5100's Install and Tips
454K views 1K replies 265 participants last post by  Amax
#1 · (Edited)
5100 Install and Tips
There are countless threads about how to/ how not to install Bilstein 5100 series struts. Most of these are thrown together by someone who has had something go wrong, so I think its time for a proper review.
First off, I have an 07 4x4 Titan with Bilstein 5100's, set at the second notch, and 08 4x4 coils, all sitting on 275/70/18 BFG AT's. The struts were ordered from 4x4parts.com and the springs from Fontana Nissan (Both are supporting Vendors).
The year of your truck matters because 04-07 springs are shorter than 08+ springs, and the 08+ coil buckets are set higher than the 04-07 ones.
With that said, your results will vary depending on your truck and final setup. (EDIT #2) This will work on all model Titans. The Rancho's and OEM shocks are put together the same way. The 08+ Pro4x springs most likely will be the hardest to compress, followed by the 08+ 4x4, then 08+ 2wd - 04-07 4x4, 04-07 2wd.
There have been a lot of post recently about if you can run the 5100's with a spacer to get more height. Answer is: you can, in certain situations. First, the spacer needs to be the same size or smaller than what is needed to level the truck. (EDIT 10/3/14) The new 5100's with the CNC'd lower perch do not provide any lift. Bilstein shortened the overall length of the strut to compensate for the 08+'s design. If you have the older 5100's with the steel lower perch, your 5100's are .5" longer than stock, which adds .5" to the total height of your spacer. You will need new upper control arms if you use the spacer that is used to level your truck. You might need new uca's if you use a spacer that is smaller than the one used to level your truck. For the springs used, it will not matter. for you 04-07 people, if you have contact with your stock springs, you will have contact with the 08+ springs. The setting also does not contribute to coil bucket contact either. The setting adds preload, which compresses the spring on the shock, resulting in a "stiffer spring" and more height. You will also need cam bolts to get the alignment correct. PRG arms will give you more clearance than any other due to their design. Total Chaos, CST and Camburg will be next with clearance, then Rough Country. You can grind the coil bucket lip off where contact is occurring. Many have done this with no problems.[/COLOR]
You get cb contact from the strut being too much longer than stock. A spacer makes the strut longer. Ergo, if you install a spacer that is taller than what Is recommended, you will get cb contact. The 5100 adds .5" to the spacer because the body is longer. So add that to a 1.5" spacer and you get 2". The last inch comes from preloading the spring. Preloading the spring is stuffing the stock spring in a smaller space, which the 5100 allows you to do. This is essentially creating a stiffer spring. Same weight plus a stiffer spring equals less droop. So by putting the 5100 on the second setting over the bottom, you get a stiffer spring, less droop, and a higher ride. This is where the last inch comes from. PRERELOAD DOES NOT CAUSE UCA TO CB CONTACT.
Greg from PRG has said that 4" is the max you should lift a 4x4 without a drop bracket, due to cv angles. I wouldn't push it, because the steering rack could also go.
7/25/13 Update:
Bilstein has reworked the lower shock perch of the 5100's to account for the change in the suspension of the 08+. The new style of 5100's with a CNC'd lower spring perch provide 0" Lift on the lowest setting, ~1" lift on the middle setting, ~1.75" lift on the top setting (from what i have read). Select your setting accordingly.
Another thing to note. My last setup, before i sold my truck, was with a 1.5" spacer, 5100's on the bottom setting, and 08+ 4x4 coils. I was able to run the stock swaybar endlinks with this setup. I'm not saying it will work for everyone, but its something to look at and possibly save a few bucks.
When you receive your 5100's, they will include the strut, the lower coil bucket, adjustment clip, black rubber boot, aluminum boot holder, conical washer facing down (IMPORTANT) and a lock-nut up top. EDIT #3: make sure you have all of these parts before installing. Each part is highly important. If you do not have a part, call Bilstein directly and they will send you it for free.
If you ordered the 08+ 4x4 springs, their self explanatory. Grey plastic end is the bottom.
Guys with the 08+ 4x4's will want to re-use their OEM coils for maximum lift.
Choices, Choices...
Option 1: You do it yourself. Compress the spring with one of the rental tool programs from most major auto stores. PITA, and you will cuss yourself for not taking it to a shop.
Option 2: Take it to a shop. Easy to do, but this is where most bad installs come from, and you will cuss yourself for not doing it on your own.
