Old 11-17-2009, 07:23 PM   #1 (permalink)
08pro4x2486's Avatar
Need advice on using longer shocks w/stock leafs
Ok I bought some Bilstein 5125's to match the lift increase of Deaver C-10's. 2.5"-4.0". I decided not to put the Deaver springs on and I am having trouble finding a buyer for the Bilstein shocks. I want new shocks for the rear anyway so how much trouble would it be to use the longer shocks with the stock leaf springs?
"If you've ever heard an uncorked Titan blast to life, it would sound like what it would if you woke up a den of lions-roaring sounds that register at all angles of the eardrum."
08pro4x2486 is offline   Reply With Quote
Old 11-17-2009, 07:35 PM   #2 (permalink)
54warrior's Avatar
Re: Need advice on using longer shocks w/stock leafs
How much are you selling them for? Are they NIB (new in box)? Where did you buy em? Any chance of a return?
Try the buy/sell section?
2005 Nissan Titan CC SE 4x4
Old 11-17-2009, 07:37 PM   #3 (permalink)
I listed them on another thread (buy/sell) for 135. Yes they are new, and from PRG.
Old 11-18-2009, 04:04 PM   #4 (permalink)
No trouble at all. The longest stroke shock you are going to be able to use is a 10" shock. And that should suit up to a 3" lift in the back (I think.. might wanna verify that exactly). I know SAW, King, RadFlo and a few others make them. Everyone on here seems to like the PRG/SAW 2.25 body res. shocks. You can get them from Greg at PRG but I am sure you know that already..
'08.5 Pro-4x King Cab
PRG MT Equipped!
svtguy22 is offline   Reply With Quote
Old 11-19-2009, 05:03 AM   #5 (permalink)
loufish's Avatar
No trouble at all.
Maybe....If the shocks too long it may bottom out before the factory bump stops do...
When the shock is mounted, how much shaft is showing?
How long is the shock?
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
Old 11-19-2009, 07:20 AM   #6 (permalink)
I haven't mounted them yet. They are for 2"-4" of lift on a 4wd. I wasn't going to mount them until I heard back from Greg or another equally knowledgeable individual. So you think it will be fine then?
Old 11-19-2009, 10:21 AM   #7 (permalink)
Greg told me the SAW's would work with our factory springs.. The same shocks you are currently running.
PRG MT Equipped!
Longer Shocks??? dgood Titan Suspension 3 09-16-2009 09:30 PM
FS: Stock Coils and Leafs Hades Buy/Sell 2 01-05-2009 06:02 PM
WTB: Longer Shocks to Relace my Ranchos Dr_Combustion Buy/Sell 5 09-04-2007 01:05 AM
Longer Shocks MississippiTitan Titan Suspension 3 03-11-2006 08:07 AM
