Old 10-17-2009, 05:20 PM   #1 (permalink)
Colten K's Avatar
Need new ball-joint.
So i took my truck in to get some tires and a alignment after i did the mini lift (looks good), so they didnt do the alignment beacuse they told me i need a new left side lower ball joint and you have to get the whole lower A-arm, they said its $700 new not a chance im paying that, so if i go to the Auto Wreckers will a ball joint from any year titan or a Pro 4X work? also if i put the front coils in from the Pro 4X they have there will it bring my front end up a bit as well? will it work?
2005 SE
Galaxy Black
King Cab
4x4
Big Tow
Off Road
Air aid intake
Billett Grill
Mini Lift
34" NItto Terra Graplers
BAck Flip box cover
LED light bar under tailgate
Custom hockey stick shifter
Colten K is offline   Reply With Quote
Old 10-17-2009, 05:50 PM   #2 (permalink)
Re: Need new ball-joint.
I think Auto Parts Fast at RockAuto has ball joints for about $50
Old 10-17-2009, 06:22 PM   #3 (permalink)
titanss's Avatar
Yes they have them, $45 Upper and $60 Lower.
Lower: MOOG Part # K80647
Upper: MOOG Part # K80994
2004 XE KC
Quickest UnTuned Titan: 13.900@96.67mph
Old 10-17-2009, 06:47 PM   #4 (permalink)
thebassn8tr's Avatar
How did they determine that you needed a new one? I think I need one to solve my front in clunk noise...not sure though.
thebassn8tr is offline   Reply With Quote
Old 10-18-2009, 02:53 AM   #5 (permalink)
Colten K's Avatar
ya my driver side was/is clunking when going over bumps and stuff, i dont know how they determine it but im sure thats the problem.
2005 SE
Galaxy Black
King Cab
4x4
Big Tow
Off Road
Air aid intake
Billett Grill
Mini Lift
BAck Flip box cover
Old 10-18-2009, 05:26 AM   #6 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
I have 85K on my Titan and I hear a knocking noise on the passenger side when I drive on gravel roads or over uneven paved road surface. I replaced the ball joints on my T100 years ago and it sounds about the same. Also if I drive slow over a good size bump in the road or shoulder it will make a loud POP noise under the front of the truck.
Yep sounds like it's time for ball joints.......how many miles are on your Titan and what kind of road surface do you drive on?
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and 75-90 in Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
JFK http://www.youtube.com/watch?v=J8dLHZ6jKFc
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 10-18-2009, 10:51 AM   #7 (permalink)
Colten K's Avatar
i have 108,000 and im in Canada so a bunch of gravel roads, and soon to be snow and ice. some pavement too but in places around town and stuff it can become rough and thats where i hear the noise.
2005 SE
Galaxy Black
King Cab
4x4
Big Tow
Off Road
Air aid intake
Billett Grill
Mini Lift
BAck Flip box cover
Old 10-20-2009, 11:17 AM   #8 (permalink)
Well, I'm in the same boat as you. Actually, I'm literally in the process of replaing both of my front lower ball joints. This is ridiculous. I've torn apart many cars, but this is by far one of my least favorite jobs. If you have a 4x4 be ready to disassemble the front end and take out your axle shafts, otherwise you can't get your LCA's out of the spindles. Also if you've driven through winters and seized up your bolts, etc. like I have you'll curse the day you start this job. Oh well, just an FYI. I'm back to work...let you know how it goes?
tropicoz is offline   Reply With Quote
Ball Joint Replacement? CVTITAN Titan Suspension 6 09-24-2009 11:50 AM
Lower Ball Joint mikeredding Titan Suspension 9 08-07-2009 09:30 PM
Upper ball joint help needed. onect Titan Suspension 7 05-16-2009 01:11 PM
Lower ball joint question bthelton Titan Suspension 1 06-24-2008 06:44 PM
Ball joint? HudsonValleyTitan Titan General Discussion 8 02-11-2007 07:18 PM
