Old 10-26-2009, 10:56 AM   #1 (permalink)
6'' Pro Comp Lift help!
Ok i have a 2006 crew cab LE nissan titan and i want to get 35'' tires on it... Ive been told that with the 6'' pro comp lift they should fit just fine with no rubbing whatsoever. I need help with lift details though because ive never gotten one before, i saw people taking about coil covers and blocks and it gets me very confused. If i order the 6'' pro comp lift will that be all that i need? or do i need coil covers and blocks or whatever else is usually mentioned? any help would be greatly appriciated!
Kulesza is offline   Reply With Quote
Old 10-26-2009, 11:14 AM   #2 (permalink)
Pops's Avatar
Re: 6'' Pro Comp Lift help!
The ProComp Stage I lift is all you "need", it includes the blocks. You'll "want" coilovers later when your OEM shocks wear out but that expense can wait.
PerformanceLifts.com -- Explorer ProComp Nissan Titan 6" Lift Kit
If you want to just go ahead and do it all at once, these links are the way to go because they are much better packages than the ProComp Stage II lift.
PRG Products
PRG Products
2005 Armada LE 4x4
Superchips Tuned, AirBox Mod, PS2 Game Console, ProComp 6" Lift, Sway-A-Way - Nitto TerraGrappler 325/60-18
____________________________
Old 10-26-2009, 11:29 AM   #3 (permalink)
HAYNBOI96743's Avatar
Like Pops said, its the stage 1 package. You should be able to clear 35's no problem. It really depends on your wheel offset and Back spacing. Large lug tires like M/T's have a greater tendency to rub at the Pinch Weld (PW) If you are using stockers or anything close to stock specs you should be fine, good luck and post pics when you are done!
HAYNBOI96743 is offline   Reply With Quote
Old 10-26-2009, 11:52 AM   #4 (permalink)
54warrior's Avatar
Personally, having had the ProComp lift installed on my Titan since June 2005, and then installing the SAW coilovers in April 2008, I first would recommend getting the SAW or Radflo coilovers ASAP if you go the the bracket lift route.
Additionally, when I bought the bracket lift years ago, there were not many options out there, other than the ProComp and Fabtech kits. Given the other options available now, I would not do the same thing again. Realistically, the PRG Extended Travel Package [LINK] would be my first choice, followed by this style of setup [LINK] if I had a larger wallet.
2005 Nissan Titan CC SE 4x4
fs 2wd fabtech lift with pro rims and pro comp extreme all terrains timlloyd951 Buy/Sell 8 07-07-2008 06:17 PM
What body lift could I use with a pro comp 6" lift? texas t Titan Suspension 9 04-09-2008 04:49 PM
Pro Comp Lift johnwoo Titan Suspension 7 07-31-2007 05:38 AM
pro comp lift ahhhrockyahhh Titan Suspension 3 09-29-2005 03:17 PM
Pro Comp Lift webslinger1977 Titan Performance Modifications 0 10-26-2004 11:49 AM
