Old 05-03-2008, 09:40 PM   #16 (permalink)
Pops's Avatar
Re: Fix for air pressure sensors??????
Considering you've got people on here running on 35psi and those are great tires to give room for more psi, you could air them to what you're comfortable and change it as you see fit. The centerline treadwear is the biggest indicator of improper psi. You can also check with some 4x4 shops to compare notes with since those guys are always running oversized tires.
Old 05-04-2008, 07:33 AM   #17 (permalink)
Like he said, try it and see what you think... I made the same mistake at first because I was used to filling up to just a litle under the max psi and when I put the winter set on in like october last year I filled them up to about 60-65. I started noticing though that the tires were only making contact down the center and you could see that the sides of the tires were not wearing at all so thats when I started making phone calls to see what the shops run them at. I've been running 35 ever since. Cheers!
FS: Set of four pressure sensors jd1973 Buy/Sell 5 12-21-2005 01:45 PM
air pressure sensors khaynes Titan Wheels, Tires & Brakes 1 10-22-2005 04:49 PM
Pressure Sensors airrick Titan Pictures & Media Post 28 10-11-2005 01:32 PM
Does the 04 XE have Pressure Sensors? dig_doug_l Titan General Discussion 4 08-29-2005 06:15 PM
FS: Set of Four Tire Pressure Sensors. RockyMtnTitan Buy/Sell 3 04-11-2005 05:58 PM
