Re: NEED help identifying LIFT
Originally Posted by Titan of T-Mec
so easiest way to squeeze a couple of more inches is wrench up coilovers in the front and block it in the back? And yes im putting 35" hankook AT as soon as taxes come back around..
tax time get you some PRG upper control arms with coil bucket spacer and turn that 6" lift into a 9" lift. you will clear 35's with ease and some 37's.
if you don't do off roading add a body lift and you can clear 38's then you'll be at 12"s
eDDie FonZareli 2005 SE 2wd
6" Procomp Stage 2 Suspension with a 4" Rear Block
3" Body Lift
CST CBDB
AFE Stage 2 CAI with BD 2* Timing Advance
3.00 in/out Bullet Muffler, Dumped
Custom 2.50 to 3.00 Exhaust Piping
37" Toyo Open Country M/T's
20x10 XD Rockstars
Smoked tails, Headlight Mod & Grille
2 10" Kickers, Kenwood Excelon Double Din
Powered by Fosgate WHATS NEXT
PRG UCA'S
Coil Bucket Spacer
Deaver C10 Leaf Pack
Traction Bars
