Old 12-27-2006, 04:55 PM   #1 (permalink)
import2nr's Avatar
Send a message via AIM to import2nr Send a message via Yahoo to import2nr
Radiator Problems
Okay so i have talked about this on anohter thread realted to the raditor.
My truck was diagnosed with a cracked RAD and so the dealer fixed it ... but when i was driving my truck around the next day i noticed a vibration/humming noise coming from the front of the truck... this only happens when you GET ON IT.. so i took it back to the dealer and they told me they dont see anything wrong with the install. nothing is out of place as far as the RAD is concerned ... so they say... im going to be taking it back in again for them to find this problem .. the dont deny there is a vibration but they are not sure it has to do anything with the radiator being replaced.
i said it has to be somthing with the radiator because my truck was not doing this prior to the dealer working on my truck.
so my question is this.. has anyone else had there RAD replaced and had vibratiing issues ... and or does anyone know where this vibration might be coming from...
*2004 Galaxy Black SE CC
*Rockford Fosgate Punch 200 a4
*Two 10" Kicker Comp's down firing
*Omega MAX-E Remote Start/Alarm with pager remote
*ECO Systems Fuel Enhancer
*Volant PowerCore CAI / Ram Air Scoop
*AIRE TBS
*2 Degree Timing advance
*AT3030XL muffler / 3" exhaust piping from the STOCK "Y" back
*Hoppy EasyLift Tailgate Lift Torsion Bar
*Black Alteza style tail lights
*Lund S.S. bug deflector
*NCD 2" Leveling Kit W/ Bump Stops
*Nitto Terra Grapplers LT285/65R18E1
import2nr is offline   Reply With Quote
Old 12-27-2006, 06:51 PM   #2 (permalink)
goathead's Avatar
Re: Radiator Problems
just be happy its a vibration and not leaking tranny cooler lines. be sure to check the sping clamps on your cooler lines, as some dealers reuse the stock ones and they will not hold as good the second time.....good luck w/ your prob.
steve
Old 01-01-2007, 10:30 AM   #3 (permalink)
import2nr's Avatar
okay so aside from just accepting the fact that nissan messed up my truck are there any other reasons why my truck might have vibrations coming from under the hood after they installed a new radiator.... these vibrations also come while in nutral at high RPMS again these were never there prior to the radiator install.....
does anyone here know the process of taking out and putting in a new radiator on our trucks ... i know its probably unlikely but does the engine have to be raised or lowered or ... i know i know im scavengingfor answeres but i have know idea why a new radiaitor would cause vibrations from under the hood unless they diddnt put somthing back the way it was .
*AIRE TBS
Anyone else with a bad radiator cap? mtofell Titan General Discussion 4 07-29-2006 08:15 AM
Need a new radiator vw1972bugs Titan General Discussion 5 01-18-2006 06:17 PM
Loud radiator fan skycruiser Titan Problems & Dealer Service 11 07-25-2005 08:35 PM
My radiator went out>> ChadEberly Titan Problems & Dealer Service 5 07-24-2005 05:40 PM
Radiator Cap SmokeSE Titan Problems & Dealer Service 6 06-26-2004 01:34 PM
