Old 07-02-2009, 11:42 PM   #1 (permalink)
mcbreaker's Avatar
Need help ASAP Titan wont go into gear
Heres my problems when I start my titan all the guages freak out for a couple of seconds. Second the A/C just stopped no blower nothing. Third after I start it, it will not come out of park stuck in gear. Last but not least when i hook up my new scanner it keeps saying please hook up to OBD but works fine on other vehicles. All of these happened at the same time. Any help would be great thanks
mcbreaker is offline   Reply With Quote
Old 07-02-2009, 11:47 PM   #2 (permalink)
vilim12's Avatar
Re: Need help ASAP Titan wont go into gear
Fried ECU?
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is offline   Reply With Quote
Old 07-02-2009, 11:49 PM   #3 (permalink)
mcbreaker's Avatar
Originally Posted by vilim12 View Post
Fried ECU?
Whats that cost?
Old 07-02-2009, 11:59 PM   #4 (permalink)
vilim12's Avatar
No clue, and im just throwing out ideas. Ive NEVER read about anyone having any problem like this. Hopefully someone more helpful chimes in
Crew Cab Long Bed
Old 07-03-2009, 12:36 AM   #5 (permalink)
SOCALTITANKC4X4LE's Avatar
How to:ECU Reset,Throttle & Accelerator Position Learning
Try reseting the ECU.
2005: Banks, K&N CAI, Stillen Big Brakes, Stillen Transmission valve body mod. Detroit Trutrac, PRG TRACTION BARS, ODYSEY BATTERY [b]BLUE LED DASH LIGHTS MOD STILLEN RADIATOR
1997 PATHFINDER
w/ original engine and and diff. (Tranny died at 473,000 Rebuilt by Aamco )
Odometer reads 500,000 miles . 9/06/2009. Totaled on 9/13/09. R.I.P.
SOCALTITANKC4X4LE is offline   Reply With Quote
Old 07-03-2009, 02:10 AM   #6 (permalink)
1badass2006titan's Avatar
Sounds fried but try the reset. Don't just disconnect the battery because it is not always the best bet with this case. Socal put in a nice link so you can do it. Dealer will charge you up the a**. Good luck!
Mods: K & N Cold Air Intake, Magnaflo exhaust, DMH Performance Electric Exhaust Cutout, Firestone Rear Airbags, Electric Brake, Dvd, Navigation, Leather, Rockford Fosgate, 33" Toyo Open Country M/T tires, 20" American Racing Rims, Westin Bull Bar, Billet Grill, Viper 2 Way Remote 7900, LoJack, Moonroof, Extang Fulltilt Tonno cover, Hood protector, window guards, Nissan moonroof wind guard, loaded with every possible option available from factory!
1badass2006titan is offline   Reply With Quote
Old 07-03-2009, 10:38 AM   #7 (permalink)
You should also clean both battery cables.
1997 PATHFINDER
Old 07-03-2009, 10:42 AM   #8 (permalink)
Carbeaux's Avatar
I'm not following the logic of a fried ECU here. Sounds to me like a low voltage situation. Battery or alternator, or both.
I'm sure that if the ECU does make sense, someone will come along and let me know I'm wrong, but I hope they'll at least explain to me how/why.
Hook 'Em Horns!
Old 07-03-2009, 10:44 AM   #9 (permalink)
vilim12's Avatar
I would think if the truck has enough power to start, but not enough power to turn the blower on that a low battery is likely not it.
Crew Cab Long Bed
Old 07-04-2009, 06:15 AM   #10 (permalink)
Carbeaux's Avatar
Other symptoms it's exhibiting do point to low voltage or amperage situations. When my batt went belly up last week, it was still barely turning over and would start, but the needles sat there and jumped for a second and the trip ODO reset, until the alternator gave it enough voltage/amperage to work properly. If he's got a double problem of a batt that's given up because an alternator isn't properly charging it, there wouldn't be a recovery to the system from the alternator making up the shortfall of power needed. Make sense?
Hook 'Em Horns!
Help!.tried the burnout mod and truck now wont go into gear Dom249 Titan Performance Modifications 7 12-08-2007 06:08 PM
titan wont start!! reagan12 Titan Problems & Dealer Service 12 12-01-2007 07:11 PM
HELP PLEASE! Titan wont start! Footloose301 Titan General Discussion 11 06-14-2007 02:09 PM
Titan Wont Start!!! luiscaratinijr Titan General Discussion 7 04-25-2007 08:10 AM
I know you titan boys wont like this Srt-8 War Stories 20 08-02-2006 12:23 PM
