Old 10-12-2009, 08:23 PM   #1 (permalink)
4x4 is not engaging
Hey guys, MY 4WD is not engaing in my 05 KC, The diagram for the wheels engaged on the cluster disapears when I turn it to 4WD, instead of filling in all 4 holes to show its in 4wd, but if you cut it hard on pavement you can tell its not in 4wd, Then when you turn it back to 2wd the 4wd light will not go off until you turn it off for a min and let it reset. Has this happened to anyone else? any advice? THanks in advance.
jbarth636 is offline   Reply With Quote
Starter Engaging While Running Iowa Titan Titan Problems & Dealer Service 17 03-04-2009 11:21 AM
Brake failure, abs engaging? the_kernel Titan Problems & Dealer Service 33 06-04-2008 08:18 AM
4WD not engaging? Steve-o Titan Engine, Transmission & Drivetrain 12 03-21-2008 12:38 PM
reving up before engaging dslater524 Titan Engine, Transmission & Drivetrain 1 06-30-2005 07:43 AM
Indicator says D but not engaging!!!! Titan4x4Dave Titan Problems & Dealer Service 5 09-14-2004 09:35 PM
