Old 04-09-2007, 02:20 PM   #1 (permalink)
TitanRider's Avatar
Question Need some help with the dealer.
I was going to put on my spacer kit but could not even get my front passenger wheel off. First off I noticed a lug nut missing and I thought no big deal. I loosened the other lug nuts before a I jacked up the wheel and they where very stubborn once I got them loosened. Jacked up the wheel and only got three nuts off w/ little shavings in them. I had my buddy press the brake and I attempted the fourth nut cause it was really hard and it snapped the stud right off. And the fifth was the same so I didn't want 2 studs missing and it would not tighten all the way. So write now I only have 3 lug nuts holding the wheel on.
I got my oil changed on 3/30. I just got off the phone the service guy and he said there was no record of the tire being taken off. I was not notified a lug nut was missing. But they did notify me of tire condition and alignment. The service guy had no record of the tires being rotated and said I should talk to the previous person that did that about the lug nut missing. And he will charge me $110 for a new stud and lug nut and $4.95 for the other missing lug nut.
Is this the correct way the service guy assessed this situation or is he passing blame because there was no service on the lug nut? Do I have any other options?
TitanRider is offline   Reply With Quote
Old 04-09-2007, 02:37 PM   #2 (permalink)
Re: Need some help with the dealer.
Have you had all your service done through them??
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
Old 04-09-2007, 02:39 PM   #3 (permalink)
Yellomantis's Avatar
I know it might be a bit of a drive for you, but Tim over at West Covina Nissan should be able to help you out.... *wink, wink*
www.myspace.com/yellomantis
Old 04-09-2007, 02:49 PM   #4 (permalink)
TitanRider's Avatar
Only oil changes, but not every oil change. I did have the tires rotated around 19k mi but have 26k on them now.
Old 04-09-2007, 02:57 PM   #5 (permalink)
Did they do the rotation??
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
Old 04-09-2007, 03:20 PM   #6 (permalink)
TitanRider's Avatar
No but I would have noticed a lug nut missing for 7k mi.
Old 04-10-2007, 10:52 AM   #7 (permalink)
Send a message via AIM to rodney
okie... i will ask the obvious question: did you rotate your own tires? if not, who did? it is obvious that whomever did the work f'd up the simple job.
rodney is offline   Reply With Quote
Old 04-10-2007, 12:10 PM   #8 (permalink)
TitanRider's Avatar
No I did not. And no they did not f up because I would have noticed a lug nut missing for 7k miles.
Old 04-10-2007, 12:33 PM   #9 (permalink)
If the lug nut wasn't tighten properly, it could have slowly worked it's way loose and just recently fallen off. I would go back to whom ever did the work, and file a complaint!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
D@mn Dealer... pi3yeargrad Titan General Discussion 44 03-22-2006 01:09 AM
Do I have to take off my PRG kit before I go to the dealer? Waterfowler Titan Problems & Dealer Service 4 09-08-2005 10:03 AM
Should I get the dealer- ckat Titan General Discussion 2 03-27-2004 08:58 AM
Dealer sticker - opinions on allowing the dealer to put them on? rrumaner Titan General Discussion 16 02-17-2004 05:26 PM
