Go Back   Nissan Titan Forums > Titan Discussion > Titan Problems & Dealer Service
User Name
Password
VDC/Slip/4WD - being discussed at Nissan Titan Forums in the Titan Problems & Dealer Service section.
Old 05-07-2008, 06:43 PM   #1
jarknow
VDC/Slip/4WD
I have a 2004 Titan LE Crew cab. The VDC/Slip/4WD lights came on and were no longer functioning. The dealer indicated it was a speed sensor in the front wheel and was replaced under warranty - since then it has happened two more times and they are now indicating it's the speed sensors in the rear wheels which are NOT under warranty. HELP...
jarknow is offline   Reply With Quote
Old 05-07-2008, 06:49 PM   #2
Jared
Send a message via AIM to Jared
Re: VDC/Slip/4WD
It could be. What kind of mileage between the failures? Why are front under warranty and not rear? Extended warranty?
MY06 Smoke Titan SE CC 4x4 Tow
Nismo Cold Air, Banks Monster, Nismo Headers,
2.5" leveler
ASE Master Technician
Nissan Master Technician
AEM Trained
Jared is offline   Reply With Quote
Old 05-07-2008, 08:15 PM   #3
TitanTech659
TitanTech659's Avatar
Re: VDC/Slip/4WD
Do you know what the codes were?
TitanTech659 is offline   Reply With Quote
Old 05-13-2008, 01:30 AM   #4
iamsmithy
iamsmithy's Avatar
Re: VDC/Slip/4WD
did the error codes locate the problem to the speed sensors?? i only get the lights when i've been in traffic for sometime, never when cruising along the highway...
Black Crew Cab 05 Titan 4x4 LE
iamsmithy is offline   Reply With Quote
User Name
Password
slip light helomech Titan Engine, Transmission & Drivetrain 5 03-15-2007 06:57 AM
VDC, SLIP, and ABS all on PrerunnerGreg Titan Engine, Transmission & Drivetrain 29 02-24-2005 07:59 PM
VDC / Slip 305hp Titan General Discussion 19 01-08-2005 10:14 AM
VDC/SLIP/ABS Lights On??? mtbendo Titan Problems & Dealer Service 9 12-31-2004 08:20 AM
Limited Slip?? KY TITAN Titan General Discussion 29 11-24-2004 04:56 PM
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
