Old 12-03-2004, 04:18 PM   #16 (permalink)
I had this problem when I first got my truck. It was the rear suspension boots (red dust covers). I gave those a 180 degree turn and all was good. Six months later quiet as can be.
bradld is offline   Reply With Quote
Old 12-03-2004, 08:16 PM   #17 (permalink)
mikegronholz's Avatar
Here is the picture of the springs ...
2008.5 Nissan Titan SE CC 4x4
RF with Buckets
Black Grill
Chrome Mirrors and Handles
Medium Tow Package (everything but gears)
Line-X with Ducks Unlimited Logo
15% Tint All The Way Around
Llumar Paint Protection
20" Enkei TSP1's
305/55-20 Toyo OC AT
Bilstein Adjustable 5100 Fronts at 1"
Bilstein 5100 Rears
Magnaflow Duals
Garmin Nuvi 660
Cobra 75-WS XT
3' Firestik
Serving as a Tow Rig for my Jeep Cherokee ...
mikegronholz is offline   Reply With Quote
Old 12-04-2004, 10:52 AM   #18 (permalink)
Mike H.'s Avatar
Originally Posted by Mike H.
I use Tri-flow. Spray every pad, roller and clamp on the springs. On mine it is NOT the spring bushings at the ends.
Here are the culprits. I don't have any problems with the spring/shackle bolt bushings. However the plastic on the sides of these clamps with the rollers rubs the leafs, and to a lesser extent the clamps and plastic pads at the leaf ends. I lube all with good spray silicone, lasts about 6-8 months. I imagine moly grease would work longer, but messy to work with.
EDIT- Actually, I'm going to look at taking off the plastic side pieces from the sides of the roller clamps.
Mod links (clickable):
Old 12-04-2004, 02:56 PM   #19 (permalink)
Banned
Squid's Avatar
Mike H thats it exactly.I live on a dirt road so I have to lube mine every month and for me it's only the passenger side.
When they act up,it'll drive ya nuts.
Squid is offline   Reply With Quote
Old 02-13-2005, 09:43 AM   #20 (permalink)
It is the bushings at the spring clamps. Spray thoroughly with a good silcone-based lubricant. That will take care of it......... for about 6 months. Then repeat.......
Forgive my ignorance, where are this bushings, and what are they? anyone have a pic of exactly where are this located so I can silicone spray them?
THX in advance...
Suspension Mods:
BFG MT/KO 35"x12.5"r17
Audio Mods:
Cooming soon:
HIDs and Yellow Fogs...
Old 02-13-2005, 10:41 AM   #21 (permalink)
37L1's Avatar
THX in advance...
See post #18 this thread.
2004 Titan Smoke LE CC
Born 11/18/03
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
Old 02-21-2005, 07:29 PM   #22 (permalink)
Bama334's Avatar
Has anyone taken there truck to the dealer for this? I was wondering if they have a FIX, not patch for this yet? I not spraying mine down for the life of the truck.
2004 Titan LE CC 4X4 Offroad Blizzard
PRG Performance Package
PRG Rear Shackles- PRG Sway Bar End links
True Trac
315 BFG's on factory 17" OR Wheels
Bama334 is offline   Reply With Quote
Old 02-22-2005, 09:50 AM   #23 (permalink)
The dealer fixed mine 5 months ago and it hasn't returned. I never found out for sure what the adjustment they made was because they changed service managers during the month mine was in the shop.
Old 02-22-2005, 01:58 PM   #24 (permalink)
Banned
Squid's Avatar
You can get out there and just do a little bending until it stops squeeking. I could never see any signs of wear/rubbing so it took a little trial and error to finally hit the sweet spot.
Old 02-27-2005, 01:56 PM   #25 (permalink)
Same prob.
I had that same problem the 1st week of owning my truck they replaced driver rear shock and squeak went away!
Prlauren is offline   Reply With Quote
Old 03-13-2005, 05:17 PM   #26 (permalink)
I am having the same problem with mine. I took it to the dealer four times and all they did was spray it with WD40. Isn't that crazy? The problem is still there and they told me they can't fix it. What else can I do?
danifoshi is offline   Reply With Quote
Old 03-13-2005, 05:23 PM   #27 (permalink)
Banned
Squid's Avatar
Welcome to the site.
That little bracket with what looks like a roller on top is the culprit on mine.
Old 07-04-2005, 09:02 PM   #28 (permalink)
I'm hearing this noise whenever I get out of the truck.
I got under the truck and pushed up on the leaf springs and it makes the same noise. One side is worse then the other side.
This something that can be fixed?
Titansg1 is offline   Reply With Quote
Old 07-05-2005, 05:55 PM   #29 (permalink)
Mike H.'s Avatar
Scroll up to post #9 and read to bottom. Just need to spray lube.
Old 08-12-2005, 06:46 PM   #30 (permalink)
PDT
I have a '04 crew cab and at 6000 miles the shock is really annoyingly squeaking. I'm taking it in to the dealership next week.
PDT is offline   Reply With Quote
