Squeaking in front end?? - Nissan Titan Forum
post #1 of 11 (permalink) Old 03-10-2008, 01:30 PM Thread Starter
husker1206's Avatar
iTrader Score: 2 reviews
Every time my front suspension moves, like going over uneven ground, it squeaks and it is getting annoying. Anybody else have this problem. Maybe I could just grease it, but I have no clue where it is comming from. Thanks for the comments in advance.
2005 CC LE 4x4: 2" leveling kit
35-12.50-18, Nitto Mud Grapplers
Volant CAI, Helix TBS, 2* Advance
Borla Dual Exhaust
husker1206 is offline
Advertisement
post #2 of 11 (permalink) Old 03-10-2008, 01:39 PM
Pops's Avatar
iTrader Score: 1 reviews
Re: Squeaking in front end??
It should just be the front Stabilizer Bar Bushings inside the U-Brackets next to the skid plate edges. I've had this issue with past trucks and will be pulling mine off soon to grease. If you eventually want new bushings, they're really cheap from the dealer.
Part 54613 on this diagram: http://www.courtesyparts.com/betasit...1147_1149.html
2005 Armada LE 4x4
Pops is offline
post #3 of 11 (permalink) Old 03-10-2008, 05:34 PM
Guiseppe's Avatar
iTrader Score: 0 reviews
I have a squeaking problem too, at first I thought it was the suspension. But, the other day I got out of my truck and I was in the frontof it when my son shut his door. I found out it is the chrome grill. I wish there was a way to tighten it or something, it's annoying.
Guiseppe is offline
post #4 of 11 (permalink) Old 03-11-2008, 10:54 PM Thread Starter
husker1206's Avatar
So just take them off and grease them or put new bushings in and that will fix it??
Borla Dual Exhaust
post #5 of 11 (permalink) Old 03-12-2008, 06:47 AM
Pops's Avatar
Yep. Clean it up with a scrub brush and use lots of grease, it's cheap. I'm also trying to find something to help cover the sides of those a little bit to help keep the grime out. I'm thinking when I remove my stabilizer bar that I'll shop hardware stores and so forth to see if anything will work as a cover for the bushing sides.
2005 Armada LE 4x4
Pops is offline
post #6 of 11 (permalink) Old 03-12-2008, 09:14 AM Thread Starter
husker1206's Avatar
By stabilizer bar you are refering to sway bar right?? If so, I dont have mine hooked up. I unbolted it at the links, but I guess it could still be moving around in there and making noise. I will just take it all the way out today and see if that fixes it.
Borla Dual Exhaust
post #7 of 11 (permalink) Old 03-12-2008, 09:23 AM
Pops's Avatar
Yep. Stabilizer, Anti-Sway, whatever... I think completely removing it might likely fix this for you.
2005 Armada LE 4x4
Pops is offline
post #8 of 11 (permalink) Old 03-12-2008, 04:46 PM Thread Starter
husker1206's Avatar
alright its gone now. I took the sway bar out. Thanks Pops
Borla Dual Exhaust
post #9 of 11 (permalink) Old 03-12-2008, 06:01 PM
Pops's Avatar
Nice!!!!!!!
2005 Armada LE 4x4
Pops is offline
post #10 of 11 (permalink) Old 03-12-2008, 08:44 PM Thread Starter
husker1206's Avatar
Well I take that back. It stopped for a little while, but now it is doing it again lol..any more sugestions??
Borla Dual Exhaust
post #11 of 11 (permalink) Old 03-12-2008, 09:01 PM
Pops's Avatar
One way of troubleshooting is to pop the hood, climb on top of the radiator and bounce on it to see if anything squeaks. You can also jack it up to move the parts by hand or with a pry bar to narrow it down.
There's all kinds of bushings in the suspension and also a thin rubber "pad" on the bottom of the coilover spring that dampens the spring from the bracket. You can use WD40 to spot spray different joints on the UCA, LCA, and Shock connections to see if and where spraying puts a permanent stop to it and that rubber piece coming dislodged has caused some some Armadas to squeak. Other things to check are Hood Hinges, Hood Latch, Billet Grille, and Bug Deflector. I know of one that a squeaking Hood Hinge sounded like it was coming from the suspension for some reason.
Climbing on the Nerf Bars or front end and Bouncy bounce jump jump are how I usually try to narrow them down then lift a little and drop with a floorjack a few times to narrow down further.
You could also use a car wash high pressure to spray all over the suspension inside the wheels wells and underneath really good to see if it's just some Winter Grime that can washout easily.
2005 Armada LE 4x4
Pops is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Bed is squeaking? PSNissanFleetMgr Titan General Discussion 4 02-23-2008 08:16 PM
Brakes still squeaking TopMyTitan Titan Wheels, Tires & Brakes 6 02-14-2007 05:12 PM
brake squeaking? titanmike Titan General Discussion 7 02-13-2007 10:49 PM
Brakes are squeaking jnoriega23 Titan Problems & Dealer Service 1 10-06-2005 12:04 PM
HELP! Chassis Squeaking titancrazy Titan General Discussion 10 07-26-2005 10:42 PM
You may post new threads
You may post replies
