Go Back   Nissan Titan Forums > Titan Discussion > Titan Problems & Dealer Service
User Name
Password
Slight vibration when in gear, any help? - being discussed at Nissan Titan Forums in the Titan Problems & Dealer Service section.
Old 04-25-2008, 01:54 PM   #1
cusco
I recently purchased a 2006 Titan with 10,000 miles I have noticed that when I put the truck in drive there is a slight vibration you can feel through the floor on your feet and if you put your hand on the dash. It goes away in park or neutral. When driving it is there but goes away when you let off the accelerator. I was wondering if this was normal, if anyone else had noticed it or had any ideas what I should check? My 2003 ford felt similar when 4WD was engaged. The Titan is definately in 2WD as it has a totally differnet feel in 4WD. Thanks
cusco is offline   Reply With Quote
Old 04-25-2008, 02:28 PM   #2
billwitte
billwitte's Avatar
Re: Slight vibration when in gear, any help?
Remove from gear... Sorry, could not resist.
08.5 SE CC LB TP
99 Max cattman Ypipe, hijacked w/K&N
65 Karman Ghia vert (body-off Resto)
1 BIG Tibetan Mastiff
billwitte is offline   Reply With Quote
User Name
Password
Another AEM with a slight modification FedXr Titan Performance Modifications 17 03-24-2008 09:45 AM
4th Gear or 5th Gear for a Light Trailer? ten~39 Titan Towing & Hauling 11 02-20-2008 05:08 AM
Have a slight thump. SKEET Titan General Discussion 1 09-10-2006 07:57 PM
Slight noise when in 4x4 kbaeta Titan General Discussion 20 03-29-2005 10:46 AM
slight problem pkramjr Titan General Discussion 1 05-03-2004 06:35 AM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
