Titan stalls upon starting - Nissan Titan Forum
post #1 of 2 (permalink) Old 05-01-2009, 12:08 AM Thread Starter
iTrader Score: 0 reviews
My Titan has been progressively getting worse with starting as of late. The issue began with a warm start..the truck would fire fine, then idle down to 400 RPM, then recover to normal idle. Yesterday (after warm), the truck would fire then idle down to the point of shutting off. I repeated this several times. After letting the truck sit for 30 minutes, it would fire, idle down to 400 RPM, then idle normally. Driving and performance seems unaffected and no codes are thrown. So far I have cleaned the MAF and throttle bodies to no help. What could this be?
2004 Nissan Titan SE KC Blizzard
Chrome Step Rails
Smoke Bug Shield
Bedliner/Tonneau Cover
Big Tow
Volant Cool Air Intake
Magnaflow SS Custom Exhaust
2 Degree Advance
R1 Concepts Drilled/Slotted Rotors
2006 Northwind 27Y Bunkhouse Travel Trailer
White Lightning is offline
Advertisement
post #2 of 2 (permalink) Old 05-01-2009, 12:12 AM
Banned
Re: Titan stalls upon starting
ECU glitch? If you can, try to disconnect the battery over night (at least a few hours) to reset the ECU. Could be something that simple, and won't hurt anything. Worth a try.
adamdude04 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Engine Hot Stalls shaeboy Titan Problems & Dealer Service 10 08-16-2011 12:11 PM
05 Titan Starts and then Stalls Scott05 Titan Engine, Transmission & Drivetrain 4 03-19-2009 03:44 PM
Problems starting 07 Titan cemj Titan Problems & Dealer Service 10 12-28-2007 10:08 AM
Slow Starting Titan TitanWannaBe Titan General Discussion 4 02-09-2007 11:29 AM
Engine stalls/lose all control! thecruzs Titan Problems & Dealer Service 26 01-24-2007 01:27 AM
You may post new threads
You may post replies
