Old 10-28-2009, 11:42 AM   #1 (permalink)
Titanup07's Avatar
2wd spindle lift package installation
Just got off the phone with 4 wheel parts. They qouted me $680 for the install with an allignment after. Does this sound right? I am looking to get the 2wd spindle lift pkg with deaver c-30.
2007 black CC 2x4
Banks Exhaust
Titanup07 is offline   Reply With Quote
Old 10-28-2009, 12:29 PM   #2 (permalink)
HAYNBOI96743's Avatar
Re: 2wd spindle lift package installation
sounds about right. They quoted me $475 for the install of the deluxe spindle lift (SAW C/O's) package less the deavers, 3" blocks, another $120 for mount/balance 35" tires on my current 17's, and another $110 for the alignment, total comes out to $695. Did the alignment on my own so came out to $585. They did a good job
BTW does the $680 include tires or just the lift? I would look around and compare prices and go from there. I went with them cause out here in the islands you don't have variety, so it was them or another shop which would have cost $280 more for the exact same thing
HAYNBOI96743 is offline   Reply With Quote
Old 10-28-2009, 03:10 PM   #3 (permalink)
USN HM 350Z's Avatar
well, I had spindles, new struts, rear blocks, shackles, rear shocks, tires mounted and an alignment done for $520.00 labor. Hope that helps
2008.5 Nissan Titan -CST, Bilstein, 3inch PA Body Lift, Toyo AT's, PRG traction bars (on order), CDT Audio, Sundown Audio, RE Audio, ipod (Thanks Tech12Volt).
2009 Subaru WRX - SPT Cat Back Exhaust, Cobb Access Port, SPT Heat Shield, SPT Front Strut Brace, Alpine W205 with full ipod control
USN HM 350Z is offline   Reply With Quote
Old 10-29-2009, 09:24 AM   #4 (permalink)
mine was $500 with labor and alignment for what its worth
2006 Silver KC SE
Interior: Tech 12 Volts Dual 10" Box*2-Infinity 1062w's*Alpine MRP-M500 Amp*Infinity Reference 3030cs Components*Infinity Reference 6022i Rears
Exterior: Smittybilt Side Steps - Black*Smittybilt Bull Bar - Black*Lower Bumper Billett Grill - Black*avs Ventshades*15% tint
Suspension: CST 4" Spindles*SAW 2.25" OEM Replacements*CST Stainless Brake Lines*Bilstein Rears*3" PRG Billet Blocks*35" Nitto Terra's
Performance: S&B CAI*Flowmaster Dual Exhaust
On the way: Billett Upper Grill - Black*CST CBDB*Kenwood 10" in a Tech12 Under Front Seat Box
WAR EAGLE!
bhamby3 is offline   Reply With Quote
Old 10-29-2009, 09:55 AM   #5 (permalink)
54warrior's Avatar
Surely there is someone around the Orlando area that has experience with this and can help you out for a much less price or maybe a few cases of beer.
2005 Nissan Titan CC SE 4x4
Old 10-29-2009, 09:58 AM   #6 (permalink)
Send a message via AIM to Alwaysbeingdumb
Well if it helps any i payed NOTHIN, Because of this great site and ScottsBro. I think you should look around on the site and see if any one can give you a hand with the install.
"Your Not Lost ....Your Just Off Roading."
Mods:
130 Watt KC Day Lighters, Dual Magnaflow Exhuast, Burn Out Mod,10000k 55 Watt HIDS, Fujita F5 Intake, 2* Advance, 4" CST Spindles, DR Coilovers, 2.5" Deaver pack, 3" blocks, Pro-Comp rear shocks, Pro Comp 10" Subs (BLOWEN Kenwood Amp), 6X8 Infinty Speakers, Sony Ipod Ready HU, Flat Black OEM Rims.
I NEED CHROME BT!!
Alwaysbeingdumb is offline   Reply With Quote
Old 10-29-2009, 05:25 PM   #7 (permalink)
x2
when i decided to lift my truck, i had absolutely no knowledge of trucks (was a car guy all my life) but searching, reading and looking on this site basically gave me enough info to do it myself. i think with some knowledge of cars/trucks and the right tools, its not too hard to knock out yourself. i did the spindles, c/o spacer, c-30 deavers, blocks and shocks during a weekend. just took my time and kept referencing some posts on here.
good luck!
