Old 04-30-2008, 04:10 PM   #1 (permalink)
305hp's Avatar
EVAP Vent Control S/V
Anyone have a picture of this or know how to replace it?
305hp-
Banks Monster Exhaust, AEM Brute Force CAI,Window Tint, Access Cover, Billet Grille, PRG Mini-Lift, BFG T/A KO.
Also, 2005 Volvo S60R
"If you don't know where you're going...Any road will take ya there."
305hp is offline   Reply With Quote
Old 04-30-2008, 10:25 PM   #2 (permalink)
James Con's Avatar
Re: EVAP Vent Control S/V
Look at this TSB. Go to step three, do you see the little round canister( filter)
The bottom hose coming out of the canister goes to the evap solonoid valve. Disconnect the hose coming from the filter then turn the valve about a 1/4 turn then pull it out. There is an o-ring sealing the valve to the evap box, make sure that comes out with the valve. If the new valve does't come with the o-ring get that too. It should be replaced with the valve.http://www.clubtitan.org/forums/atta...4&d=1189618447
You don't say what year your truck is, If it doesn't have the filter you should install that too. Just perform the whole TSB.
AEM CAI, 18" Magnaflow
James Con is offline   Reply With Quote
Old 05-04-2008, 10:18 AM   #3 (permalink)
Hi I have a 2005 Titan LE. I brought it to the dealer and they ran diagnostics and come to find out my Evap/vent control valve (the word charcoal was thrown in there) needs to be replaced for est $410.00. The dealer stated they went thru a few "goodwill requests" with Nissan to replace it for free since I'm out of the 3yr/36k warranty. I have 22k miles. That process took about a month to get a response. Did they really try and contact Nissan? Anyone else familiar with this process?
2005titanle is offline   Reply With Quote
Old 05-04-2008, 03:16 PM   #4 (permalink)
baseballfanz's Avatar
You should still be under warranty at 22K miles
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 05-04-2008, 03:50 PM   #5 (permalink)
What are the symptons?
Mrhavasu is offline   Reply With Quote
Old 05-04-2008, 08:30 PM   #6 (permalink)
James Con's Avatar
Sounds like his bumper to bumper warranty is up due to years not mileage. He must have bought it early 05. Correct me if I'm wrong but some states cover warranty on emissions for a longer duration, And that would be an emissions issue. I think it says it in the warranty manual. When I had my evap solonoid valve changed I had approx. 55,000 miles, It was covered under the extended warranty.
Old 05-04-2008, 08:39 PM   #7 (permalink)
James Con's Avatar
I would bring that TSB to the dealer and remind them in a nice way that there is an ongoing problem with these valves that don't have the filter attached to them. Technically they still can charge you for the TSB work, The TSB's are just info for the mechanics to help them troubleshoot common problems. It's possible they don't know about this TSB. My dealer didn't know till I showed them the copy I got from BBfanz.
Old 05-04-2008, 08:46 PM   #8 (permalink)
James Con's Avatar
Check engine light, Also when putting gas in, it doesn't vent properly so the pump keeps shutting off thinking it is full. Check the Tsb it will tell you the codes that are thrown when the valve is not working properly.
Old 05-07-2008, 05:56 PM   #9 (permalink)
TitanTech659's Avatar
The EVAP canister vent control valve is located on the EVAP canister and is used to seal the canister vent.
This solenoid valve responds to signals from the ECM. When the ECM sends an ON signal, the coil in the solenoid valve is energized. A plunger will then move to seal the canister vent. The ability to seal the vent is necessary for the on board diagnosis of other evaporative emission control system components.
This solenoid valve is used only for diagnosis, and usually remains opened.
When the vent is closed, under normal purge conditions, the evaporative emission control system is depressurized and allows "EVAP Control System" diagnosis.
TitanTech659 is offline   Reply With Quote
Old 05-07-2008, 06:05 PM   #10 (permalink)
Evap Leak FLYTECH Titan Problems & Dealer Service 1 12-23-2007 02:59 PM
EVAP - Control Valve SES code P0455 phlydude Titan General Discussion 3 10-18-2005 06:20 PM
EVAP cannister problem TitanVol Titan Problems & Dealer Service 1 03-03-2005 10:29 AM
Evap volume control knocking. Huey130 Titan Problems & Dealer Service 33 01-03-2005 06:04 PM
Vent/defrost/air flow control knob rockwalltitan Titan General Discussion 7 12-19-2004 06:39 AM
