Old 01-28-2008, 09:02 AM   #1 (permalink)
Vibration at stop lights??
I have been noticing a vibration in my truck whenever I'm stopped but in drive. I thought it may be my exaust but I tightened all the bolts and it still making the noise. Again it only happens when I'm at lights or stopped but not it park. Any ideas?
Jeff
2005 LE Crew Cab Nissan Titan
Performance Mods include: 22" Forte rims, K&N Stage II FPK, 2' timing advance, JBA Evo Exhaust
Audio upgrades: 2 12" P3's in a Tech22Volt enclosure being pushed by a Sundown 1000D
Titan22inch is offline   Reply With Quote
Old 01-28-2008, 09:08 AM   #2 (permalink)
37L1's Avatar
Re: Vibration at stop lights??
Could be a lot of things, rough idle? What RPM's do you idle at?
Clean your MAF and check all throttlebody/air box connections. Air filter new or clean?
At least there's some place to start, short of taking it to the service tech.
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 01-28-2008, 09:21 AM   #3 (permalink)
I just changed the oil and cleaned the k&n cold air intake. My wife drives it during the week, so I won't know until this weekend if it helped any. I'll have to get back to you on the rpm at idle.
Jeff
Old 01-28-2008, 10:56 AM   #4 (permalink)
37L1's Avatar
Is it a vibrating noise, like a rattle?
If so where is the area it's coming from? Inside or outside? A little more information and others could help if they knew better what your problem is.
Born 11/18/03
-Gambit
Old 03-07-2008, 07:31 PM   #5 (permalink)
Wiscdave's Avatar
i get the same thing...today it was really bad I'll be investigating this week as I'm in the middle of a 1200 mile drive. very scary. If I put it in neutral or park it stops, drop it in drive andhold the brake I get the noise. WTF
old ride - 04 XE CC 4x4 traded at 62k
Wiscdave is offline   Reply With Quote
Old 03-07-2008, 07:48 PM   #6 (permalink)
cp.16's Avatar
Check to see if anything on the K&N cold air intake may have loosen up. I heard a rattle over bumps and found the filter was loose.
cp.16 is offline   Reply With Quote
Old 03-31-2008, 10:01 AM   #7 (permalink)
I just came back from the dealership with the exact same problem. At idle in neutral or park the truck wouldn't make any vibration under the hood...Just shifted to Drive or mostly reverse, and that vibration would come up...I would even feel it on the dashboard and mostly with the windows up. Well......to my surprise, it was the bulb box of my subwoofer that was loose and making contact with the left pannel, they just attached it to a cable with a plastic staple, and no more noise!. So yeah, check for any loose pieces, I checked EVERYTHING to see where the vibration was coming from, and never imagined something so small would actually make a lot of vibration. titans' cabins are very quiet, and any little noise under the hood will magnify with windows closed.
Anyway!, hope this helps..and I'm sure it will be something like mine had.
nismo8228 is offline   Reply With Quote
Stop Truck Stop!! jasonmotox Off-Topic Discussion 16 04-17-2007 07:14 PM
Somebody stop me. SKEET Titan General Discussion 16 09-26-2006 05:23 PM
Cant stop here D_C Titan Suspension 1 02-15-2005 12:52 PM
