Old 08-25-2007, 03:17 PM   #1 (permalink)
SoBeGraphics's Avatar
05 radiator cracked with only 42K
WTF?? i searched and noticed others with the same problem.
the bottom has a 3 inch crack with next to the fitting.
POS dealer will not fix it. Cost me 266.00 + 70 install.
Dealer wanted a lot more.
Why such a crappy radiator in a great truck?
If so many others have had the same problem shouldn't there be some sort of TSB??
My 89 Toyota 4x4 had an all aluminum radiator and it lasted 180K. had one leak in one of the viens which i had them weld shut.
Plastic radiators suck.
2005 Titan LE Crew - Galaxy - BT - BANKS - AEM - BLACK BOX TUNER - Dyno @ 298 rwhp / 359 rwtq
Weeeheeheeheehee. Click Here
SoBeGraphics is offline   Reply With Quote
Old 08-25-2007, 03:32 PM   #2 (permalink)
killcatzforfun's Avatar
Re: 05 radiator cracked with only 42K
mine cracked around 15k... It was fine for 5k more miles until I got rid of the truck
07 TITAN CC,O/R,B/T 4X4 SE MAJESTIC BLUE
mods: fram boost air 2 cai.
8000k H.I.D's for low beams and fogs
killcatzforfun is offline   Reply With Quote
Old 08-25-2007, 09:00 PM   #3 (permalink)
tutttitan's Avatar
Send a message via AIM to tutttitan
same problem here at 20000 the dealer screwed around a while and tried to tell me it wasnt leaking, eventually got the manager on the phone and they replaced it
current Mods:
-cst 8" suspension lift
-window tint
-Black headlights w/ projectors
-black euro tailights
-flowmaster 40 series
-jvc dvd head unit
-kicker door speakers
-solobaric subs
-fiberglass box
-billet grill
-stillen bumper
-bed sliding tire rack
-shock hoop
-diamo 18" rims
-nitto mudgrapplers
coming soon:
-prg upper arms
-racerunner coilovers
-deaver long travel springs
-racerunner bypass shocks
-road armor winch bumper w/ warn 9500 winch
-toyo 37"x13.5
tutttitan is offline   Reply With Quote
Old 09-18-2007, 01:34 PM   #4 (permalink)
I just found out my radiator cracked at 37,800 and the dealer wants $1100. I asked if they would split the cost with me and they said that the good will was denied. Thankfully I found a radiator shop that will do it for $400. Screw the stealership.
surfrockman is offline   Reply With Quote
Old 09-18-2007, 01:49 PM   #5 (permalink)
an 1100 dollar radiator ??? are'nt aftermarket radaitors only like 300 ???
Old 09-18-2007, 03:15 PM   #6 (permalink)
nothing at the dealer is aftermarket.
Old 09-18-2007, 06:28 PM   #7 (permalink)
The repair was $1100 for the radiator and labor.
Old 09-19-2007, 09:03 PM   #8 (permalink)
My 05 titan's radiator broke this week with 66,000 miles. I took it to the dealer and had it replaced. The bottom tank broke. Nissan paid 25% of the bill making my cost $493. I also had both of my exhaust manifolds replaced since both were cracked. They were covered by warranty 8yr/80,000miles emission warranty. I also had the rear center seatbelt replaced under the recall done at the same time.
Carrot Top is offline   Reply With Quote
Old 10-04-2007, 08:48 PM   #9 (permalink)
My radiator just cracked on the bottom by the fan mount in tha plastic. I have a 2004 with 22700 miles on it. Warranty ran out 2 months ago. If this is happening to (almost) everyone, why won't they recall it???? I called parts to see how much a new one is $544. I called service for a total price, they quoted me around $800. I'm going to pickup a silla with lifetime guarantee tommorrow for $202plus tax tommorrow. Install myself. Just a little more complicated with transmission coolant lines going through it. Anyone have any tips to make replacement easier would be appreciated.
shoe780 is offline   Reply With Quote
Old 10-04-2007, 09:28 PM   #10 (permalink)
pgthe1's Avatar
I replaced my own a few weeks ago... Once you get the fan shroud off (2 pieces), take the fan clutch off before removing the radiator, it will make it a lot easier to remove it.
pgthe1 is offline   Reply With Quote
Old 12-10-2007, 07:15 AM   #11 (permalink)
I have a 2004 Titan with 44,000 miles and the passenger bottom on the inside of the radiator cracked horizontally about 6 inches. From looking at several different sites as well this one, the common thread is this area of the rad cracking. Do you or anyone know how or to who, this can be reported to trigger a recall.
JD's Titan is offline   Reply With Quote
Old 12-11-2007, 12:41 PM   #12 (permalink)
TallTexan's Avatar
Bad radiators, bad differentials, bad steering racks, bad brakes, a/c water leaks, bad wheel seals. When will this crap stop? I have had all these problems and Nissan still dodging arrows.
Robert Louis Stevenson
Old 08-29-2008, 05:52 AM   #13 (permalink)
My dealer quoted $900 for an aftermarket radiator replacement and said it would be more for OEM. I was there to drop $410 for the transmission coolant line replacement (at 61K miles, but no goodwill coverage) and wound up going to a mechanic for the radiator, $500 installed with lifetime warranty.
barnold1 is offline   Reply With Quote
This cracked me up: Lurchdubious Off-Topic Discussion 6 03-30-2007 09:16 AM
Cracked Windshield kctitan Titan General Discussion 31 03-17-2006 10:26 PM
Cracked Radiator GreenmtnTitan Titan General Discussion 24 02-12-2006 05:07 PM
cracked fan blade helomech Titan General Discussion 7 12-27-2005 06:58 PM
