Old 01-29-2007, 06:45 AM   #16 (permalink)
Re: warped rotors
Where did you get the cryo rotors for the Titan?
Old 01-29-2007, 11:34 AM   #17 (permalink)
cneary812's Avatar
Re: warped rotors
remember cryo rotors will never warp cause they stay cool lol
05 LE Crew Cab Smoke OR 4x4
airbox mod with K&N
Scangage2/blendmount
Roadmaster Active Suspension
NCD leveling kit installed 3/10/09 Thanks Adam!!
MVP Titan sticker on 3rd brake light.
2º Timing advance, Thanks John! 11/14/09
future mods - JBA Evol , Injen Powerflow, and more
cneary812 is offline   Reply With Quote
Old 01-30-2007, 08:06 AM   #18 (permalink)
DeadRiver's Avatar
Send a message via AIM to DeadRiver
Re: warped rotors
had that judder real bad in my 04 cc. factory recall for some brake module, i'd have to read the invoice to see exactly what they did. cost nissan about 800 bucks when all was said and done, and i got new rotors.
2004 Sedona Titan LE CC 4wd
Link to DeadRivers' Overhead Racks with Bed Extender MOD Link to DeadRivers Titan Photos
2° | Sliding Bed Extender | 07 Bed Divider | OEM Overhead Racks | 10" BA Sub in a www.tech12volts.com Enclosure
The Urinator™
DeadRiver is offline   Reply With Quote
Old 02-01-2007, 08:32 PM   #19 (permalink)
Clint's Avatar
Re: warped rotors
Originally Posted by BKW
Steve...This is the most informative post I've read here or elsewhere. This explains the cause and effect of all the Titans brake issues.
Your statement about turning rotors really should hit home with all the owners of 2004's and some 2005's.
When the judder issues began, many Nissan dealers had none of the new brake parts, so they turned the warped rotors (A No No under any circumstance), and replaced the pads. The brake judder then re-appeared within a few days.
The Titan got a bad rap...still unresolved among the many 2004 owners, because the dealers were unprepared to handle the issues.
Amazing first post. Usually we get trolls, not real information. Thanks.
Clint
You have two choices in life:
Old 04-24-2007, 07:47 AM   #20 (permalink)
cneary812's Avatar
Re: warped rotors
well... it looks like it is strating to happen again. I am going to wait till it is completely obvious with no denying that the rotors are warped again or that it is indeed brake judder. Seems to only be bad at sparatic times so far so kind of hard to tell for sure. Its been a little over 3k miles since last time now.
airbox mod with K&N
Old 04-24-2007, 08:19 AM   #21 (permalink)
Re: warped rotors
here we go again. while i do not doubt that pad material can and does imprint onto a rotor and cause "judder", anyone who says rotors do not warp have never turned a rotor on a brake lathe and witnessed it firsthand.
jtmvol is offline   Reply With Quote
Old 04-24-2007, 08:22 AM   #22 (permalink)
cneary812's Avatar
Re: warped rotors
I just resurected my thread instead of starting a new one. I guess every 3 months I will have to resurect it for the same reason...
I hope not... This is why I am going to wait a week or 2 to make sure that i am not just loosing my mind and imagining that my steering wheel is shaking while my foot is on the brake.
airbox mod with K&N
Old 04-24-2007, 08:26 AM   #23 (permalink)
TallTexan's Avatar
Re: warped rotors
I have had 2 of the new brake fixes , new rotors and all. The fix is not as good as we think. I have heard that Nissan will no longer fix the brakes if you have had the new design installed. They fixed mine but probably no more.
Robert Louis Stevenson
Old 04-24-2007, 08:28 AM   #24 (permalink)
cneary812's Avatar
Re: warped rotors
time will tell... Rotors should not warp in 3k miles and it should not happen every 3k miles! But it is happening!
airbox mod with K&N
Old 04-24-2007, 08:33 AM   #25 (permalink)
Nissan Mike's Avatar
Re: warped rotors
Nissan will no longer do a complete update again after this has been done initally.You rotors are still covered under warranty 3-36 for rear but the warranty for the front rotors for jutter has been extended to 3 yrs unlimited mileage.If rotors are machined or replaced under warranty the pads are included.If it is just worn out pads,unfortunately you're an owner.
Old 04-24-2007, 08:36 AM   #26 (permalink)
cneary812's Avatar
Re: warped rotors
very true.
its hard to wear out pads in 6500 miles with normal driving and braking.
airbox mod with K&N
Old 04-24-2007, 08:39 AM   #27 (permalink)
SoBeGraphics's Avatar
Re: warped rotors
Many dealers including mine will say that the pads wore and caused the judder instead of the rotors failing and eating the pads. Big difference between the two. The first situation the customer pays and the second situation the dealer must pay. "What came first the chicken or the egg?" lol f'n dealers will find a way to not pay. My dealer tried to hit me with a 600 bill to replace them but i went with the stillen kit instead. 30,905,940,950,909 times better.
2005 Titan LE Crew - Galaxy - BT - BANKS - AEM - BLACK BOX TUNER - Dyno @ 298 rwhp / 359 rwtq
Weeeheeheeheehee. Click Here
SoBeGraphics is offline   Reply With Quote
Old 04-25-2007, 11:22 PM   #28 (permalink)
Re: warped rotors
You need to find a new dealer,you're getting hosed...
Call 800-NISSAN1 and tell them you have a Titan with a brake judder,I guarantee you this dealer will be set straight!!!!
Old 05-22-2007, 11:14 AM   #29 (permalink)
cneary812's Avatar
Re: warped rotors
well i took it in today to have the brakes done again and they said they resurfaced the rotors which were about .00064" off. I said O-K but if this happens again im calling NISSAN. So... time will tell
airbox mod with K&N
the new rotors are warped ringo Titan Problems & Dealer Service 13 10-10-2005 12:55 PM
Warped Rotors casique Titan General Discussion 15 10-22-2004 08:42 AM
Warped rotors karlconnell Titan Problems & Dealer Service 90 09-06-2004 01:20 AM
warped rotors... TITAN21 Titan General Discussion 20 05-27-2004 08:12 PM
Warped rotors...not good! karlconnell Titan General Discussion 23 03-04-2004 06:21 PM
