Old 05-27-2008, 11:36 AM   #31 (permalink)
07cajuntitan's Avatar
Re: Front Axle Failer Thread
Just to make sure I'm not setting myself up for problems in the future...are there plenty of guys out there with a 2" leveling kit and a bunch of miles that HAVE NOT had a front axle failure? I only have 9000 miles on my truck, and I bought the extended warranty out to 75000 miles. I don't want to screw up the truck and have the dealership deny the repairs b/c of the spacers. Thanks.
2007 Titan SE KC 4x4 Granite --- Geaux Tigers!!!
07cajuntitan is offline   Reply With Quote
Old 05-27-2008, 04:03 PM   #32 (permalink)
5:00 bump for the guys with 4x4's. Please see my post from lunch. Thanks.
Old 11-22-2008, 06:50 PM   #33 (permalink)
The front driverside axle pulled out of my 04 with a 2" level kit. I have had the kit in for about a year and this is the first problem. While researching this problem I came across some manual locking hubs.
http://www.autopartswarehouse.com/
I would like to try this part as it might be easier on the front driveline when driving in 2wd. I just don't know the number of splines on the front axle of my truck (28 or 31)? I anyone has tried this product or knows how many splines our trucks have on the front axles, some feedback would be greatly apprecited.
Jedbar is offline   Reply With Quote
Old 11-22-2008, 08:43 PM   #34 (permalink)
Smoke05's Avatar
Auto Parts Warehouse | Car Parts, Truck Parts & Auto Body Parts Online - Free Shipping on most Auto Accessories & Performance Parts - AutoPartsWarehouse
They do not make manual hubs for the Titan as far as I have seen. If they did, like they do for the Ram, they would more than likely be cost prohibitive. IIRC they were around $1,500-2,000 for little to no gain on mpg.
Smoke05 is offline   Reply With Quote
Old 11-22-2008, 09:31 PM   #35 (permalink)
"2004-2007 Nissan Titan - Rugged Ridge Locking Hub
Part Number: 15001.45Description:"RUGGED RIDGE LOCKING HUB SET, FOR 31 SPLINE AXLE -- High Quality Locking Hub Set For 31 Spline Axle, Constructed Of Military Spec Hardened Nylon Center Dial That Will Not Damage Other Parts In An Unlikely Event Of Failure, Salt-Spray Tested Epoxy Enamel Finish, Die Cast Aluminum Cap With A Corrosion Resistant Glossy Finish, Internal Components Are Precision Machined And Heat Treated, Provides Better Fuel Economy Due To The Lesser Drag On The Engine, More Mileage For The Front Tires Since They Will Rotate Freely And A More Comfortable Ride Due To The Lighter Steering, Reduction Of Drive Train Noise And Minimal Vibration, Also Provides Better 4Wd Performance When The Hubs Are Locked" Our Price: $152.07"
This is the ad that I found, is it bogus? I can't get the link to work but you can check it out yourself at Auto Parts Warehouse | Car Parts, Truck Parts & Auto Body Parts Online - Free Shipping on most Auto Accessories & Performance Parts - AutoPartsWarehouse and search for your Titan.
Old 11-23-2008, 04:11 AM   #36 (permalink)
My front axle/diff failed in my 04 about 2 years ago. It has the 2" kit on it, and I can tell you that the kit did not cause it but it did make a poor axle design worse. My axles only popped out in 4-lo, and if I hit a dry spot while turning. Luckily they where easy to put in with the end of a shovel handle. After the whole run around with new axles, new clips, and seals the dealer finnaly replaced the front diff. I have had no other problems since and it still has the leveling kit.
rwhite is offline   Reply With Quote
Old 11-25-2008, 05:27 PM   #37 (permalink)
Smoke05's Avatar
That comment in particular makes me question the need and/or qulaity of these items. Locked is locked my friend. I am also not grasping how plastic can protect items in the unlikely event of failure.
Old 11-25-2008, 07:14 PM   #38 (permalink)
They list 28 spline and 31 spline manual locking hubs as fitting the same model Titans.
Old 12-05-2008, 04:49 PM   #39 (permalink)
I got a puddle under mine, drove it two days ago in 4hi because of snow. It is the front leaking right in the middle, taking it in to get fixed/looked at tomorrow. I bought mine used as a certified vehicle with the 84month 100,000 mile drive chain warranty, it is a 2005 with 51,000 miles so I am not real worried.
erickktm is offline   Reply With Quote
Old 12-06-2008, 07:08 PM   #40 (permalink)
If you have spacers, and the dealership denies coverage due to that, please let us know.
Old 12-06-2008, 10:51 PM   #41 (permalink)
All stock suspension, it does have new tires, but they are smaller than factory 265 vs a 285 and a brush guard.
Old 12-08-2008, 08:27 PM   #42 (permalink)
Yep, its done driver side axel and differential ordered, will be replaced when they get it in stock. Just said they are covering it all and they have done several already.
Old 01-04-2009, 06:00 PM   #43 (permalink)
PRJ
Originally Posted by PRJ View Post
So does anyone know if the NHTSA has done anything about these front and rear axle failures in addition to doors that are freezing and won't close?
Or are we all just pissing into the wind?
Maybe a lawyer and class action might be a better alternative?
I've had the rear axle replaced on my truck already and at 65,000 miles I now wonder if the front will be next someday.
I jinxed myself. 77,000 and mine is now toast.
Awesome
PRJ is offline   Reply With Quote
Old 01-07-2009, 02:30 PM   #44 (permalink)
You can probably add me to the list...are there any tutorials on how to go about fixing this yourself and what parts are needed? Would rather not go the $1700 repair route.
n o o d l z is offline   Reply With Quote
Old 01-07-2009, 05:31 PM   #45 (permalink)
Front Axle/Suspension Problems... Juday Titan Suspension 10 12-02-2007 11:35 AM
Leaking front axle at flange? rsaylor2682 Titan Problems & Dealer Service 1 10-28-2007 09:13 PM
Power Steering Pump Failer flynbrian Titan Problems & Dealer Service 2 04-16-2007 07:49 PM
PRG leveling kit and Front axle strain rwhite Titan Engine, Transmission & Drivetrain 5 01-26-2007 02:39 PM
4X4 Front Axle Check Please. Squid Titan Engine, Transmission & Drivetrain 4 03-20-2005 03:45 PM