This is for the DIYers:
Start by unbolting the swaybar from the LCA on the left and right sides. Then, place a jack on one side and give it a few pumps to take some pressure off the suspension and wheel. Loosen the lug nuts, jack the wheel off the ground, pull the wheel off. Remove the lower shock bolt from the LCA, then the three smaller nuts from the top of the coil bucket. The entire assembly should drop right out.
TIP #1: This is a good time to check your UCA and coil bucket for contact points. Simply press down on the spindle till the UCA hits the CB. If you want to grind the CB, mark the points of contact and grind around the area. This will allow for more clearance and should minimize contact during droop travel (downward movement) if there is any. I did this just for clearance reasons. I did not have any contact with my setup and no grinding, but I ground some off anyway.
TIP #2: Remember the way the strut looks, as in how the top and bottom perches are in relation to the bottom mount.
Take the strut and place it in a vice with a rag around the bottom. Place the compressor on each side of the spring. One as high and low as possible, the other on the opposite side in the same fashion. And yes, I disassembled one of my 5100's just for this.
Begin wrenching down and cussing b/c its gona be aggravating. Work each side until the spring starts spinning.
Loosen the top nut with the box end of a wrench and vice grips. Take it off SLOWLY in case there is still tension on the spring.
Once the nut is off, the coil is free to come off the OEM strut. Note the position of the rubber bushings and the top spring plate. You need to remember this.
Take the OEM strut out of the vice and place the Bilstein in, in the same fashion.
VERY IMPORTANT TIP: Check the lower spring bucket clip AS SOON AS you put it in the vice. This is the time to adjust it to your desired setting. The main point of this is to make sure the clip is set in the groove COMPLETELY. I have personally seen a clip that was not set properly come out of the grove, causing the spring to decompress with the full weight of the truck on it, causing major chaos.:teethmast:teeth:
Make sure the Bilstein supplied washer is on and is facing down toward the black boot.
Put an OEM black bushing on the rod, followed by the OEM metal spacer inside the bushing.
Now place the spring (grey end down) on the lower spring seat.
Then the upper spring perch with the black perch bushing between it and the spring. Line up the end of the spring with the notch on the perch bushing.
Then the other OEM black bushing.
Then the OEM conical washer facing up.
Then the Bilstein supplied nut.
Tighten the nut down using the same method as getting the OEM one off.
Before decompressing, make sure the top spring perch, bottom spring perch, and the bottom mount line up the same way as they from the factory.
(EDIT #1) Essentially, if the bottom mounting hole of the strut is parallel to you, the top perch needs to have two studs sticking up in the front and one centered in the back. You can tweak them slightly by mounting the top studs in the CB and taking your lug nut wrench, which has a flat side on the pointed end, placing it in the lower mount and twisting the assembly. I would not advise just throwing it together and then twisting it to fit like this.
Then decompress the spring.
To install the 5100, its opposite of taking the OEM one off. Top, Bottom, Torque, Done.
Oh wait, there's another side...:teethmast Start whole process over.
Now for the opinion:huh::
I took my sway bar completely off with the OEM setup before all this. The OEM setup was crap. Way to much lean in the corners which made me put the swaybar back on within a week. With the 5100's set on the bottom setting, it was a much improved ride over stock. Soaked up bumps amazingly with less sway in the corners, but it was still a little too much for me. My current setup is with the 5100's set on the middle perch and the ride is amazing. Minimal lean with a very solid feeling over bumps. Extremely happy with it. I have not tried my current setup with the swaybar on, so if anyone has any input on it, I'll add it to this.
Hope this helps with all the questions. If there is something I've missed, let me know and I'll add it in.
#63 ·
Are you sure they installed the coils properly? Shops are notorious for leaving out parts or installing the spacers upside down etc. Anyway, the '08 coils are much longer than the 04-07 coils, so it would make sense that the coils are close together. Got any pics?
Reactions: honda250xtitan
#64 ·
Thanks for the great write up! I will be attempting my 5100's install tomorrow on all 4 corners and my 1" rear block! I will definitely need this info!
