User Name
Password
ride quality w/ daystar!!!! - being discussed at Nissan Titan Forums in the Titan Suspension section.
Old 07-04-2004, 02:01 PM   #1
mytitan
well i have had the 2.5 kit from daystar since january, i just got back from big bear and did some back trails. the daystar is still good, shocks are still good, ride is good, and NO PROBLEMS.....
titan crewcab 4x2 xe
stock shocks
17x8 centerline wheels on bfg 265x70x17
pace edwards jack rabbit tonneau cover w/ explorer rails
mytitan is online now   Reply With Quote
Old 07-04-2004, 02:56 PM   #2
TampaTitan04
good to hear!!!
TampaTitan04 is offline   Reply With Quote
Old 07-04-2004, 03:31 PM   #3
BossHogg
Picture of mine after I put a little water scrub on it.
Yeah, no Daystar complaints here... Is your Titan 4wheel drive? Any binding while turning?
Click image for larger version
BossHogg is offline   Reply With Quote
Old 07-04-2004, 03:32 PM   #4
BossHogg
Nevermind, should have read your description. I haven't put mine in 4wheel yet, but I am curious if anyone has 4 wheel drive and any problems. I doubt it, the angle change is slight, but just wanted to get feedback. Anyone?
Old 07-04-2004, 03:34 PM   #5
BossHogg
The backend on mine ended up still being about a 1/2 inch taller, which worked out perfect for the boat that I tow. It has a tongue weight of about 250 lbs. and it rides perfectly level when it is hooked up.
Old 07-05-2004, 03:59 PM   #6
dirtydozen
i have 4x4..took it out trail riding this weekend at duck creek and the suspension squeaks like crazy and something rattling really bad underneath sounds like a loose skid plate or heat shield or something...it's really annoying anyone else having this problem...and the B-LSD works like a charm but doesn't seem to work on the front axle ...is this normal ?
dirtydozen is offline   Reply With Quote
Old 07-08-2004, 08:56 AM   #7
tortuga
Banned
tortuga's Avatar
BossHogg,
love the truck!!! you guys love the daystar? i have the daystar kit sitting in my closet as i have been reluctant to install the kit. its been awhile since i've been on titantalk and have been somewhat out of the loop on all the lift issues. i was thinking of going with the cst lift kit and the problems with the daystar lift made me holdoff. but ultimately the daystar, looking at your trucks (bosshogg/vinoche/michiganmade) it looks as though the daystar is really all i need.
So the ultimate question is this:
should i just say screw it and save a few thousand dollhairs and just put my daystar lift in? is there really no problems with the lift?
once again love your truck bosshogg!!!
tortuga is offline   Reply With Quote
Old 07-08-2004, 10:01 AM   #8
mytitan
wait for....
prometheus, even though i have no problem with the kit, the rancho adustables are coming out soon and i will probably switch them to the rancho.....
Old 07-08-2004, 06:20 PM   #9
BossHogg
Prom,
Yeah, love the Daystar so far. No problems, but again, I have not had it out on the trail. A big deal for me; a truck is not a truck without the 4wheel working smoovely.
I am also with the other guy. If I had a choice between spacers and adjustable shocks with more travel; well, the choice is clear. However, in my case, I could not stand to look at the truck one more day with it's rear sticking up in the air.
I appreciate the compliments on the truck; despite the fact that I maintain it is ugly -- just as a truck should be.
Old 07-13-2004, 01:26 PM   #10
genebarb97
genebarb97's Avatar
Daystar
I have the 2.5" Daystar on my KC 4x2. I went to Mono Hot springs and did some off roading. Very rough road with mostly rocks and gravel. I had no problems at all and did not hear any unusual noises. I am happy with the lift kit so far.
SE KC 4x2 Smoke RF
genebarb97 is offline   Reply With Quote
Old 07-13-2004, 02:27 PM   #11
Wmoore
Send a message via Yahoo to Wmoore
Has anyone with the Daystar installed had the dealership tell them that their warranty is no longer valid? I was wondering because I have yet to install my Daystar because I need to get some work done by the Dealer.
Wmoore is offline   Reply With Quote
Old 07-15-2004, 08:25 AM   #12
RedTitan
Just had the Daystar kit installed yesterday on my CC 4x4 with off-road. The ride is just as smooth as without it. I too was concerned about the warranty but after asking my dealer about this directly they said it wouldn't be a problem and would in no way void the entire warranty. Suspension issues would be addressed on a case by case basis based on how extensive the mods were. The Daystar kit is a minimal mod.
RedTitan is offline   Reply With Quote
Old 07-16-2004, 05:31 PM   #13
workman1000
I've got the daystar kit and there is a distinct topping out of the suspension when coming down the back side of speedbumps or any large drops in the road surface. There is hardly any downward travel left on the supension. Its not noticeable if you live in an area with real good roads, definitely noticeable on bad roads and trails.
workman1000 is offline   Reply With Quote
Old 07-17-2004, 11:19 PM   #14
DallasTitan
DallasTitan's Avatar
Any noise yet? or just topping out?
________________________
2004 Titan SE CC 4X2, Built 11-15-2003
Purchased 12-12-03
Galaxy Black, Popular SE pkg, Capt. chairs/gated shifter, Factory Fog lights, UtiliTrac/Bedliner pkg,PRG Leveling Kit Front and Rear
DallasTitan is offline   Reply With Quote
Old 07-18-2004, 12:50 PM   #15
workman1000
When it 'tops' out, the suspension has reached its limit of downward travel. When that happens, the full weight of the suspension, tires and wheels slams down against the frame. Its jars the whole truck. Sounds like someone hitting the dash with a sledgehammer. Not ideal.
It is my only option for now but is not a long term thing for me. Its something most could live with, especially those in the city that don't go offroad. But I don't want to deal with it any longer than I have to.
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
