Old 04-27-2008, 10:34 PM   #1 (permalink)
RyBo's Avatar
Send a message via AIM to RyBo
Fuel Gauge Only registers to 1/4 Tank??? Help?
Hey guys,
Well I've just found out that my truck has a unique problem...apparently, my fuel gauge doesn't like to tell me that I'm running out of fuel. It fills up fine, registers all the way down to 1/4 tank then just happens to stay there...and because of that, I've run out of gas twice now, no warning light no nothing, and when i shut off my truck the needle does go down past E showing that the gauge cluster itself seems to be fine....So, after taking it to my dealer they said that the most likely cause was that it was a loose ground wire their mechanic came across...That was fixed free of charge, but has had no effect and my gauge is still only going to 1/4. I've searched around a few forums and have found no other problem like mine, so I thought I'd finally write a thread and ask if any of you awesome members might have any idea whats going on? Much appreciated guys and gals!
Thanks.
Ryan C.
RyBo is offline   Reply With Quote
Old 04-27-2008, 11:10 PM   #2 (permalink)
SOCALTITANKC4X4LE's Avatar
Re: Fuel Gauge Only registers to 1/4 Tank??? Help?
It seems to me that it's probably the sending unit. Others including myself have had defective sending units.
2005 Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b][color="Blue"]BLUE LED DASH LIGHTS MOD
1997 PATHFINDER w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads [b][color="Red"]487,000 miles and I'm hoping to get 500,000.
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 04-28-2008, 08:22 PM   #3 (permalink)
Send a message via AIM to Jared
I agree, most likely the sending unit. I have seen issues in other places like wiring connectors, etc.. but misreading is always the sender.
MY06 Smoke Titan SE CC 4x4 Tow
Nismo Cold Air, Banks Monster, Nismo Headers,
2.5" leveler
ASE Master Technician
Nissan Master Technician
AEM Trained
Jared is offline   Reply With Quote
Old 04-28-2008, 09:02 PM   #4 (permalink)
VA06TITAN's Avatar
Fuel sending unit needs to be replaced. I had the same problem last summer. Took it to the dealer, and they replaced the unit ... No problems since.
AMSOIL Independent Dealer
Email: cwsynthetics@msn.com
Web: www.lubedealer.com/cwsynthetics
VA06TITAN is offline   Reply With Quote
28 gallon fuel tank v8nissans Titan General Discussion 17 01-22-2007 04:31 PM
fuel gauge reading about qaurter tank low after filling up 24gal. titaninak Titan General Discussion 35 12-05-2006 02:15 AM
Fuel tank Fredman5555 Titan Problems & Dealer Service 11 03-07-2006 10:29 PM
auxilary fuel tank juma Titan General Discussion 7 09-04-2005 12:03 PM
Fuel Tank Range Yeti Titan General Discussion 5 01-25-2004 12:10 PM
