Front differential oil leak - Nissan Titan Forum
post #1 of 4 (permalink) Old 02-17-2008, 02:25 PM Thread Starter
TecheTitan's Avatar
iTrader Score: 1 reviews
Cool Front differential oil leak
While under my Titan yesterday installing my JBA cat-back I noticed that there was an oil leak on my front differential where the drive shaft goes in from the T-case. Bummer!!! It is obvious that there is oil on the crossmember and was a drip on the differential itself. It looks like a bad seal, and I have never noticed any oil in the driveway where I park her. The good news is that my truck is still under warranty, so it looks like a trip to the dealer is coming soon.
I only have 24,000 miles and only put the truck in 4 wheel drive on occasions when necessary and don't abuse it. So, just a heads up to everyone else here who has a 4X4 Titan. You may want to check your front diff.
Has anyone else here had this problem?
06 Smoke SE CC 4X4
Bug Shield, in channel vent visors, 22% front window tint, Pro Comp stage1 w/ SAW coilovers and 2" rear block w/ 35x12.5x18 Toyo Open country MT on 18X9 KMC Monsters, JBA cat-back, 2* advance, AEM intake, BD Power Pup
TecheTitan is offline
Advertisement
post #2 of 4 (permalink) Old 02-17-2008, 02:39 PM
pedalhappy1053's Avatar
iTrader Score: 0 reviews
Send a message via MSN to pedalhappy1053
Re: Front differential oil leak
Ive gone through 2 front diffs already.......it sucks
NEXT MOD: UPREV And Trutrac
Performance: K&N FIPK Intake, Throttle Body Spacer, BANKS exhaust
Suspension: 6" Pro Comp Lift, SAW Coilovers with PRG Upper Control Arms, Ionic Dynamics front fenders
Audio: Alpine CDA-9887 Deck, 2 Planet Audio BB212D sub woofers, 2 Memphis Audio 15-MCS69 speakers, Hiphonics BXi2006D Amp, EFX Hyperdrive HD4300 Amp
"Girls love my truck"
My sub woofers move more air than your turbo
pedalhappy1053 is offline
post #3 of 4 (permalink) Old 02-25-2008, 04:59 PM
bobo993's Avatar
Mine's leaking where the drain plug screws in. This has been a problem off and on for 4 mos. Dealer checked 4 mos ago and said they fixed the leak. Now I noticed its leaking again. I checked the level and it looks low. Anyone know what the proper fluid level should be?
05 BT: OR: CC: Bed package: Front Bench
01 Ebbtide campione 182 w/v6 volvo
bobo993 is offline
post #4 of 4 (permalink) Old 03-16-2008, 09:38 AM
I had noticed a couple oil spots on my garage floor so mentioned it when I went in for 30k service. Turned out it was the front diff input seal leaking. Service also noticed the right rear axle seal starting to leak. Service changed both under warretry, had a loaner Sentra for the night. Can't complain about the service but don't think the seals should have gone bad.
04 KC OR BT
AMCS is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Front differential 4 wheel drive actuator leak royr Titan Engine, Transmission & Drivetrain 0 07-12-2007 02:04 PM
HELP NOW! Front diff leak at c.v. - truck at stealership Wallrat Titan Problems & Dealer Service 6 12-12-2006 06:20 PM
Front Differential leak corrupt05 Titan Problems & Dealer Service 4 11-26-2006 01:26 PM
Front differential seal leak chepdog Titan Engine, Transmission & Drivetrain 0 05-07-2006 09:45 PM
Front Axel seal leak TitanVT Titan Problems & Dealer Service 13 05-06-2005 05:08 AM
You may post new threads
You may post replies
