LinkBack Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Old 03-20-2005, 05:04 PM   #1 (permalink)
Banned
Squid's Avatar
Solutions to Known Problems.
This an attempt to consolidate all the known solutions to problems in one place. If you know of, or run across a thread not listed on this first post let me know and I'll edit this post accordingly with the link to the thread. This should after a while help out not only the new owners/members but also the long time members with bad memories.
REMEMBER KEYWORD, Solutions.
Audio.
1.)Aftermarket Stereo Installation Knowledge Base.
(Suggested by Bestatchess, Contributed by Boucoup Audio Gurus )
Installing Aftermarket Radio Tonight...
2.) Audio Install with Pics.
(Contibuted by M95roadster)
Audio Install...the beginning w/Pics
3.) Bezel/faceplate and door panel removal.
(Contributed by Bestatchess Post #4)
Stereo installation
4.) Low Audio level through Aux Input Solution.
(Contributed by Sammy Sandbag)
Hardwired MP3 Player
5.) Airhorn for the Titan.
(Contributed by Juma post #6)
http://www.titantalk.com/forums/show...361#post329361
Brakes.
1.) Brake Recall Info. Warrenty extension document for 04/05 brakes.
(Contributed By Slurppie)
Brake Recall Info
2.) Stillen aftermarket Big Brake Kit.
(Contributed by gr8titan )
They're here: Stillen Big Brakes
Cab
1.) Microfilter replacement/Installation (Great How To, for trucks with no filter from the factory. All trucks do have the filter Box)
( Contributed by VW1972bugs post #21)
Microfilter- King Cab
2.) Check Engine Light, toolless code retrieval.
(Contributed by Titanparts1 post #16)
Service Engine Soon Light
3.) Low Tire Pressure Warning System FAQ.
(Contributed by Austin Post#14 and others.)
Low Tire Pressure Indicator
4.) Popping sound when closing the door.
(Contributed by HavockWK and Friends. Post #4 of this thread.)
5.) Windows creaking in the up position.
(Suggested/Solution by ctuck13 post # 12 of TITANTALK link, Solution by adjmcloon Post #6 and #10 of CLUBARMADA link)
drivers side faint rattle
http://www.clubarmada.com/showthread.php?t=465
6.) Air bag sensor light reset procedure.
(Suggested by Sammy Sandbag, Solution by smoketitan)
Dash Air Bag Sensor Reset
7.) Keyfob ID setup
(Suggested by BLwedge09)
http://www.titantalk.com/forums/atta...achmentid=9665
Differentials .
1.) Photos of 05 aluminum rear diff cover install/Info.
(Contributed by gr8titan)
Photos of 05 aluminum diff cover install
2.) Low differential fluid discovery.
(Contributed by JETTECH)
Everyone PLEASE READ!!!
3.) Checking/Draining the Front Differential.
(Contributed by BigJoe Titan, Post #32)
Differential lube check screw-locktite??
4.) Checking/draining the rear Differential.
(Contributed by Bestatchess Post 2# and #4)
Rear Diff fluid question...HELP!!
5.) Differential drain plug torque/sealant.
(Contributed by Bayou Titan Post #2 and Bestatchess Post#3)
Checking Rear Differential
6.) Rear Differential fluid change Pictures.
(Contributed by Admorris)
Rear diff. fluid change pics
7.) E-Lock locked in 2WD, 4HI & 4LO Modification
( Contributed by Austin)
Electrical
1.) Optima battery and grounding upgrade.
(Contributed by 1BADTITAN)
Pic of my Optima Battery and Grounding Set
2.) Wire colors and purpose
(Contributed by Wareagle)
http://www.titantalk.com/forums/show...272#post328272
3.) Wiring 101 for dummies.
(Contributed by Bestatchess and Juma)
Hard Wire Help
Engine.
