Old 06-28-2009, 03:47 PM   #1 (permalink)
smokeum's Avatar
What TSB? - R U Kidden me
I called to set up an appt. with my dealership. I'm not going to knock these guys because (some) are good to work with when I need something done. So I called to say I need two issues fixed. 1st- water is getting the carpet wet on the passenger side. 2nd- noisy spring/shackle issue. There are TSB's on both of these. They were like huh, and then like what... " I've haven't heard about those ". I've done a search and have found problems but I can't find the exact TSB(s) I need to print out so that I can carry it to them. Its for a 04 and probably won't matter since its out of warranty but it would be nice and maybe I can back date it since its been happening for a while. Sorry for the long write up.
smokeum is offline   Reply With Quote
Old 06-28-2009, 05:02 PM   #2 (permalink)
titanss's Avatar
Re: What TSB? - R U Kidden me
Here you go: Knowledgebase - 2004 Titan King Cab - Nissanhelp.com
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
Old 06-28-2009, 05:03 PM   #3 (permalink)
SOCALTITANKC4X4LE's Avatar
TSB for wet carpet:
2005: Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b]BLUE LED DASH LIGHTS MOD STILLEN RADIATOR
1997 PATHFINDER
w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 500,000 miles . 9/06/2009. Totaled on 9/13/09. R.I.P.
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 06-28-2009, 09:12 PM   #4 (permalink)
titanss's Avatar
You can fix the A/C drain cheaper than what the dealer will charge. I fised mine like this: A/C drain repair questions...
All they are going to do with the rear suspension is spray lube on it.
Since your Titan is out of warranty you will have to pay to have any TSB done, Recalls are the only things the dealer will do for Free.
2004 XE KC
Old 07-02-2009, 01:13 AM   #5 (permalink)
Just-in's Avatar
son of a ***** I never took mine in for the gastank TSB
Old 07-02-2009, 08:38 AM   #6 (permalink)
teksupportdude's Avatar
my stealership tried telling me that because its a tsb they don't have to fix it. my truck had 2k miles on it getting its first oil change and tried the whole "how many miles are on the truck" to get out of doing it when i told them "i bought a truck from you with problems and you are telling me you don't have to fix them because its only a technical service bulletin?" then they asked the how many miles on the truck and when i said "2000" the 3 service techs that where there jaws dropped like oh, shxx, we gotta fix it on warranty.
Zeus destroyed the Titans with his Thunderbolts, from the smoldering ashes mankind was born. Now the Rise of the Titans Again!
Contact Info
Myspace.com
http://www.myspace.com/x0m6ie
Cardomain.com
http://www.cardomain.com/ride/1262876
teksupportdude is offline   Reply With Quote
Anyone have this a/c TSB done yet? 6thsense Titan Problems & Dealer Service 33 10-11-2005 10:03 AM
TSB for AC GO_VOLS! Titan General Discussion 3 10-05-2005 11:49 AM
tsb mkelee Titan Problems & Dealer Service 1 12-23-2004 08:28 PM
new tsb Truck41 Titan Wheels, Tires & Brakes 2 10-21-2004 06:10 PM
Tsb mrcolin2u Titan General Discussion 1 10-10-2004 05:29 PM
