Old 06-12-2009, 02:49 PM   #1 (permalink)
2006 a/c condenser fan/motor/ harness recall
I had the recall done then my a/c wasn't working. I went to the dealer thinking they were at fault, they inspected and put in leak detecting fluid said come back in 2 weeks, assuring me it was not there fault. I go back they say my condenser needs to be replaced not there fault. I don't want to pay another dealer to inspect then argue with customer service. Help, is there a diagram of the harness, they told me the fan is no where near the condenser, it's like 1/2 inch away, it could be leaking elsewhere of course the mechanic is not in untill monday, but i want to see myself where it's leaking, but how do I get a mechanic to admit he banged it or something....important info i left out ..it worked fine before i had the recall work done, the dealership said they never break a condenser changing the fan/motor/and harness....I'm guessing it does happen they just don't admit it! will someone admit it happens cause i know mistakes happen
Buckhorn is offline   Reply With Quote
Old 06-12-2009, 10:32 PM   #2 (permalink)
Re: 2006 a/c condenser fan/motor/ harness recall
I'm about to take my truck to the dealership for the same recalls this coming week. I really don't know how to answer that till I have mine done. i will advise when its done.
Papi903 is offline   Reply With Quote
Old 06-13-2009, 01:44 AM   #3 (permalink)
TXSRedTitan's Avatar
Geez!! I have gotten the same recall notices and i hate taking my truck to a dealership for anything. When i 1st got the truck and took it back to the dealer for its 1st free oil change they messed up the drian plug and over torqued it leaving it to leak and then when i took it back they tried to tell me there was nothing wrong after having their top people look it over. What BS since i could tell they had added 3 more of the thin copper washers under the drain plug and could see oil slung all over the bottom of my new truck at the time. Anyway, really have a hard time trusting a dealer for anything. I wish i could see the replacement parts and do it myself. I will watch if i take it in this time. Good luck guys! I will be checking back for your replies!
Take care,
M
2006 TItan SE 2wd KC Red Alert, K&N, Little Tow Package, Tint, 20" LE Titan Rims (installed 8/21), Cooper Zeon LTZ tires 275/60/20 (installed 8/21), PRG Radflo front Coil Overs, Bilistein 5100 series rear shocks (Purchased / Installed), Banks CAI, Banks Monster Exhaust. (Purchased 9/19 Installed 10/4) Audio
Then more to come! TruTrac, Cortex, etc.
TXSRedTitan is offline   Reply With Quote
Old 06-13-2009, 09:13 AM   #4 (permalink)
sudden urge's Avatar
Take care,
M
You might not need anything done to your current fan. My fan happened to be the type 1 fan (Gate brand), so I never took it in. Click on my posting, and that will redirect you to the actual repair TSB.
RECALL for 06 Titan
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 06-16-2009, 05:19 PM   #5 (permalink)
Question Re: 2006 a/c condenser fan/motor/ harness recall
Thanks for the info Sudden Urge!!! Now i need to find out about the Wiring Harness Recall in between the rear Cab Doors. Something about the wiring harnesses not being installed correctly and that the twisting of the harness and wires as the back cab doors are opened could cause wires the break causing seat belt tensioners to not engage in an accident. Any info about what was being done to fix the issue? I hate taking my truck to the Stealers for anything i can do myself.
Thanks all,
M
Old 06-17-2009, 09:04 PM   #6 (permalink)
teamevolutionstitan's Avatar
Thanks all,
M
When I took mine in for that all they did was put some black plastic loom around it and zip tie it on and call it done. Nothing major, I just got my truck back from having this A/C recall thing done and 2 new exhaust manifolds put on.
'04 KC/6" Pro Comp/PRG Traction Bars/Banks Exhaust/OEM Fog light kit/K&N Intake/Westin Chrome Bull Bar/Westin Chrome Nerf Bars/6" Piaa Fog lights(Soon to install 6" KC's)/Lund Chrome Bug Shield/Replaced Driver Side Bedside with one with storage compartment
'06 CBR 600 RR
'97 Honda Civic (gas savers)
'90 CRX w/b18
teamevolutionstitan is offline   Reply With Quote
A/C fan motor FLfinfan Titan General Discussion 5 08-20-2008 04:10 PM
2 fan motor problems Graybeard Titan Problems & Dealer Service 3 07-02-2008 08:33 AM
Fan motor running but nothing from vents Shee Nut Titan Problems & Dealer Service 2 04-13-2008 03:07 PM
? about 2007' TSB for A/C condenser fan . ProjectTitan007 Titan General Discussion 7 06-25-2007 02:32 PM
Condenser fan not working TSB Old Speed Titan Problems & Dealer Service 3 09-26-2006 09:18 PM
