Originally Posted by deadlift
Instead of the 1.5" block for the rear could someone go with say the PRG Deaver Titan C-30 3-Leaf Spring Pack + PRG rear shackle to bring it down a bit ?
You could go that route. But remember, C30 lift is higher than the C10. I've actually thought about this route as well instead of blocks.
C10 gives 2.5" lift on 4wd and 1.5" on 2wd
C30 gives 3.5" lift on 4wd and 2.5" on 2wd
Shackles can be set for 0", .5" or 1" drop.
C10, 4wd + PRG Rear Shackles drop 1" = 1.5" of lift
C10, 2wd + PRG Rear Shackles drop 1" = .5" of lift
C30, 4wd + PRG Rear Shackles drop 1" = 2.5" of lift
C30, 2wd + PRG Rear Shackles drop 1" = 1.5" of lift
