Old 10-08-2009, 05:15 PM   #1 (permalink)
shaeboy's Avatar
Droan and vibration at 1500 RPM-UPDATE..Problem found
Hey Titan guru's..I have more to add to my problem. Here is the original problem....(When my truck hits 1500 RPM I am getting a vibration in the gas pedal and floor board. It also has a droan/metal vibration sound. It happens mostly around 50-54 MPH in OverDrive. It does not happen if you put the truck in neutral and coast. Can happen in any gear below 54MPH at 1500 RPM though. I feel a slight vibration even in park at 1500 RPM (groan). It is worse when the drive train is under a load as I explained above. Any ideas? Does this sound like an exhaust manifold problem? Engine/Transmission mount? It is a 2007 Crew Cab with only 25,000 miles on it.
Update...I have been driving it in 4th because of the vibration in OD. I had the dealer look at it and they could not find anything. Since then it has been jumping on occasion (almost like the transmission is losing power from the torque converter). It shakes the whole truck almost like the engine is going to die, but the RPM's do not change. Does this sound like a transmission going out or torque converter problem. Please help. It is driving me crazy.
Update 10-16-2009
Finally figured it out. I went by my local Nissan dealer (Barr Nissan in Columbia, TN) and talked to the service manager (James, super nice guy). He said to bring it by next week and he would drive it with me and see what was going on since it had gotten worse. I asked him if I needed to check the transmission fluid. He said that would be fine. As soon as I got home I popped the hood with it warm and running, and pulled the trans dipstick to check the fluid. It was a little low on the stick but it looked fine(light red not dark). . Smelled a little weird, so I put it between my fingers and rubbed...I could feel grit. I thought "must be dirt", so I put it back in and checked again..grit again. Turns out it was metal shavings. I checked it 2 more times and metal shavings both times. Looks like I will be getting a new trans next week. Truck only has 25K miles on it. Hopefully this will fix my problem and I can go on loving my Titan like I loved my 2004. Thanks for all the suggestions. This place is a world of knowledge for the do-it-yourselfer. I will let you know the final say when it is all said and done.
Update-10-22-2009
It was not a bad transmission. Pan was clear. They dropped the pan and serviced the trans(no charge..thanks James!) Dealer said there was grit in the dipstick tube, that was what was on the stick. He said he thinks the Torque converter (he is still not sure) is unbalanced or going out. Wants to wait until it fails to try to replace. Said it could be the an unbalanced flywheel, or cat problem. Feels the vibration and jumpiness. Frustrating problem for us both. I will let you know when something finally fails and I get this problem fixed.
2007 Titan Crew XE 4x2
shaeboy is offline   Reply With Quote
Old 10-08-2009, 05:52 PM   #2 (permalink)
bagellord's Avatar
Re: Droan and vibration at 1500 RPM-More Problems
How many miles? Have you serviced the transmission at all?
gaycamellovingwhore
2008 Nissan Titan LE Crew Cab
Black/Black Leather
Tow Package
Black Hunter Truck Accessories Brush Guard
Black Undercover Hard Tonneau Cover
iPod adapter
Magnaflow 22" dual in single out muffler
BullyDog Power Pup
5000k HID low beams
Pending:
2 12" RF subs + amp
Wish List:
Cold Air Intake (AEM or Injen or K&N)
bagellord is offline   Reply With Quote
Old 10-09-2009, 04:53 AM   #3 (permalink)
shaeboy's Avatar
It has close to 26,000 now. Not time for a trans service yet. Probably gonna take it back to the dealer. They were looking for engine/exhaust problems before. I will get them to check out the trans this time (fluid, etc.)
Old 10-09-2009, 06:13 AM   #4 (permalink)
sudden urge's Avatar
Are you running the stock exhaust?
05 KC SE 4x2 FFV, smoke, no big tow. Mods: Bully Dog Power Pup, JBA catback, S&B GEN 3 CAI, Hellwig HD traction springs, Nasta nerf bars, Kenwood KSC-SW1 powered sub, Grilleguy lower bumper insert, Autoenginuity/enhanced Nissan software. Latest 1/4 mile time of 14.632 running BD reg 87 tune in FST. Currently running the Superchips Flashpaq. JBA catback soundclip, just some revs: http://www.vimeo.com/634077
Old 10-09-2009, 09:04 PM   #5 (permalink)
shaeboy's Avatar
Everything is stock. No modifications other than upgrade from 17 inch steel wheels to factory 18 aluminum LE wheels and tires.
Old 10-09-2009, 10:53 PM   #6 (permalink)
walleeme's Avatar
Broken trans mount?
My has almost nothing compared to some of you guys, but I still like it.
Red meat is not bad for you.
Fuzzy green meat is bad for you.
You know you had a great night last night when you make it home the next day missing at least half your clothes.
If you have integrity, you do not have to defend yourself. Learn it. Live it.
walleeme is offline   Reply With Quote
Old 10-10-2009, 05:57 AM   #7 (permalink)
shaeboy's Avatar
Originally Posted by walleeme View Post
Broken trans mount?
Nope, in perfect shape. The underside has been checked over thoroughly by me and the dealer. Has to be something internal.
Old 10-10-2009, 06:23 AM   #8 (permalink)
Ok, I thought you might have a muffler swap that could cause a pedal and floor vibration at a certain RPM, but we can probably rule that theory out. When I had a Flowmaster 70 muffler swap done way back when, I started to notice a pedal and floor vibration at a certain RPM. After I later swapped to a Magnaflow muffler, the pedal and floor vibration was gone.
Old 10-10-2009, 11:53 AM   #9 (permalink)
n2titan's Avatar
The rattling could be due to heat shields. Do a search on that. It could be caused by the other issues your truck is having. Good luck... Hopes it's a minor issue.
n2titan is offline   Reply With Quote
Old 10-17-2009, 08:10 AM   #10 (permalink)
shaeboy's Avatar
PROBLEM FOUND!!!!!!!!!!!!
Old 10-22-2009, 05:23 AM   #11 (permalink)
shaeboy's Avatar
Update-10-22-2009
Droan and vibration at 1500 RPM shaeboy Titan Problems & Dealer Service 4 07-20-2009 02:56 PM
it ONLY happens at 1500 RPM’s AKTitan Titan Problems & Dealer Service 1 02-11-2008 05:11 AM
Rattle at 1500 RPM i386 Titan Problems & Dealer Service 8 06-16-2007 09:06 PM
Do you have Vibration problems with 35 and up tires? Gonpostal Titan Wheels, Tires & Brakes 21 03-16-2007 12:18 PM
1500 miles on the Titan now and I'm noticing some problems... Vyrus Titan Problems & Dealer Service 8 07-31-2005 05:35 AM
