I bought the Titan a year ago. when I asked the guy what kind of lift he had he told me he had a shop install it. I called Greg at prg and me and him tried to figure it out. it seemed sitting too low to be a pro-comp 6" even though the coilovers are set a lowest setting. I figured i would post pics and see where that took me.
thanks.
I wanted to know because i want to go bigger it doesn't look like 6" to me. guess thats because everyone around here in so cal it 8" and up. would it be best to get the spanner wrench and adjust the coilovers (not maxing them out) or just go for S.A.W or CST Spindle? have a little money to play with?
thanks.
ill tell you one thing GOOD luck with pre-loading those coilovers by far one of thee hardest to do. i had those my self and hated them since it was nearly impossible to add pre-load....ugh! thank god i sold them...but yea good luck you'll need it....
2008 SE 2WD:
PRO COMP Kit, PRG UCA, with Radflows 2.5 Externals sitting upfront at 9.5" and rear 3' with MX6 Rear shocks. Nitto Trail Grapplers 35x-12.5-17 Tires. PRO COMP ALLOYS SERIES 6005 rims. Injen CAI,
soak em in WD-40 or liquid wrench every day for a few days and hit the threads with a wire brush. it will clean em up and make adjusting more easy..........well a little
2007 Galaxy Black, CC, 4x4, Big Tow, Off Road.
Custom Dual FM 40 Series Exhaust, AEM Brute Force CAI, 2* Timing Advance, 2 JL Audio W3 10" Subs, De-Badged, De-Chromed, Pro- Comp 6" Lift, Radflo Coilovers, 20x10 KMC D-Backs, Nitto Terra Grapplers 305/55/20
Good advice man, I work with alot coilovers for cars. Them being clean, free of dirt and sand makes a HUGE difference with adjusting them. If they are really dirty I usually spray some brake cleaner on them and use a tooth brush to clean the teeth up. Or just use soap and water with a sponge and tooth brush. Just don't use that sponge on the rest of your truck, unless you want a bunch of scratches on your paint. Once clean spray some WD40 on to lubricate them.
yea I have done coilovers with cars before. it wasnt the funnest thing to do. If i adjust the front pre-load wont i end up with a so-cal lift? with the front sitting higher because the back will stay the same. so would i need to buy bigger blocks or just go with shocks in the rear?
I use a cheater pipe on the spanner wrench to adjust mine.
me too!!
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
so easiest way to squeeze a couple of more inches is wrench up coilovers in the front and block it in the back? And yes im putting 35" hankook AT as soon as taxes come back around..
tax time get you some PRG upper control arms with coil bucket spacer and turn that 6" lift into a 9" lift. you will clear 35's with ease and some 37's.
if you don't do off roading add a body lift and you can clear 38's and some 40's.
eDDie FonZareli
2005 SE 2wd
6" Procomp Stage 2 Suspension with a 4" Rear Block
3" Body Lift
CST CBDB
AFE Stage 2 CAI with BD 2* Timing Advance
3.00 in/out Bullet Muffler, Dumped
Custom 2.50 to 3.00 Exhaust Piping
37" Toyo Open Country M/T's
20x10 XD Rockstars
Smoked tails, Headlight Mod & Grille
2 10" Kickers, Kenwood Excelon Double Din
Powered by Fosgate
