Old 06-30-2007, 06:19 PM   #1 (permalink)
duks4u's Avatar
Trailer Lights not working
Have checked all fuses... tail lights and brake lights work fine. Testing out of the trailer light connection can not get a test light to light up.
Anyone have any ideas?
duks4u is offline   Reply With Quote
Old 06-30-2007, 06:39 PM   #2 (permalink)
Demondw3's Avatar
Re: Trailer Lights not working
Did you install the relays that go under the hood Check this link someone posted a picture of where the relays go.
Do I have the relays?
check out my trucks transformation.
http://www.kodakgallery.com/Slidesho...Uy=8mexzr&Ux=0
Demondw3 is offline   Reply With Quote
Old 06-30-2007, 06:56 PM   #3 (permalink)
duks4u's Avatar
No but it had been working for 3 years until now.
Maybe one of these went out.
Thanks......
Old 06-30-2007, 07:04 PM   #4 (permalink)
Nissan Mike's Avatar
Don't forget the 2 -10 amp fuses under dash near steering column
Old 07-01-2007, 04:38 AM   #5 (permalink)
AF-Medic's Avatar
Is the trailer gorunded to your ball. I had to hook the trailer up to my ball to make the lights work.
2007 SE Granite C/C 4X4 BT,OR,RF,Bed Package
Born 12/18/06 in Mississippi/ adopted 03/31/07 in Anchorage. Man that stork had a good drive.
Improved with Westin black aluminum nerf bars, Husky floor liners, Vent visors, Full billett grill, Black XE door handles,American racing Teflon THUG'S, Top Dawg folding tonneau cover, AEM brute force CAI with prefilter,
PRG 4INCH PERF Package with Saw's Shift Pass You
AF-Medic is online now   Reply With Quote
Old 07-01-2007, 07:33 AM   #6 (permalink)
Demondw3's Avatar
I have never heard this one before.
Old 07-01-2007, 10:20 AM   #7 (permalink)
BobNYC's Avatar
Me neither. There's a ground in whatever trailer connector you're using.
'07 SE KC Titan, Tow, Utility Bed, Off Road and Preferred packages, Majestic Blue
BobNYC is offline   Reply With Quote
Old 07-01-2007, 10:40 AM   #8 (permalink)
duks4u's Avatar
I have checked all of the fuses and relays under the hood in the box next to the firewall.
Nissan Mike, Can you be a little more specific I have crawled up under the dash but don't see any fuses near the steering column.
As far as being grounded, I am checking it at the truck connection that should be grounded.
Old 07-01-2007, 10:53 AM   #9 (permalink)
Under the dash to the right of the steering wheel collum there are two ten amp fuses spliced inline (mine where taped together) they work the rear trailer turn signal and brake light. They are small so they could be hard to spot.
jpdp8 is offline   Reply With Quote
Old 07-01-2007, 08:16 PM   #10 (permalink)
TallTexan's Avatar
Are you sure you checked the little 10 amp fuse under hood in the box nearest the firewall. I looked half the night before I found it and replaced. Bingo, trailer lights.
Robert Louis Stevenson
Old 07-01-2007, 11:09 PM   #11 (permalink)
AF-Medic's Avatar
I had my trailer lights plugged into my Titan but didn't have the ball hooked up and the lights would not work. I hooked the ball up and the lights worked. Tried it a couple of times and it did the same thing.
Old 07-02-2007, 04:58 AM   #12 (permalink)
Demondw3's Avatar
I will have to try this when I get home from work. I already have one light that works when it want but I think it is my adapter. My truck did not have the tow package so I bought a Uhaul adapter and it is starting to give me trouble.
Old 07-04-2007, 08:07 AM   #13 (permalink)
duks4u's Avatar
I fixed it....
I traded it off. If you have to go to 3 or 4 different places ot check fuses than I need to go back domestic.
Old 07-04-2007, 10:26 PM   #14 (permalink)
AF-Medic's Avatar
Heck of a reason to trade but goodluck to you. What did the dealership say when you told them you were trading because of the fuse box?
Old 07-05-2007, 06:06 PM   #15 (permalink)
duks4u's Avatar
That wasn't the only reason. Had most of the problems that everyone else had and all of the recalls, etc. I really like the Titan as far as power and especially the interior design with all of the storage. Had close to 100K on it and was really just time for a new truck, but the rattles really were getting bad. I went to all dealers and Nissan would not deal on the '08's. I tried but they didn't want to play.......
Interior trailer lights not working Wallrat Titan Towing & Hauling 17 01-10-2007 08:24 PM
Trailer Parking Lights not working...Any Ideas?? jhawk Titan Towing & Hauling 3 10-29-2006 05:54 PM
Trailer Lights : running lights not working Chance2336 Titan Towing & Hauling 9 09-12-2006 05:33 PM
Trailer running lights not working since day 1, dealer won't help...DIY fix?!? Justin311 Titan Towing & Hauling 11 06-22-2006 06:23 PM
Trailer lights not working.....Need help TitanOwnr Titan Towing & Hauling 9 05-01-2006 05:17 PM
