Can someone tell me WTF is going on with my Procomp 6" lift
Hey guys
Listen, i have a procomp 6" lift, 22" wheels with 305/50 nitto terragraplers. My front swaybar endlink brackets always break. I have like 2 extra because they break so often, its really getting old.
Well today i heard the usual clanking from the sway bar and thought "well time to replace the bracket again." This time the bracket broke AND the metal tab that comes off the lower control arm is broken too. SO now it looks like im going to need a new lower control arm also.
Does anyone else have this problem? Im thinking about just taking the sway bar right off to end this BS. As a side note, its ALWAYS the drivers side that breaks. And i do no offroading whatsoever.
Re: Can someone tell me WTF is going on with my Procomp 6" lift
Pics would be nice. Are you sure they're installed correctly? The ProComp endlinks are kinda tricky to install in the correct configuration. I am betting that the parts are hitting on the spindles steering stop as well.
Does it look like this?
__________________ 2005 Nissan Titan CC SE 4x4 6" Stage 1 Procomp Lift, SAW Coilovers-Front, Bilstein 5125 Series Shocks-Rear, Total Chaos Shackles, Custom Skid Plates
like POPS said ... get some SAW's and ditch that sway bar!! I do have some PRG extended length end links (that I would be willing to sell) if you want to keep the anti-sway bar
2004 XE 4x4 CC OR
6" Pro Comp lift with SAW's
Deaver Springs in the Back with Bilsteins - thanks PRG!!
Bumpin Sub box and Sundown Amp thru Tech12Volts!!!
37x13.50/17 Toyo M/Ton Factory OR wheels
Cherry Bomb Extreme Exhaust
Originally Posted by Lurchdubious
I really need to get some SAW's too. I hate my anti-sway bar. Mine hasn't broken anything, but it clunks around enough to be very annoying.
the first time my endlink bracket broke my sway bar went through my CV boot. what a joke, luckily nissan was nice enough to replace it under warranty for me.
2007 SE Crew cab
6" Procomp
22" wheels
Terragraplers
You don't need a new LCA, just have a muffler shop weld the tab back in place. You can grind the steering stops off of the spindle if you want to, that should help a little. Do you have the Stage 1 or Stage 2 kit? If you have aftermarket coilovers, you can ditch the swaybar and links completely and be just fine.
Yea i might just get it welded, use my new bracket as a jig for the guys at a shop. I have the stage 1 i believe as it has the stock coilovers with the spacer on top. are the SAW's by PRG the most cost effective set of coilovers i can get? I saw on the site there is a set of radflo/icon for 899 that is front and back. i could use new rears as well, but im not sure if this fits my truck with it being lifted. I really dont want to buy new upper control arms either. here is the kit i saw.
I had the same problem for about 2 years.. I went through about 15 endlinks... Both side would break, one at a time. It wasnt just the driver side like yours....
Finally when my tab broke off like yours, I made a drive down to PRG's old place and picked up a set of CST sway bar links for $80. I heard so much good about them and noticed they dont even use the tab that broke off.
Since then, I have been the happiest person alive... The ride is a mess without a sway bar, even with my Pro Comp stage 2 coil overs.. So far its been about 4 months.. I can FINALLY off road, tow and drive in peace with out a sway bar worry in the world
2006 NO FEAR Edition CC TITAN
PRO COMP Stage 2 with MX6 Shocks
CST Sway Bar Links
35x12.50 PRO COMP Xtreme A/T
20x10 KMC XD Series Monsters
Shaved & Pulled Rear Fenders
2008 Rear Axle
5% Tint
6k HID
Alpine Indash
Alpine PDX 1.1000 & JL 300/4 AMPS
Infinity Kappa Components all around
4 10" JL W3 v2 in a Fiber Glass Box
Odyssey PC1700 Deep Cycle Battery
Bully Dog GT Gauge and Programer
Gibson Exhaust with Throw Down Tip
Volant Intake
You need to get some good coilovers from PRG the pro comp ones are trash i had them before my Radflos it's day and night then you dont need the sway bar and dont need to buy some CST end links
Ohh man, tell me about it.. Ill try to avoid even a speed bump by all means necissary
Cantttt wait to switch over.. how much lift can you crank out of yours???