1.) How to:ECU Reset,Throttle & Accelerator Position Learning
(Contributed by ROCKYMTNTITAN)
http://www.titantalk.com/forums/show...027#post316027
2.)Nissan Titan V8 engine development SAE white paper.(VK56DE INFO)
(Contributed by ARMADA)
http://www.titantalk.com/forums/atta...tid=9430&stc=1
3.) Oil Analysis.
(Contributed by JetTech)
Titan loves Mobil 1 0W-40
4.) Oil Pressure Fluctuation as seen on the gauge.
(Contributed by BLWEDGE09, Post#2)
Oil pressure guage
5.) Air Conditioning Drain Tube Extension.
(Suggested by Cajunguy, Contributed by Vshortt, Instructions by 37L1 Post #60 and Friends)
Another Water Problem
6.) Blackstone labs (oil Analysis) $20,00
http://www.blackstone-labs.com/
Free Kit form.
http://www.blackstone-labs.com/free_test_kit.html
Exterior Safety Items
1.) Windshield wiper skipping/replacement blades
(Contributed by everyone in the following threads.)
wipers squeaking and skipping
windshield wipers
Noisy Windshield Wipers
2.) Removal/ Installation of Big Tow Mirrors
(Contributed by BigRedTitan)
Big Tow mirror problem
3.) Oily film on windshield removal.
(Contributed by all involved)
Oily film on windshield.
4.) Changing wheels/Tire rotation/Lug nut Torque.
(Suggested by Wrenrj1)
http://www.titantalk.com/forums/atta...achmentid=9666
5.) Spare tire remote air up/check Mod.
(Contributed by RDfeatherstone)
Valve Extension Hose?
Lighting
1.) Replacment procedure for Headlights/turn signals/parking/sidemarker.
(Contributed by RRUMANER Post #9)
Bulb Size
2.) Headlight Adjustment.
(Contributed by Stitch)
Check Your Aim
3.) Solution for inadvertant shutting off of headlights.
(Contributed by honeykeeper, solution by carpentry1@optonline)
Cure for accidentally turning off lights 63¢!
4.) Solution for Intermittent dash/enviromental control knobs lighting.
(Suggested by Fluxcubby, solution by me post#3)
Electrical Gremlins
Service.
1.) Service Department Advice.
(Contributed by Wrenrj1 )
Dealing with Dealer Service Depts.
2.) Downloadable Service Manual FAQ.
(Suggested by Bestatchess, Contributed By Many.)
Downloadable Service Manual Question
3.) Nissan Free Downloadable Owners Manual(Contributed by me)
http://www.nissan-techinfo.com/nissa...id=&dept_id=30
4.) TSB Website
(Contributed by me.)
http://www.nissanhelp.com/Bulletins/Model.htm
5.) TSB's (in .PDF format)
(Contributed by Z23Fan)
Suspension
1.) Axle Wrap. (Explanation and Solution)
http://www.titantalk.com/forums/show...6&postcount=31
2.) Squeaky Suspension.
(Contributed by Mike H Post #18)
Squeaky suspension
Ticks/Rattles/Bumps
1.) Fix for tick on passenger side area.
(Contributed by arkman0, Post#7)
Fix for tick on passenger side area?
2.) Bump sound from bed when slowing to a stop.
(Suggested by Optimist, Member who first found solution unknown)
THings that go bump in the night......(problem)
Tansmission
1.) Transmission fluid change.
(Contributed by Juma)
sunday transmission fluid change - the easy juma way
Towing
1.) Towing FAQ.
http://www.titantalk.com/forums/show...061#post279061
2.) Trailer light relay P/N and Installation.
(Contributed by KYdeepwater and Pagerdaddy)
Trailer Wiring
3.) 4X4 drop hitch drop length discussion.
4X4 drop hitch "drop" length????
Squid is offline   Reply With Quote
Old 03-20-2005, 05:08 PM   #2 (permalink)
BLWedge09's Avatar
Oil Pressure Guage
Question on oil guage
Oil pressure guage
BLWedge09 is offline   Reply With Quote
Old 03-20-2005, 05:32 PM   #3 (permalink)
Banned
Squid's Avatar
Originally Posted by BLWedge09
Thanks, added it to the list.