#65 ·
ok took a pic, i may have them move the clip to the lowest setting tomorrow from reading through this thread cause i'm only on 33's and have a 1.5" spacer i'm putting on. They need to straighten out the bolts too cause they're not lining up :bangit:
heres a pic of what i took off...lol. Just a little bent! had to cut the bolts to get it out of the coil bucket
#66 ·
I can't really tell from your pics if everything is put together properly. But to straighten out the bolts and get them to line up, I just put the bottom of the shock in a vice, put the nuts on the spacer to protect the threads, and stuck my 2 foot breaker bar accross the top of the spacer and used the bolts as lever points to spin the spacer and coil together. Since the spring is not anchored to anything, the entire coil and top of the shock can spin. It took me a couple tries to get it perfect so all 3 bolts lined up. It would be really hard to get everything to line up the first try without test-fitting on the truck. But yeah, I would recommend using the bottom setting with your '08 springs. You will probably get 2.5-3" of lift on the bottom setting with a 1.5" spacer. It would probably be hard on the CV axles due to excessive angle if you keep the middle setting and the spacer with '08 springs.
#67 ·
ok i'll give that a shot... i was told middle perch and 2" spacer if i wanted to clear 35's but maybe thats just on 2wd's
#68 ·
2wd's don't have cv axles, so I don't see a problem with that setup. But some guys have cleared 35's with only the RC kit, so I don't see it being a problem with 2" spacer, bottom setting and '08 coils. And if it doesn't fit, you can always go back to the middle setting, but your ride will probably be really stiff and you will be putting more stess on the CV joints.
#69 ·
ok left off the 1.5" spacers cause they didn't work, ride and height are awesome! Completely loving this set up so far and i went down in the river bed with whoops and what not.
#70 ·
The didn't fit or they were to f'ed up to work?
Try it with the swaybar off. Smoothes it out even more.
Sent from my PB99400 using AutoGuide App
#71 ·
They didn't work... the spacer didn't sit flush because the bolts were hitting the top plate
#72 ·
Installed all 4 5100's yesterday, the fronts I put on the middle setting with my 2" leveling spacer and I also threw a 1" PRG block kit in the rear. Definitely rides smoother than the oem shocks! I like the new look and I have not had CBC yet but I'm pretty sure I will it is about 3/4" from touching. I will try to eliminate that by buying the RC UCA's.
I now sit 39 1/4" up front and 39" in the rear.
I also extended my PRG SB endlinks a little more.
I eneded up breaking the special key for my locks and lugs so had to put one stock rim back on :ftard::ftard: :teeth: I will post pics when I throw the other rim on.
#73 ·
Sorry for the delay, it's been raining pretty much non-stop for the last few days here in Hawaii so I haven't been able to wash my truck since the install, so I snapped a few dirty pics of her for the mean time until the weather clears up.
Set-up...
2" leveling kit and 5100's up front on second perch setting
5100's in the rear along with a PRG 1" block kit
PRG OEM replacement, adjustable SB endlinks.
(Purchasing RC UCA's and 1.25" wheels adapters soon!)
(Sorry for the crappy phone pics)
Reactions: lancelot
#75 ·
If you're talking about my truck, I really appreciate man!
Thanks!
#79 ·
Currently the shocks are on sale for the general public with that code applied, after the weekend when the price goes back up, the code will work.
#81 ·
Should be able to be aligned as-is. A 06 4x4 can handle 2" up front no problem. However, every vehicle is different.
Reactions: phatplat
#83 ·
Got my 5100's and 08+ springs in, now I have a few questions. What kinda tool is required to adjust the clip? Does anybody know if the 2 rubber bushings on the OE assembly are dealer only parts? What tourque is required on the top 3 bolts and bottom shock mount bolt?
Thanks in advance for the help.
#84 ·
Needle nose pliers or fingers for the clip - its just an o-ring. Bushings are reusable unless their torn, and are fairly cheap from the dealer.
Sent from my PB99400 using Tapatalk
#85 ·
thanks mack, you da man. I would hate to mess up that little clip.....seems kinda fragile to me.
#86 ·
Oh no. It takes a lot to mess it up. Just make sure its seated properly. I had a little accident, as stated in the write-up.
#88 ·
Well i am finally done with my suspension. Setup is in the sig. 41" all around.
On another note, BFG 275/70/18's are waaaayy too skinny for a lifted T. I'm kicking myself for not getting 295/70's or 325/65's.
#90 ·
C-10 deavers in the rear. It was just like installing a leveling kit except I had to undo the uca from the spindle to grind around it. Only took me around an hour. Going in for a final alignment on next oil change.
#92 ·
295 70 18 will be a 34.?? By 11 tire. The 325 65 18 is a 35 by 12.5 tire.
