Anyone here ever replace the wheel studs or have any diagrams on how to do it? (for the rear 4x2) I've done it to other cars but haven't had the time to look at the titan yet. 2 studs are stripped because some newbie kid from Firestone doesn't know how to use and impact and stripped 2 studs the last time they rotated the tires. Came back and told them but it was over 3 months ago so they don't warranty their work or claim responsibility. Oh well never going there again. Thats what I get for being lazy and not doing it myself like I always have.
I just found out I have the same problem! I was cleaning and painting my rotors today and couldn't take off the left rear wheel because one of the nuts and studs is stripped/crossthreaded. The dealer, Universal Nissan in Kissimmee, FL is the only place that has worked on the truck and removed the wheels. I'm so pissed that I took the truck in for the brake TBS and a leaky axel seal and 7months later find out I have another problem they created. I'm taking it in tomorrow and hope the dealer does the right thing and accepts responsibility for damaging my truck. This is exactly why I like to work on my vehicles myself.
__________________ IRC VK56 MEMBER
05 Silver SE 4X2 KC
OEM Fog light kit w/Sylvania SilverStars
Stillen SS Cat Back Exhaust
6000k HIDS
Armada Front Air Dam
Stillen Rear Sway Bar
JL Audio 10 inch Sub
Active Tuning Grounding Kit
Uprev Tuned
TrueTrac coming soon...
I would try popping a rotor off and laying it on a solid surface and tapping one out with a drift pin and a hammer. Do not have a Titan yet, waiting for the '08, but this works on most vehicles. Then push in a new stud and pull in on through with the lug nut until flush with the back.
I think it involves rotating to a position where there is clearance, driving the broken stud out with a BFH, pulling the new stud into place with a lug nut.
Do you have a diagram of the rear assembly? Thanks in advance!
05 Silver SE 4X2 KC
6000k HIDS
Uprev Tuned
my brother in law just changed out 4 on my father in laws titan.. he said it took him like 10 minutes to do... and the dealer was trying to charge 400 plus.. Ill ask him what he did and get back to you..
PRG'D: 4" SPINDLE, DR COILOVERS, 2.5 DEAVER PACK, 2" BLOCK, BILSTEINS, CARRIER DROP BRACKET.
TIRES: 35X1250X17 DUNLOP MUD ROVERS ON MOTO'S 951 BLACK
A little heads up while putting the new stud in, use a nut that is larger than the threads in between the rotor and the lug nut. You can sometimes still damage the lug nut even with this method but it is a lot less likely. It doesn't hurt to have a spare lug nut either just in case. Hope this helps.
Just came back from the dealer and with some encouragement they agreed to fix it. I have an apoitment at 7:00am tomorrow.
Whish me luck...it get's fixed right and I have no more drama.
Thanks for everyone's help.
05 Silver SE 4X2 KC
6000k HIDS
Uprev Tuned
Just got done doing them. It took about 1hr to do. In case someone else ever needs to replace the rear studs here is what you need to do.
1. Remove caliper 2 bolts 10mm
2. Remove the rotor
3. Remove the E-Brake 2 clips on top/bottom and 2 springs
4. Hammer out the broken studs
5. Put the new ones in, tap them in place as much as you can. then put the rotor back on and use the lug nuts to tighten them into place
6. Then put back everything as you took them off and you should be done.
2. Remove the rotor
hope this helps.
I just replaced two because of a boneheaded mistake with my air wrench. As far as step 3 goes....If you pull down on the lower E-brake shoe it will move out of the way just far enough so that the stud will clear it and you will not have to remove the clips or springs. Once the stud is in just push the brake shoe back into place.
i have bought all my studs (regular & extended) for my Titan here. Not a bad idea to have a few spare ones laying around. If you remove your wheels alot or just get trigger happy with the air wrench as well.
So let me get this right, you just take all the brake stuff off and hammer it out. That cool for the front and rear? I glad it's only that, a few of mine are getting bad. Has any one replaced them for bigger or longer ones. I was looking at another brand truck the other day at the tire shop and noticed they were a little bigger, longer and beefier.
