Go Back   Nissan Titan Forums > Titan Discussion > Titan Problems & Dealer Service
User Name
Password
Transmission fluid drain vs. flush - being discussed at Nissan Titan Forums in the Titan Problems & Dealer Service section.
Old 02-22-2008, 04:36 AM   #1
Skiff Fisher
Skiff Fisher's Avatar
Question Transmission fluid drain vs. flush
Does any body have a handle on the real time frame to change transmission fliud? The manual indicates possibly around 30,000 miles, but the freaking fluid is almost $15 a quart. I'm at 79,000 and fluid still looks (smells) good. I do alot of towing (camper and boat), but don't want to waste money on something the truck doesn't need.
Also, is it OK to flush these transmissions or drained only??
Thanks....
Skiff Fisher is offline   Reply With Quote
Old 02-22-2008, 04:57 AM   #2
dc_909
dc_909's Avatar
Re: Transmission fluid drain vs. flush
If you're asking for our opinions, I am sure most of us, if not all, will tell you to fork up the bucks to get it done.
Seems you are a bit weary about it anyways, and how much do you value peace of mind?
Here is an analogy.
I own a 2006 Crf450, and I've used Motul 300v since break in.
Motul 300v is 57 bucks a gallon, and I change the oil every time i ride, the oil still looks primo, still smells primo, still has the thick texture, but i change it anyway, why? ( takes 2 quarts per change )
peace of mind.
call me paranoid or what not, but i didn't spend thousands to loose it over trivial preventive maintenance.
2008 Blizzard SE KC
Volant CAI-Magnaflow Catback-2/3 McGaughy's-22" AR 311's w/Kumho 305/45's - 2* T/A
next mod up : Detroit TT
dc_909 is offline   Reply With Quote
Old 02-22-2008, 06:17 AM   #3
TallTexan
TallTexan's Avatar
Since you are over the warranty mileage, you might want to look at MaxLife transmission fluid. It states it is reccomended for vehicles requiring Nissan J fluid. I did my first change with Nissan J because under warranty but my next will be MaxLife. MaxLife is about $3. 50 a quart. I sent a email to MaxLife to make sure their oil was compatible and the sent me a reply that said it was compatible with my Titan and there was no warranty issues. I noticed that maxLife is also compatible with most new trannies from Honda, Acura, Toyota and others. Do your own research but I will be using it next time. My truck has 74k now. MaxLife is made by Valvoline.
Robert Louis Stevenson
Old 02-22-2008, 06:55 AM   #4
Skiff Fisher
Thanks for the info. Every other vehicle I have had, as best I can remember, stated to drain every 60,000 to 70,000 miles. Guess I'm over due even at that rate. I'll check out the MaxLife. Thanks for the tip. I realize the whole ounce of prevention thing, but don't want to be wasteful just to pad a dealers wallet for a unnessary change.
Old 02-22-2008, 07:01 AM   #5
bestatchess
draining at the pan will change about 1/3 of the tranny fluid.
Old 02-22-2008, 07:53 AM   #6
TallTexan
TallTexan's Avatar
Remember, if you use MaxLife you must flush out the NissanJ so you do not mix. Just draining the pan will not work.
Old 02-22-2008, 10:04 AM   #7
Skiff Fisher
Thanks, will do.
Old 02-23-2008, 06:47 AM   #8
Clint
Clint's Avatar
If you drain and fill the pan at three motor oil changes you'd in effect be changing just about all the trans fluid. I did that on my truck starting at 51,000 miles for three motor oil changes and was done by 60,000 miles.
Clint
You have two choices in life:
Old 02-26-2008, 11:49 AM   #9
PRJ
Nissan does not recommend flushing.
A drain and re-fill as outlined in the service manual needs to be done.
See attached document and read this thread. Brown dude posted the correct procedure from the service manual.
http://www.titantalk.com/forums/tita...n+fluid+change
Dealer did it for me for $160
Someone should post this as a sticky.
PRJ is offline   Reply With Quote
Old 02-26-2008, 12:39 PM   #10
boya544
boya544's Avatar
Clint
That is what Royal Purple told me to do with their trans fluid that is J-matic compatible.Do a pan fluid change 3x 3k-5k apart. They said mixing the two would be ok since they are compatible.
_________________________________
05 CC 4x2 Red Alert
20" VCT Scarface Rims
Injen CAI
Volant Stainless Exhaust
2* Timing Adv.
boya544 is offline   Reply With Quote
User Name
Password
transmission fluid buckeye titan Titan General Discussion 16 10-17-2007 07:49 AM
Transmission Flush / Fluid Questions faith+1 Titan Engine, Transmission & Drivetrain 20 03-27-2007 02:29 PM
Transmission fluid heath22 Titan Engine, Transmission & Drivetrain 45 02-09-2007 04:16 PM
Transmission Flush KYDeepwater Titan Engine, Transmission & Drivetrain 9 12-30-2006 06:43 PM
How to drain tranny fluid on '05? GO_VOLS! Titan General Discussion 3 05-04-2005 02:05 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
