Old 02-12-2007, 05:43 PM   #1 (permalink)
Rubbing/Grinding sound when I turn in 4X4
When I turn sharp while the truck is in 4x4 high and low, there is a rubbing (I know its not my tires) sound and I have to accelerate more to make the turn. Whats up with this?Also, should my warranty cover this. I have 41k on my titan. Thanks and sorry if this has been posted=Rookie!
hogfan1 is offline   Reply With Quote
Old 02-12-2007, 05:59 PM   #2 (permalink)
konigfritz's Avatar
Re: Rubbing/Grinding sound when I turn in 4X4
are you doing this on dry pavement?! that is a no no. IT is 4WD system not AWD. not meant to be used on dry pavement. what you are feeling is the extra effort the truck needs to turn the wheels. The 4WD is to be used in loose or snowy situations, not on pavement. NOT GOOD FOR THE TRUCK!
AKA Filthy Whore, aka fartingdogwhore
04' Galaxy CC/BT/OR
K&N filter & DIY air box mod, JBA Cat back
Pioneer 6900UB
2* Timing Advance
Silverstar Ultras Active Tuning ground kit
Power locking tailgate
http://s3.bite-fight.us/c.php?uid=180006
MOΛΩN ΛABÉ
"Dammit Tolson, You know what those shorts do to me."
- J. Edgar Hoover, former FBI Director
konigfritz is offline   Reply With Quote
Old 02-12-2007, 06:00 PM   #3 (permalink)
i<3mytitan's Avatar
Send a message via AIM to i<3mytitan
if you're doing this on concrete....STOP. not exactly sure of the mechanical explanation but you're asking for a new front diff. someone chime in as to why it needs more speed to make a sharp turn.
http://usingthejohn.smugmug.com
i<3mytitan is offline   Reply With Quote
Old 02-12-2007, 06:02 PM   #4 (permalink)
konigfritz's Avatar
The sharper the turn the more friction, therefore the more power needed.
04' Galaxy CC/BT/OR
Pioneer 6900UB
2* Timing Advance
MOΛΩN ΛABÉ
Old 02-12-2007, 06:10 PM   #5 (permalink)
It was snowy/icy conditions thats why I had it in 4. Should it be doing this in mud?..b/c it does.
Old 02-12-2007, 06:14 PM   #6 (permalink)
konigfritz's Avatar
it will be harder to turn in 4wd, but for the noise, Without knowing what it sounds like I can't tell you if it is normal or not. Mine is pretty quiet in 4wd unless you turn very sharp and then you get some suspension noise, but not much.
04' Galaxy CC/BT/OR
Pioneer 6900UB
2* Timing Advance
MOΛΩN ΛABÉ
Old 02-12-2007, 06:27 PM   #7 (permalink)
K. I'll be sure to keep an eye on it. I'm really enjoying the site, lot of helpful topics on here. Leveling kit is my next project. I puttin some Cooper Disc STT's on this week. Thanks guys!
Squeel / Rubbing sound Justintoxicated Titan General Discussion 3 09-29-2006 05:40 PM
Sound after you turn the ignition off Bayou Titan Titan Talk Site Polls 26 01-11-2006 01:48 PM
Strange grinding sound on front wheel? coyote268 Titan General Discussion 7 04-27-2005 07:24 AM
Rubbing sound and squeal fronm front driver wheel falchulk Titan General Discussion 4 03-02-2005 11:37 AM
Grinding/Moaning sound while turning left HighDesert Titan General Discussion 7 01-20-2005 05:37 PM
