Old 06-05-2008, 11:19 PM   #16 (permalink)
pahinui31's Avatar
Re: clunk in front when hitting bumps
my 08 does this also and i'm pretty sure it's the uca hitt'n the coilbucket. i'm planning to get PRGs uppers and SAW coilovers to correct the clunk.i have no lift at this time..
pahinui31 is offline   Reply With Quote
Old 06-06-2008, 09:23 AM   #17 (permalink)
Clancy's Avatar
Mine does it - has since I put the leveling kit on it.
The fix is simple and well known. It's called a grinder. Grind a relief in the coil bucket - it's not structural (as long as you don't get too carried away)...
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Old 06-06-2008, 09:45 AM   #18 (permalink)
54warrior's Avatar
Originally Posted by AnonymousGuy
So, it typically only happens when someone mods their truck, but yet is still a "poor Nissan design"?
Hmm, then why all the owners with STOCK trucks chiming in with problems
I've seen you write this a few times, and each time you write it you're as wrong as the time before. To claim that the shock is "destroying itself" by topping out is just silly and almost libelous. The shock is the limiting factor for suspension stroke on our trucks, thus it's designed to top out. That's why our shocks have stoppers in them that are separate from the valve assemblies. Ask Greg, I'm sure he's cut a few open in his time.
Yes, I'd say he has: http://www.titantalk.com/forums/739858-post6.html
also:
Originally Posted by PrerunnerGreg
On the 08's you need to grind a little bit on the drivers side coil bucket. It seems as though Nissan has the frames built on a new jig and there is a small clearance issue now (the coilbuket is welded a bit higher on the frame now).
Do you have any data, anecdotal or otherwise, to demonstrate causality between top-out and the shock "destroys itself"? If not, I'd seriously consider not implying a truth where one cannot be proven.
See my comments in red. What crawled up your ***?
Old 06-06-2008, 10:04 AM   #19 (permalink)
Bhudda454's Avatar
Send a message via Yahoo to Bhudda454
Content, not postcount, my friend. Been lurking here for years.
Some line of thought would be you need to read more and continue to post less. You are dipping into an area which you seem to have no personal experience. I have had TWO Titans. one 2wd and one 4wd. Both have had this issue. The 2wd stayed stock, and the 4wd has the level only. UCA bucket wearing a hole in itself do to striking the coil bucket is Piss Poor Design and a very well know issue. Not Operator error. Simple fix has been to either grind away safely, or replace crappy stock shocks with a quality name brand.
Implying that the replacement shocks are "higher quality" is a fallacy. People replace the shocks with units that have different characteristics and configurations than the stock units, and the noise stops. Doesn't mean that the replacement units are of higher quality, just means that they're different.
Everyone say hello to the 800 Nissan Customer Support guy.
This is more crap from the fountain jr. POST LESS READ MORE... Try back in a year.
2008 Crew Cab SE Long bed 4x4
Timberline Green Exterior
Almond Interior
Mod's: LiquidMetal Wingman wheels, Parada Spec-X tires, N-Fab 6-step Nerfbars, Sliding OEM Toolbox, AVS Vent visors, Tint, CUSTOM One-Off JesHand Creations Front Stealth Bumper, Tailgate bib Cover, color matched steering wheel wrap, Chrome swap on mirrors and door handles, PRG 1.3" Level kit
Yeah, She's the Biggest One
General James Mattis, USMC to Iraqi tribal leaders.
"Allies or enemies. You make the call. I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you Faq with me, I'll kill you all."
Bhudda454 is offline   Reply With Quote
Front End Noise Clunk On Small Bumps xavier Titan Suspension 8 07-04-2007 07:43 PM
Front End Noise Clunk On Small Bumps xavier Titan Suspension 1 04-18-2007 08:44 AM
under cab floor board clunk when going over speed bumps, etc. RobTitan Titan Problems & Dealer Service 18 01-04-2007 08:02 AM
Front end clunk Blue_Water_Rush Titan General Discussion 2 12-31-2005 09:43 AM
Knock /clunk.... Right Front import2nr Titan Problems & Dealer Service 0 12-04-2004 01:36 PM
