Old 04-11-2007, 11:19 AM   #1 (permalink)
MA-titan's Avatar
No reverse lights
Just had my front diff replaced last week and noiticed last night that the reverse lights are not working. The relay under the hood is fine, bulbs are fine now what? Is there a fuse not listed in the fuse panel? I don't think there is need to disconnect anything under the truck to replace the front diff or is there? Help!
MA-titan is offline   Reply With Quote
Old 04-11-2007, 01:06 PM   #2 (permalink)
Kronos1965's Avatar
Lightbulb Re: No reverse lights
1. Somewhere the harness has grounded on the reverse wire. It could have been nicked I imagine.
or
2. The signal when you put it into reverse from the shifter is not working and not completing the circuit.
Just curious if you put it in reverse and connected a tester to your trailer wiring harness what would happen...
Kronos1965 is online now   Reply With Quote
Old 04-12-2007, 05:11 AM   #3 (permalink)
MA-titan's Avatar
Upon further investigation the trailer lights and rear sonar are not working as well. Thinking it must be something to do with tha BCM update that was done last month........back to the dealership again. Last month it was front diff which took 3 weeks to come in. The two things that are important to me and need to be reliable on this vehicle have let me down which makes me concerned when traveling to far away destinations
Just venting
? Brighter Reverse Lights ? tazstitan Titan Parts & Accessories 9 03-16-2007 01:29 PM
Installed some reverse lights gixxer0.6g Titan General Discussion 10 11-15-2006 11:01 AM
Aux. reverse lights NHJAKE Titan General Discussion 3 11-11-2006 02:45 PM
Backup/Reverse lights not working, checked fuses. JGM Titan Problems & Dealer Service 3 10-03-2006 11:01 AM
Where did reverse go? Miker84 Titan Problems & Dealer Service 14 10-25-2005 01:43 AM
