Fuel Gauge Only registers to 1/4 Tank??? Help?
Hey guys,
Well I've just found out that my truck has a unique problem...apparently, my fuel gauge doesn't like to tell me that I'm running out of fuel. It fills up fine, registers all the way down to 1/4 tank then just happens to stay there...and because of that, I've run out of gas twice now, no warning light no nothing, and when i shut off my truck the needle does go down past E showing that the gauge cluster itself seems to be fine....So, after taking it to my dealer they said that the most likely cause was that it was a loose ground wire their mechanic came across...That was fixed free of charge, but has had no effect and my gauge is still only going to 1/4. I've searched around a few forums and have found no other problem like mine, so I thought I'd finally write a thread and ask if any of you awesome members might have any idea whats going on? Much appreciated guys and gals!
Thanks.
Ryan C.
2006 Smoke Titan Crew Cab XE-Adopted: January 2008
________________________________
Current Mods:
Interior-JVC Reciever, Aspire AMP, Two 10" Kicker Subs in JL Audio sub box, Boston 6" Component Speakers.
Exterior-Debadged, Colormatched Rear Bumper, XE To SE/LE Chrome Bumper & Grille Swap, Hazzed (Lightly Smoked) Taillights, Hella 500 Series Fog Light Kit Mounted In Front Bumper, 5% Tint All around.
To Get Off The Ground-4" SpringTech Spindles, PRG 2.5in Leveling Kit, 2" Dosche Blocks
Under The Hood-2* Timing Adv. (Thanks BECHLYF  ) JBA Cat-Back Exhaust w/ (soon to be) custom turndown exhaust tip, Injen CAI, Custom Painted Manifold Cover.
Bling/Rubber-22" XD HOSS/ 325/50/22 Nitto Terra Grapplers
Miscellaneous-Escort X50 Radar Detector.
___________________________________
Wishlist/Future Mods:
*Headlight Mod
* SAW's all around, 4" rear block, CST Carrier Drop Bracket, PRG UCA's, PRG HD Shackles
*GrillCraft Mesh Inserts
*AMP Research Steps/Go Rhino's
*PRG Traction Bars
*Hornblasters.com 4pc. Conductors Special Train Horn
*Defender Roof Rack, Defender Rack light bar, Four 8" Hella Lights, Two 6" Hella's
*3 Pod Gauge Cluster w/ Oil Pressure, Voltage Meter/ Trans Temp Gauges.
*Kenwood Touch Screen Double Din
*All door dings/scratches and rear dent repaired
Future Company: De-Railed Custom's
www.myspace.com/derailedcustoms
