I am planning on starting with the PRG Mini-Lift on my 07 CC 2x4 next month, but I am looking to the future as I know I will want to go bigger. I see alot of people going with either the procomp or fabtech 6 inch lifts, but after reading a little on PRG's website I see they off a kit that offers up to 8 inches of front lift using spindles and coilovers (PRG Products). Is there a recommendation going either direction?! I am not sure how much I will be off road considering I am 2wd, but I plan on playing a little bit. As poser at it sounds, I like the look of a titan rolling on 35in tires. Any suggestions? Will towing be really sacrificed with these setups? These are really newb questions I know...THANKS!
David
DMack
-2007 Titan SE CC 2X4
-2006 Honda 599
-2006 Honda CRF450X Super Moto
Shop Online 24/7 @ www.friendlyyamaha.com!
If you are a 2wd, the bracket style lifts (i.e. ProComp, Fabtech, etc.) is the LAST direction you want to go. Go for any of these packages: PRG Products
__________________ 2005 Nissan Titan CC SE 4x4 6" Stage 1 Procomp Lift, SAW Coilovers-Front, Bilstein 5125 Series Shocks-Rear, Total Chaos Shackles, Custom Skid Plates
54 warrior is right, a bracket lift wouldnt be your best choice, if i was you, i would go with a spindle lift. i would get the extended travel spindle lift if i was you. i think it gets you like 8" of lift, plus you get alot more ground clearance, unlike a bracket lift
2007 Galaxy Black, CC, 4x4, Big Tow, Off Road.
Custom Dual FM 40 Series Exhaust, AEM Brute Force CAI, 2* Timing Advance, 2 JL Audio W3 10" Subs, De-Badged, De-Chromed, Pro- Comp 6" Lift, Radflo Coilovers, 20x10 KMC D-Backs, Nitto Terra Grapplers 305/55/20
great advise. I read over and over on this forum about what way to lift my T and I am glad I did. I started out basic with the CST spindles, Bilstein adjustable struts up front set to +2 and a 4 inch block in the rear. Next phase of my suspension will be Deaver C30's in the rear with a 3 inch block, PRG Upper Control Arms and sway-a-way 2.5 coilovers in the front. This should give me 8 inches of suspension travel. A lot of people don't like block lifts, but I am also going to be installing a 3 inch BL. I only do light off-roading, so I am not worried about any negatives from the BL.
__________________ 2008.5 Nissan Titan -CST, Bilstein, 3inch PA Body Lift, Toyo AT's, PRG traction bars (on order), CDT Audio, Sundown Audio, RE Audio, ipod (Thanks Tech12Volt). 2009 Subaru WRX - SPT Cat Back Exhaust, Cobb Access Port, SPT Heat Shield, SPT Front Strut Brace, Alpine W205 with full ipod control
The bracket lifts are really about the only way to lift a 4x4 because the front diff housing has to be dropped down a little. This is where your 4x2 has it's advantage because you can go with 54warrior's suggestion and gain way more true ground clearance than we can with a 4x4.