Old 03-20-2005, 08:32 PM   #4 (permalink)
HavockWK's Avatar
Popping sound opening/closing door
TT member and fellow PRG installer VShortt helped me out with this one last night. When opening/closing the door I would hear 2 pops and thought it was a lube problem on the positive stop guide. VShortt pointed out that the problem is that the screw holding the guide to the body. My other fellow PRG installer MOTO-MAX-TITAN (aka 2 second Max) quickly busted out with the 10mm socket and tightened the bolt on all 4 doors and solved my problem! It really helps to know people!
Here's the culprit bolt:
Old 03-20-2005, 09:33 PM   #5 (permalink)
37L1's Avatar
This thread deserves a sticky, so as it is written so shall it be done.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 03-20-2005, 09:54 PM   #6 (permalink)
Banned
tortuga's Avatar
thanks squid, i am one of those with the bad memory problem...
tortuga is offline   Reply With Quote
Old 03-21-2005, 02:08 AM   #7 (permalink)
Banned
Squid's Avatar
All right brothers and sisters this what I've got done so far. Suggestions are welcome and help would be appreciated. I want this to be as complete and user friendly as possible.
Happy monday to you all. I'll be sleeping and you'll be hard at work? Wait a minute if you're reading this you're screwing off. Get back to work!
Oh yeah, thanks havock.
Old 03-21-2005, 04:17 AM   #8 (permalink)
TriKKy's Avatar
Ground wire fix? Dunno if that is what your post is for the ticks/rattles, it's a busted link :-P
1.
Old 03-21-2005, 08:05 AM   #9 (permalink)
terryu1's Avatar
Whiner mute??
'04 Titan LE Crew Cab - Born on 4/30/04
terryu1 is offline   Reply With Quote
Old 03-21-2005, 11:41 AM   #10 (permalink)
Banned
Squid's Avatar
Thanks , Got it fixed.
Old 03-21-2005, 03:58 PM   #11 (permalink)
Banned
Squid's Avatar
Little Help?
I know that there has to be more out there but I can't think of them.
Anyone have any Ideas?
By the way, thanks 37L1 for the sticky.
Old 03-21-2005, 04:15 PM   #12 (permalink)
beach-bum's Avatar
thanks squid my hat's off to you.....
KC LE 2WD
deep water
born: 5/31/04 2:00 p.m.
So Cal beach bum
beach-bum is offline   Reply With Quote
Old 03-21-2005, 05:38 PM   #13 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Lighting:
Cure for accidentally turning off headlights 63¢
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow and E-loc Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Hellwig Anti-Sway Bar, PRG: Bilstein 5100 shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Bilstein Front Shocks, In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod., NISSAN I-POD adapter, Bosch Icon blades.
6 x 10' low bed/rails trailer with E-brakes.
108 year old rebuilt 4,000 lb. road roller/packer.
Amsoil Testing: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Series 2000 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter
60 MPH/20.50 MPG ***New Record-23.01 MPG***
"We have the Capability &Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 03-22-2005, 11:59 AM   #14 (permalink)
Banned
Squid's Avatar
Originally Posted by honeykeeper
Lighting:
You're on the list.
Old 03-22-2005, 03:12 PM   #15 (permalink)
Great thread Squid.
What about “thud sound when stopping & accelerating”?
Check the rubber floor protectors covering the utility track. They can slam up against the cab when stopping quickly & or slam against the tailgate under heavy acceleration.
Seems like I have seen 4 threads on this & can’t find-a-one.
KC/LE 4x2
Galaxy Black/Titanium
No-Tow/No-Offroad
G.Banks&Trux.cover
PRG. 2.5"F 1"R.
305/55/20 Nitto's TG
20x9MB Motoring Razor's Chrome
Optimist is offline   Reply With Quote
