Re: LIFT/ 35-37IN Tires! Need help and pics!!!
Ok so what should i do? 18x8? with a smaller tire? Or any rim that would have enough back spacing?? i dont want it to stick out way too much. Also, this truck isnt doing that much off roading. So i dont need a total aggressive tire, but the look is nice
First off, if you don't need an agessive tire, don't get one...There are plenty of good looking A/T tires around...
It's well know around theses parts that I'm a fan of the 17" wheel over anything else bigger, BUT it's your truck...I run 17" by 8.5" with a b/spacing of 4.75 and it's not a bad combo...If you do decide to go with 17" tires, they cost less and there seems to be more sizes around...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
