Titan is DEAD! Cranks and turns but not stay running HELP!
I've searched many posts and found various similar problems but none like mine.
Car was working fine just until recently i've been having to jump my car's battery quite often for some reason. But that is no longer the problem. Now after i jump the battery the car would start but it'll idles up and down as if trying to stay running but it will eventually dies after 5-10 seconds.
After doing that for about 3 times, now it won't even fire up. It'll crank and turns but will not stay running. There is spark, fuel pump works, MAF sensor is clean, no code thrown...so now i'm stump. At this point my only guess is something electrical or maybe the security system?
i just notice that when i step out of the car, and locks the door, the blinking "key" light would stay solid in the car and than flashes after 10 seconds but remain flashing for quite sometime. Does this indicate that it still thinks there's a key inside? Is this light suppose to stay on this long?
Re: Titan is DEAD! Cranks and turns but not stay running HELP!
no mine does the key flash too not that
2008 SE 2WD:
PRO COMP Kit, PRG UCA, with Radflows 2.5 Externals sitting upfront at 9.5" and rear 3' with MX6 Rear shocks. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. Injen CAI,
The Following User Says Thank You to salstats For This Useful Post:
you know what that means trip to the stealership
2008 SE 2WD:
car currently at a friend's shop, hopefully he can figure it out before i am force to bring it to the stealership...
the symptom is now worse, it literally just fires up and dies even before it idle. I'm just praying it's not something too costly, barely had the truck for a year (an 08) and just to make it worst i just went 3k miles over the warranty period so that's kind of a bummer.
I agree with "beason" my truck did the same thing took it to pep boys they told me it was a relay got lucky I only paid like $50 or so for a diagnostics. I haven't had a problem since.
__________________ 2005 Nissan Titan 4x2 CC
MODS
3" level, Bilstein Shocks, BFG KO 305/65/R18, Magnaflow Exhaust, Air Box Mod, Blacked out OEM 5 spoke rims, TB bypass,Headlight Mod, Smoked tail lights, Custom grille, Blacked out center console and Radio, rear fog lights
well got the truck fixed, all it need was a throttle body cleaning, replaced crank sensor, and replaced MAF sensor. There was one more sensor that i forgot what he called it but it wasn't the IPDM.
what is it with nissans and crank sensors. i have an 6 sentra that will crank and crank and not start then you cycle the key and it will fire up. then other times start right up. they have a tsib for the sentra not sure about the titan tho.
An '08 and you're already beyond the 5/60 powertrain warranty? Dang, that's a lot of driving! Glad you got it all resolved.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
I thought I was putting some serious miles on my 08. I have about 35k in 2 years.
gaycamellovingwhore
2008 Nissan Titan LE Crew Cab
Black/Black Leather
Tow Package
Black Hunter Truck Accessories Brush Guard
Black Undercover Hard Tonneau Cover
iPod adapter
Magnaflow 22" dual in single out muffler
BullyDog Power Pup
5000k HID low beams
lol, yea i do a lot of driving. plus a lot of people do a lot of driving for me as well...cause you know when you have a truck everyone's your friend hahahaha. I'm at 41k and still climbing fast.
Mine died on Saturday, thought it was the fuel pump but my mechanic checked that and there was plenty of pressure and thought it was a computer or sensor problem and had me take it to a dealer. Dealer said it was the fuse box in the engine bay, gonna be $420 to fix it. Sucks, just bought mine two weeks ago!
