Hmm, let's see '04
Brake Judder, rotors turned twice then replaced with new design, still running that set up and work great at 135,000
Trans coolant hoses leaking
Replaced both exhaust manifolds (cracked) warranty at 90k thanks Nissan!
Replace both rear axle seals (leaking)
Now at 135,00 runs great, looks great. I love the truck and I guess I have been lucky.
2004 LE 4X4 Crew Galaxy Black, Leer 100R shell, Chrome tailgate trim, Chrome stock wheels, chrome door sills, Zoomers cat back, 2*advance, 150,000 miles going strong. Traded on a loaded Dodge 1500 Laramie, heaven help me! As my dear old Dad said, "You've got to stop and smell the roses once in a while". He didn't.... I plan to know the smell of them roses intimately.
My 06's list is
1. Trans coolant hoses leaking
2. 4 Leveling sending units replaced (Ready for #5)
3. Heater inlet hose collapse
4. The puddle of water on pasanger floor (which I'm still fighting about)
5. Drive seat replaced, Frame damage
I'm only at about 42,000 Miles
2005 Audi A4 2.0 Turbo
2006 LE 4X4 Crew Cab Galaxy Black
Big Tow, OFF-Road, Nav, Sunroof
Current mods
2* Timing Advance, 305/65/18 BF Goodrich All-Terrain KO, PRG 2" Leveling Kit, Airlift Airbags w/Load controller II,
Styleline polished aluminum upper and lower grill, HID 6000k Low beams, Fog Lights
Reason: forgot something
front brake judder
front passenger seat tilt adjustment
rear seatbelt recall 2x
other than those items 0 issues. i have noticed rust in spots as well as some plastic parts starting to show wear. something a good detail would get rid of for sure.
36k 07 2wd 0-problems. i have drove the $hit out of my truck. nothing so far knock on wood and hope to not have any
2007 KC 2wd White
modswanted: UPREV ECU FLASH
BIG BRAKE UPGRADE
STEEL BRAIDED BRAKE LINES
MASTER CYLINDER STIFFNER
REMOTE START
REPLACEMENT BUMPERS
BULLETPROOF FRONT CLIP
SHACKLE FLIP THE REAR
MODS DONE!
REMOVED ALL THE DECALS,TINT, CAI, STRAIGHT PIPE EXHAUST, BALLISTIC OFFROAD JESTER'S 17X 9 -12MM OFFSET, 6" BASIC FABTECH LIFT, STACKED LEVELING KIT, 37x13x17 SUPER SWAMPER BOGGERS, 3"BODY LIFT, HITCH, 1 - 15" KICKER SOLO BARIC L7, CRUNCH 1500.1 AMP, THROTTLE BODY SPACER, PAINTED INDIGO BLUE INTAKE COVER,BURNOUT MOD,LED 3RD BRAKE LIGHT, BLUE LED'S UNDER DASH, WHITE FACE GAUGES, TB COOLANT BYPASS, AXLE VENT MOD, 2* TIMING ADVANCE, SUPERCHIPS PROGRAMMER, BLUE L.E.D. DOME LIGHT, CUSTOM MADE ROCK SLIDERS, DDM 35W 8000K LOW BEAM, DDM 35W 8K HIGH BEAM, MILE MARKER 12,000LB WINCH, 8-6" 100WATT OFFROAD LIGHTS, MY MADE LIGHT BAR, MY MADE FRONT BUMPER WITH WINCH MOUNT, LINE X BEDLINER, LINE X ROCK SLIDERS, LINE X ROCKER PANELS AND BOTTOM OF THE BED,
10.5" INGSIGNIA MOTORIZED FLIP DOWN SCREEN, SONY XPLOD W/ BUILT IN BLUE TOOTH AND AUX PORT, BACK UP CAMERA
Brakes, TransferCase, Rearend (within 1st 12,000 miles) now my body control module is acting up, and I have a white bed liner, but they're out of warranty so I'm just dealing with it.
2005 CC 4x4 SE
AKA
TreeHuggingHippieWhore™
"What if we picked the wrong religion? Every week we're just making God madder and madder." - Homer Simpson
Location: Right now in Ramstein Germany, no idea in the next five years
Re: List your Titans Mechanical Failures
I'll add to the mix,
- Thermometer reads ---
- Severe brake judder
- Weird electrical problems (every light comes on HVAC lights go off at random)
- Reverse sensors don't work
- Air bag light is crazy
- And the best part... I'm stationed in germany away from any real dealer support
just a thought, why dont you put the year of yall's truck when posting problems so we can see what yr most of the things are happening so we can check our trucks if they are the same year
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
from the sound of it 04-06 were probably the worse bunch, not too many 07-08 mechanical issues
2007 KC 2wd White
BIG BRAKE UPGRADE
REMOTE START
REPLACEMENT BUMPERS
MODS DONE!
you spoke too soon, 2008 cc pro4x
exploding rad fan
****ed valve body
hvac control recall
rear bumper plastic coming off
paint coming off passenger side fender flare (didnt know they were painted)
box was out of alignment but hopefully when i put it back on in the summer it will go on straight
and thats about it so far
Brake judder @ 3k miles, dealer replaced pads and rotors. Now at 30k miles, no judder and a lot of pad left (I could probably make it to at least 60k on the pads)
TSBs:
Aux cooler fan - Excessive noise. Add felt to hold fan snug in the mounts and not rattle while in operation
Recalls:
Aux cooler fan wiring, not affected but partially upgraded while they were in there.
Nothing else pops into my head. All things considered it's the best vehicle I've owned (and I've owned a lot). The only other vehicle that comes close is the '97 Ram 2500 Cummins diesel I had. 176k miles and I only had to fix 3 things, each one took 15 mins tops and < $100 in parts to fix, including the water pump. If my Titan was totalled today and I had to replace it with something I would have a very hard time choosing between another Titan and another Cummins Ram with a manual trans.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