______
HAVE...
2007 SE CC
CUSTOM TRUE DUAL GIBSON EXHAUST
4IN CST SPINDLE W/ 2IN PRG SPACER
C-30 DEAVERS W/ 2IN BLOCK
SAW RES REAR SHOCKS
18X9 XD HOSS
35'' PRO COMP XTREME A/T
HAD..
1996 CIVIC HB
B16 MOTOR
FULL BLOWN RACE CAR
JUST BOUGHT...
HONDA CRF250R
mr abstract is offline   Reply With Quote
Old 10-29-2009, 05:54 PM   #8 (permalink)
NIZMO4X2's Avatar
do it urself. as long as you have access to the right floor jack, a good torque wrench and a good set of sockets your set. with the right planning it will take you 3 hours for the first side and about another hour with the second side.
2006 Nismo Frontier 4x2 KC
-Titan Arm Swap, 2.5" Titan SAWs (1/2" preload), CST spindle, PRG UCA, 2" Fox Airbumps
-PRG 10 leaf pack, PRG Shackle, 2.25" extended Piggyback SAWs, 2" block, 2" spacer
NIZMO4X2 is offline   Reply With Quote
Old 10-29-2009, 08:45 PM   #9 (permalink)
yamatitan's Avatar
lol I should get into the lift installation business, what these companies charge is insane.
Procomp 6" ($1300.00),SAW coilovers ($1000.00),Rear Sway-away piggybacks ($399.00),PRG Offroad Traction Bars ($489.00), C-30 Deaver pack ($140.00), PRG Shackles ($139.00), PRG UCA ($599.00), NCD 2" SPACER ($89).
37x13.5x18 Toyo MT's ($1900.00)
2* Timing Advance ($0)
Volant Powercore ($320.00)
Color Matched Bushwacker Pocket style flares ($600.00)
Stillen Big Brake Kit ($905.00)
Doug Thorley Longtubes ($675.00)
Money wasted so far=$12,420.00
Old 10-29-2009, 09:01 PM   #10 (permalink)
I would so the same if I had time and the right tools. Being a college student right now aint the time to do it. Hopefully with a degree in computers I'll be able to muster up some $$$ and start my own business. We get Jacked out here in the islands but it would be nice to level the paying field!
Old 11-03-2009, 12:42 AM   #11 (permalink)
hey i live in sd too. i was looking for a lift also where did you get yours done at 520 sounds good. thanks
juniortitan is offline   Reply With Quote
Old 11-03-2009, 05:20 AM   #12 (permalink)
Prestons off the 8
Old 11-03-2009, 06:19 PM   #13 (permalink)
Peytons_Titan08's Avatar
hey man call ricky at jeepersden off east colonial and tell him your a friend of mine, he should take care of you.
TRUCK IF FOREVER CHANGING! check back
"LIFE IS GOOD"
Peytons_Titan08 is offline   Reply With Quote
Old 11-04-2009, 12:44 PM   #14 (permalink)
Titanup07's Avatar
Yeah your the second person who has told me to check out jeepersden. I'll give them a call and see. Thanks
2007 black CC 2x4
Banks Exhaust
Old 11-04-2009, 01:33 PM   #15 (permalink)
damerowalex's Avatar
Do it yourself!
I did mine, without any real knowledge of what I was doing and it wasnt too difficult.
May be a pain in the a** with the deaver package though..
Go for it! Save the $.
damerowalex is offline   Reply With Quote
PRG 2wd Spindle Lift Package bhamby3 Titan Suspension 16 06-12-2009 09:54 PM
2WD PRG spindle lift worries! FightinTitan Titan Suspension 10 05-12-2009 09:33 AM
WTS: 4 inch spindle lift 2WD rgregory1965 Buy/Sell 1 03-05-2009 06:58 PM
PRG 2wd spindle lift package opinions TitanBarry Titan Suspension 1 11-06-2008 03:04 AM
2wd 4" lift Spindle, very soon PrerunnerGreg Titan Suspension 75 05-28-2006 05:29 PM
