Old 01-08-2009, 05:21 AM   #46 (permalink)
TJ Kretschmar's Avatar
Re: Front Axle Failer Thread
In July, a dealer in Bellevue, NE replaced my front diff under warranty. I have a 6" lift, so if you are under warrenty it shouldn't even be an issue (please note the "No Fear" Titan has a 6" lift. Last month I smoked it again and decided I didn't want to deal with the dealership's crap anymore, so I pick one up at the junk yard for $591 (after taxes) and installed it in about 3 hours by myself. The front diff in these trucks are garbage!
She's BIG,
6" Pro Comp Stage 1, Radflo 2.5 Coils, Modified Reservoir Brackets, 2.5" Deaver Mini Pack, Bilstien Rear Shocks, 3" Pro Comp Aluminum Block, Buckstop Bumper, Modified Factory Skid Plate, 150 Watt KC Hilites, AmSoil Air Filter, Retrax Tonneau Cover, Northern Tool Toolbox, 315X70R17 Mickey Thompson MTZ, 17X9 **** Cepek Black DC-1, Bushwacker Flares
TJ Kretschmar is offline   Reply With Quote
Old 01-08-2009, 07:12 AM   #47 (permalink)
PRJ
So does anyone know if the so called replacement is any better or if an aftermarket one is available somewhere?
PRJ is offline   Reply With Quote
Old 01-08-2009, 08:18 AM   #48 (permalink)
How hard is it to replace on your own? What tools are needed out of the ordinary?
n o o d l z is offline   Reply With Quote
Old 01-08-2009, 10:50 AM   #49 (permalink)
I have a bracket lift, so it might be easier than a none lifted truck...not sure. All you have to do is unbolt the upper cv joints from the carrier (12 bolts, easier to do with the front tires off the ground), then the 3 bolts holding the carrier in, and finally the drive shaft (might want to check the u-joints while you are at it, they should not have any play in them). Normal hand tools and a couple of jacks will get the job done. I used an impact to remove the CV bolts (I don't recommend an impact to put them back it, I had one of them snap off on me).
She's BIG,
Old 01-08-2009, 10:52 AM   #50 (permalink)
To my knowledge, Nissan has not redesigned the front diff, just the rear. No aftermarket either. SAS is the only option when upgrading.
She's BIG,
Old 01-10-2009, 01:46 AM   #51 (permalink)
07titanowner's Avatar
i am hearing a similar noise in my 07 titan, i am also getting a grinding when i apply the brakes especialy when i first start the vehicle could this have something to do with the differential or do i have a different problem?
07titanowner is offline   Reply With Quote
Old 01-11-2009, 04:38 PM   #52 (permalink)
Ive tried to read through here and I didn't see any 08's. Is there anyone out there that has an 08 with a lift ( what kind) that has experienced this problem..
GAtitan67 is offline   Reply With Quote
Old 01-14-2009, 04:24 PM   #53 (permalink)
LouieIV's Avatar
Unhappy Re: Front Axle Failer Thread
Just had my front diff replaced. It was covered under warranty. Service guy said it was somewhat common. Concerned about the longevity of this truck now. I don't want to have to replace the front diff every 3 or 4 years.
-LouieIV
2005 Red Alert Titan
4x4 OR pkg
LEER 100R Shell
Wet Okole Seat Covers
PRG Mini Lift
Cooper Discoverer STT LT295/70R17
LouieIV is offline   Reply With Quote
Old 01-15-2009, 06:09 PM   #54 (permalink)
mine just popped a axle out. Pulling apart tomorrow to check for gear carnage.
Your Complaint Information is successfully submitted.
Your Confirmation number (ODI Number) is: XXXXXXXX
04 Titan Crewcab LE 4x4
JamesN1830 is offline   Reply With Quote
Old 01-16-2009, 09:28 AM   #55 (permalink)
Would it be too much to ask to take a few pictures of the process? I just want to get an idea of what I'd take before deciding whether to suck it up and take it to the dealer.
Old 01-16-2009, 10:16 AM   #56 (permalink)
too late! My mechanic had it fixed in a couple hours.
Put in a new clip and serviced the diff plus a oil change.
Total cost $125
The clip is $4 and it needed 6 ish quarts of diff fluid he said.
Old 01-16-2009, 11:01 AM   #57 (permalink)
Here is a whole thread it. Broke Front Diff...Weak Link - Nissan Titan Forum: Club Titan Forums
She's BIG,
Old 01-16-2009, 01:12 PM   #58 (permalink)
PRJ
Total cost $125
Keep in mind the clip is only a band aid. Nissan redesigned the whole front differential, so it will happen again. It's just a matter of when.
Old 01-16-2009, 02:01 PM   #59 (permalink)
noted.
If it happens again this yr, then the truck will be forsale. A new diff and labor is simply not worth it on a fast depreciating truck that is JUST out of warranty.
Old 01-16-2009, 02:57 PM   #60 (permalink)
dd_dailydriver's Avatar
I think I'll bandaid mine too. 60.1k miles is not very fair of a time for a failure that costs this much. But hey its for sale now, anyone interested?
SOLD - '05 KC 4x4 Off-Road BT - Deep Water Blue - 63k
dd_dailydriver is offline   Reply With Quote
Front Axle/Suspension Problems... Juday Titan Suspension 10 12-02-2007 11:35 AM
Leaking front axle at flange? rsaylor2682 Titan Problems & Dealer Service 1 10-28-2007 09:13 PM
Power Steering Pump Failer flynbrian Titan Problems & Dealer Service 2 04-16-2007 07:49 PM
PRG leveling kit and Front axle strain rwhite Titan Engine, Transmission & Drivetrain 5 01-26-2007 02:39 PM
4X4 Front Axle Check Please. Squid Titan Engine, Transmission & Drivetrain 4 03-20-2005 03:45 PM
