Mini lift or leveling kit? - Nissan Titan Forum
post #1 of 16 (permalink) Old 11-08-2010, 11:38 AM Thread Starter
iTrader Score: 0 reviews
So 2 questions. I can do a mini lift with 2.5 up front 1 in back or just the 1.5 leveling kit.
I have an 08 KK SE 4x4. My issue is gas mileage. I'm really trying it impact it as little as possible. Also, I'm looking at 305/60/18 grapplers on stock wheels so I want enough clearance but I don't want them to look small either.
rob989_69 is offline
Advertisement
post #2 of 16 (permalink) Old 11-09-2010, 04:42 AM
TITANBOY's Avatar
iTrader Score: 2 reviews
Re: Mini lift or leveling kit?
2.5 up front will probably be too much up front (probably get coil bucket contact) i had 35's on stock wheels with just a leveling kit. it rubbed very little so i did a pwm. 305/60's should fit with the 1.5 my gas mileage dropped 1mpg with 35's
  • '05 Titan SE CC 2WD
    5100's(middlenotch) CST Spindles moog '08 4x4 springs 35X12.5X18 Toyo M/T 1.25 wheel adapters 18x9 Moto Metal Wheels Debadged Bully Dog GT Air Box Mod Mesh Grille Mod
    Headlight Mod Dechromed Taillights Homemade Front Bumper Homemade Traction Bars Homemade Tow Hooks
TITANBOY is offline
post #3 of 16 (permalink) Old 11-09-2010, 05:30 AM
Carbeaux's Avatar
iTrader Score: 12 reviews
Agreed that on your 4x4, the 2.5 is probably too much. If you want it as level as you can get it with a spacer, go with a 2". If you want to put an inch of that rake back in go with the 1" block on the back. 305/60s on a level kit should be no problem. I'm familiar with a few that have run 325/60/18s on just a level kit with no rubbing issues.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James 'Mad Dog' Mattis
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
post #4 of 16 (permalink) Old 11-09-2010, 06:02 AM
gusman's Avatar
I'm pretty sure since you're 08+ and 4x4, 1.5" is the biggest spacer you can go up front. Throw a set of blocks in the rear and call it a day after
'13 Ram 1500 Sport Quad Cab 4x4 Black on Black
'08 Cummins 2500 QC SWB H&S DeletedSOLD!!!!!
'05 Galaxy LE KC 4x4 BT SOLD!!!!! But Im Still Lurking
MBRP 3.5" Cat Back Single Side Exit, 4" Poilshed Tip (Painted Black) ::PRG Minilift (2"/1.5")
::325/60 18 nitto tg's:: Nav Bezel with Magellan 1700::18X9 XD Monsters 5.71"BS, 18mm Offset::Toyota Tundra mirror lights custom mounted on BT mirrors:: 2* Timing Advance
Padre's T
-2010 Galaxy LE CC 4X4 BT
gusman is offline
post #5 of 16 (permalink) Old 11-09-2010, 06:57 AM
Carbeaux's Avatar
You're right, Gus. I didn't pay attention to the year model.
Hook 'Em!
Carbeaux is offline
post #6 of 16 (permalink) Old 11-09-2010, 02:17 PM Thread Starter
Thanks guys, leveling kit it is. Save a few bones in the process.
post #7 of 16 (permalink) Old 11-09-2010, 03:25 PM
TCUbro-dawg's Avatar
hey rob can you let me know how that leveling kit works out? i've been on the fence about the same question. im not sure if the prg leveling kit or the prg mini lift kit (2" front and 1" or 1.5" rear)would be choice for me. i also was looking at the 3"RC lift kit, but apparently that might not be the best idea. i've been reading a ton of threads and trying to get ideas. i have an 08 so the stock UCAs have me curious about which to go with. thanks
TCUbro-dawg is offline
post #8 of 16 (permalink) Old 11-09-2010, 03:46 PM Thread Starter
Sure. Actually after I posted that I did a little shopping. Turns out I can get the 1.5" leveling kit from PRG, or the Mini lift kit off ebay for about the same price. I may go with the lift kit now. We'll see.
post #9 of 16 (permalink) Old 11-09-2010, 08:22 PM
sounds good, keep me posted. im starting to lean towards the prg mini lift now anyways. but i want to see how it looks first and stuff.
post #10 of 16 (permalink) Old 11-10-2010, 06:10 PM
Hey guys, same story, have an '07 4X4 and want to fit a larger tire underneath. Is there much difference from the PRG kit and a cheaper kit? Will this affect my stock suspension? Will it compromise the smoothness of the ride? What is the largest I can go 2.5" or 3"
And one last question, can I fit 35" tires?
derek.cy is offline
post #11 of 16 (permalink) Old 11-11-2010, 05:23 AM Thread Starter
I am by no means an expert but I'll answer your questions based on my own findings.
I'm sure the PRG kits are better quality, but frankly, for what it is and what it does if I can get it for less than half the price you bet your butt I'm gonna do it. There are no moving parts to it. The only difference in some I've seen is that there are one's out there that appear to be two pieces of aluminum and seem like they would be a little more poorly constructed. Check out ebay they have some on there that look just like the prg's and that's what I'd recommend.
I believe for your model you can go 2" in front if you're leveling. Possibly 2.5" for the mini lift. I think 3 is too high.
Yes, with a leveling kit or mini lift you can definately fit 35's with no problems at all.
post #12 of 16 (permalink) Old 11-11-2010, 08:52 PM
TITANBOY's Avatar
2" is the max you can run on the front. it will not affect the stock suspension or compromise smoothness. you can run 35's, but only on stock wheels or aftermarket wheels with close to the same backspacing as stock or you may have rubbing issues. you also might have to do a pinch weld mod to the front fenders. search pwm. my kit came from top gunz and i have not had any problems.
TITANBOY is offline
post #13 of 16 (permalink) Old 11-13-2010, 07:29 AM
Thanks for the input. I did look up the PWM. I find pics to where it goes however that is all I find. Is it somethingthat needs to be purchased or just something that needs to be modified?
derek.cy is offline
post #14 of 16 (permalink) Old 11-13-2010, 02:00 PM
gusman's Avatar
its a modification just basically folding back the inner liner so the tire has clearance when it turns. 2" is the max you can go up font since youre 4x4. the difference between a mini lift andf a level kit is that the mini lift is a level kit with a block in the rear to also raise the rear of your truck. 1" and 1.5" blocks are the possible options
Padre's T
gusman is offline
post #15 of 16 (permalink) Old 11-17-2010, 05:39 PM
I do have the Off Road Package which has the 17s, not the 18s. For what I understand I can't fit the 35s on the 17 in rim becuase it is too narrow. is this true?
derek.cy is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
PRG Mini Lift and Leveling Kit GaryR1984 Titan Suspension 4 05-24-2010 04:00 PM
FS: Mini Lift Kit, Leveling kit, Stock spindles ACTion Performance Buy/Sell 15 03-24-2010 05:28 AM
WTB: PRG Titan Mini Lift Kit or Leveling Kit Ern3 Buy/Sell 7 03-24-2009 07:14 AM
PRG Leveling/Mini-Lift kit!@#$%! Titan R Buy/Sell 1 02-23-2008 05:30 PM
PRG Leveling/Mini-Lift kit!@#$%! Titan R Texas Forum 1 02-23-2008 02:45 PM
You may post new threads
You may post replies
