Old 04-10-2007, 02:05 PM   #1 (permalink)
thedeer2's Avatar
Send a message via AIM to thedeer2
4x4 Question and a couple others
1) 4x4 will not disengage unless the vehicle is stopped and put into park. Anyone know the cause or solutions.
2) does anyone else get a rattle noise from inside the dash during acceleration?
3) People that have had a front diff. leak, where does the leak originate?
4) Has anyone else had issuse with the adhesive on the mud flaps and weather stripping fail repeatedly?
Thats all. Thanks.
thedeer2 is offline   Reply With Quote
Old 04-10-2007, 02:53 PM   #2 (permalink)
gixxer0.6g's Avatar
Re: 4x4 Question and a couple others
1) Happened once
2) Nope
3) Nope
4) Nope
05 4x4 SE~
Performance Mods:
Banks exhaust, Nismo Intake, 2-Deg Timing Advance,
Exterior Mods:
Euroguard Brush Guard w/ 100w Spot Lights, fog lights, PRG Mini Lift, Low Profile Tonneau Cover, In Channel Vent Visors, Billet Grille, 17x8.5 MB Motoring Razor Wheels w/ 285/70R17 Kumho KL78s.
gixxer0.6g is offline   Reply With Quote
Old 04-10-2007, 04:14 PM   #3 (permalink)
BlingAlong06's Avatar
Send a message via AIM to BlingAlong06
Thats all. Thanks.
1 i have noticed that the more oftn i use it the faster it comers out of 4x4. if i dont use it for a month or so i takes a little bit.
2 no
3 no
4 i took my mud gaurds off right when i got my truck. i didnt want then to rub my paint and scuff it. and i think it looks better also
2006 SE CC 4x4 OR BT
AEM BruteForce CAI
Airraid TBS
Banks exhaust
2* TA
TB-Bypass
Leveled out
Smoked tail lights
Dark tint(Real Dark!!!)
Motometal 951s
Nitto Terragrapplers 325/60/18
BlingAlong06 is offline   Reply With Quote
Old 04-10-2007, 04:15 PM   #4 (permalink)
Wallrat's Avatar
If you look under the truck at the front diff you'll see where the CV shafts run from the wheels to the diff. There's 6 bolts that hold the CV to a stub shaft which goes into the front diff. This shaft has a habit of pulling out from the diff. Once its out, oil flows.
I've got feeler gauge fingers, torque wrench wrists, and a timing light eyeball!
05 SE KK 4x4
offroad, big tow, buckets, util.
$$$ stereo
Pro Comp 6", Dre's/Bilsteins, PRG Traction Bars
315/70 17 BFG AT KO on 17x9 AR Chambers
Wallrat is offline   Reply With Quote
Old 04-10-2007, 05:18 PM   #5 (permalink)
helomech's Avatar
Take those f***ing mud flaps off. I have two marks behind my rear tires that is rubbed all the way down to the bare metal. I threw the mud flaps as far into the woods as I could.
helomech is online now   Reply With Quote
Old 04-12-2007, 02:13 PM   #6 (permalink)
littlemike822's Avatar
Mudflaps only help those behind you :-)
littlemike822 is offline   Reply With Quote
Old 04-12-2007, 02:36 PM   #7 (permalink)
1) It started happened after the front diff was replaced.
2) No
3) at the driver's side seal
4) just the mud flaps - replaced with www.duraflap.com
Couple new pics... Chris93Si Titan Pictures & Media Post 17 06-27-2006 02:39 PM
couple ?? before purchase gswarriorfan Titan General Discussion 9 09-16-2004 08:10 AM
just a couple questions jayhawk1 Titan General Discussion 7 03-05-2004 02:48 PM
