Old 07-04-2009, 05:28 PM   #1 (permalink)
beason's Avatar
Send a message via AIM to beason Send a message via MSN to beason Send a message via Yahoo to beason
check engine light, bad news...
I got a check engine light on my truck. ran it up to autozone to run the code, and it came back p0420.
catalyst system efficiency below threshold - bank 1
probably cause
air leak in exhaust before rear h02s
Af sensor error
fuel system fault
faulty catalytic converter
Now, im pretty sure its the MAF, since when i had problems when the truck died, someone told me to clean it. I cleaned it using MAF cleaner, but i think that damaged it.
I feel this would be the most logical outcome.
Has anyone else had this error code?
Autozone quoted me over $200 for the MAF.
The previous owner removed the air box and installed a cone filter on the end of the tube, i would like to put an air box back in, would it be better to just get an aftermarket setup? do they come with MAF's?
  • 06 Galaxy Black LE Crew Cab BT.
  • air box mod
  • Armada air dam
  • Aries stainless step rails
  • Power Acoustik REACT1-1100 Class D2 1100-Watt Mono Amplifier with dual 10" kicker cv-r subs
  • Dick Cepek DC-1 18" chrome wheels
  • Flowmaster 50 dual in/out dumped.
Soon to have: 2" drop shackles, Jet Tech mod, tinted tails, CAI.
beason is online now   Reply With Quote
Old 07-04-2009, 07:40 PM   #2 (permalink)
titanss's Avatar
Re: check engine light, bad news...
If you used the CRC Mas Air Cleaner it did not hurt the MAF, i have used it on my Titan. This is a common code, look for leaks before the 02 sensors. There have been post on the cats coming apart on these trucks.
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
Old 07-04-2009, 11:36 PM   #3 (permalink)
beason's Avatar
where would i begin looking for leaks? in the exhaust?
  • air box mod
  • Armada air dam
Old 07-05-2009, 12:52 AM   #4 (permalink)
walleeme's Avatar
Exhaust is part of the emissions warranty. I think o2 sensor should be too.
Should be covered for 8/80.
Just so you know.
My has almost nothing compared to some of you guys, but I still like it.
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing at least half your clothes.
Let him that hath understanding count the number of the beast: for it is the number of a man; and his number is Six hundred threescore and six.
Iron Maiden
Integrity is someting you cannot buy. You either have it, or you don't. You do not want to not have it.
http://s3.bite-fight.us/c.php?uid=181043
walleeme is offline   Reply With Quote
Old 07-05-2009, 07:22 AM   #5 (permalink)
titanss's Avatar
Look for black soot around any flange, clamp or 02 bung. The exhaust leaves this soot when it is escaping the pipes.
If your still under warranty, let the dealer worry about it.
2004 XE KC
Old 07-05-2009, 08:54 AM   #6 (permalink)
beason's Avatar
its an 06 with 60k, but i got no info about warranty when i bought it. i can just take it to the dealer and they will check it out?
  • air box mod
  • Armada air dam
check engine light ckb Titan Engine, Transmission & Drivetrain 2 03-26-2008 08:07 AM
P1027 Service Engine Soon Check engine light Hendge Titan General Discussion 0 01-21-2008 02:28 PM
Check engine light? Helinut1970 Titan General Discussion 10 05-31-2006 07:11 PM
Check Engine Light argonaut1992 Titan Problems & Dealer Service 6 08-19-2004 06:42 PM
