Old 04-14-2007, 09:32 AM   #1 (permalink)
phugoid's Avatar
Angry ACK! oil filter problem HORROR story
ok, heres the story so far.
2 months ago i had my oil/oil filter changed at Expressway...no problem.
today i took my Titan to the dealer for the harness recall, and while its there, i figured go ahead and change the oil!
then im informed that whomever changed my oil filter (Expressway), they did 2 things wrong. not only did they put in the WRONG filter, but they screwed it in so tight it stripped the bolt and it messed up the cooling assembly!
the dealer tried to see if they could salvage it, but NO!!!
now mind you, these past 2 months i had no problems or oil leaks
so needless to say i was informed the truck is dead!....
so i had to scramble for a ride back home, but on the way home i stopped by Expressway and splained the situation to the manager. of course, he said that what Nissan should have done was not remove the filter and have me go back to Expressway so they could verify if what they did was wrong! ...but of course, it was to late by then, the dealer already had removed the filter and could not replace it. the dealer now has to order a new cooling assy (whatever that is) and a new bolt...... and of course, including $200 for labor its gonna be about a total of $600!!!!! WTF!......
while i was at Expressway, the manager confirmed the proper filter was installed, an HP 4612 according to their records.
now i need to physically confirm that number with the filter (Thats in a plastic bag in the front seat of the Titan which is at the dealer!)...
so i called back the dealer with what Expressway told me...and of course they said bull::#$...... i asked to speak to the tech, but was told its a better idea to wait till monday and speak w the service manager and get everything hammered out as to exactly what happened. then ill have to consider my options vis-a-vis who the heck screwed up here!........
i just hope i dont get screwed with the bill here. i think it was Expressway that screwed up, but their manager had a good point in saying that Nissan, once they realized there was a problem with the filter,(before they removed it) should have had told me to take it back where i had it changed....
come monday ill have a better idea what to do. but this pisses me off big time.
No Titan till at least Tuesday, not to mention a ~$600 bill to pay.
will keep you posted....ack the HORROR stories!
phugoid is offline   Reply With Quote
Old 04-14-2007, 09:36 AM   #2 (permalink)
helomech's Avatar
Re: ACK! oil filter problem HORROR story
Sorry to hear that, but that is why I do my on oil changes. I would never use one of those quick oil change places. If for some reason I couldn't do it myself I would have the dealer do it.
helomech is online now   Reply With Quote
Old 04-14-2007, 09:45 AM   #3 (permalink)
Yeah, DIY rules. Also, $600 sounds a little pricey to change the oil cooler. Probably buy the part from mossey or somebody and DIY that also.
Old 04-14-2007, 10:07 AM   #4 (permalink)
phugoid's Avatar
its $319 for the cooler assy, and $47 for the oil stud, plus about $200 in labor.
for that kind of work I cant do DYI...
where's judge judy?
Old 04-14-2007, 11:16 AM   #5 (permalink)
baseballfanz's Avatar
First off I think the only thing damage would be the "Stud", stripped thread not sure how the cooler woiuld get damage. Since that part is removal able from the cooler unit shouldn't be that much. It's a $20 part.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 04-14-2007, 12:38 PM   #6 (permalink)
the factory put my filter on tighter than ****....if a quick lube put it on tight enough to strip something....they must have used a wrench to put a new filter on....bad idea.
jasonwabc is offline   Reply With Quote
Old 04-14-2007, 12:58 PM   #7 (permalink)
where's judge judy?
If you have the part numbers, you can look it up online, like www.nissanpartscheap.com to find out if you are getting overcharged for the parts.
Old 04-14-2007, 01:20 PM   #8 (permalink)
$236 for the cooler, $21.96 for the stud.
I think you could even do this your self.
http://www.trademotion.com/partlocat...=2&catalogid=2
Old 04-14-2007, 03:22 PM   #9 (permalink)
Clint's Avatar
If they gave you the truck to bring to the oil change place, would you let them repair the truck? If they damaged the vehicle then it should be your choice of who repairs it and they get the invoice to pay. I'd prefer Nissan repairing their own truck.
Good luck with getting this sorted out.
Clint
You have two choices in life:
Old 04-14-2007, 11:51 PM   #10 (permalink)
EVO8's Avatar
This is the reason why I don't go to those fast monkey lubes. I do all my installs and oil changes. If it requires someone messing with my truck or car, it will only be the dealership.
2006 Titan XE 4x4 (PRG 4" Performance package)
2003 Evolution VIII (358awhp/354awtq) that's on 91octane,stock boost, stock turbo.
2007 GSXR1000 (not enough road to touch redline)
"Dream as if you'll live forever, live as if you'll die tommorow" : James Dean.
EVO8 is offline   Reply With Quote
Old 04-15-2007, 05:52 AM   #11 (permalink)
phugoid's Avatar
thanks guys.
ill deff look into this more. im going to talk w the service manager (great guy from past experiences at Bruce Bennett Nissan in Wilton, CT) =..... so i'll have a better idea of exactly what happened, then ill decide whether to pusue it further against those oil monkeys.
no matter what, from now on my Titan goes to the dealer for everything!
will update as soon as i know. im suppposed to get the truck back Tuesday.
...... i miss my Titan....
he/she is all alone, battery disconnected, relegated to the back of the dealer next to a creek that will probs overflow with alll this rain thats happening!!
Old 04-15-2007, 05:56 AM   #12 (permalink)
phugoid's Avatar
Clint
Clint, the truck cant be driven. id have to tow it to the oil monkeys and i dont want that further expense. plus its to late for that now.
it'll have its operation at Nissan hospital, not at some oil monkey clinic...hehehe.
thanks tho.
Old 04-15-2007, 06:52 AM   #13 (permalink)
phugoid's Avatar
thanks baseballfanz........
thanks for the link. tho i can do simple mods, like the fog light one, ive never been much of a DIY mechanic wise. i will show the service manager the prices on those parts, and ask him "whats the deal?"
Ultra filter oil filter? 05dr Titan Performance Modifications 8 10-11-2005 02:38 PM
Not really a War Story, but.... RockyMtnTitan War Stories 5 10-06-2005 09:02 AM
Ultra Filter (resuable oil filter) mlucero Titan Parts & Accessories 4 08-01-2005 06:10 PM
oil filter found; fuel filter??? juma Titan General Discussion 2 04-18-2004 12:06 PM
