Long Bed Lift problem - Page 2 - Nissan Titan Forum
Old 11-15-2012, 06:15 PM   #16 (permalink)
Red Crew08's Avatar
iTrader Score: 0 reviews
Re: Long Bed Lift problem
Im telling ya...the CBDB will help!Made a huge difference in mine! 4x4 shorts with the one piece shaft dont need em...us LWB do.
Red Crew08 is offline   Reply With Quote
Advertisement
Old 11-15-2012, 09:49 PM   #17 (permalink)
KeepGodFirst's Avatar
Did you have a vibration? And are you lifted 6"s. I want to know what comes of this too because it just bought Pro Comp Kit from Prg Greg and if need be, will get cbdb.
KeepGodFirst is offline   Reply With Quote
Old 11-17-2012, 12:40 PM   #18 (permalink)
Red Crew08's Avatar
PC1 lift and ya I had bad vibration! It was night and day
Sent from my DROID RAZR using AutoGuide.Com Free App
Old 11-17-2012, 12:54 PM   #19 (permalink)
zach93's Avatar
CBDB made my vibration way worse! Took my vibration from 75 and up to 55 and up. I am in the process of trying to get to time to fab something up to raise my driveshaft back up.
2009 Blizzard Crew Cab Pro4-X LWB
Prg 6" Procomp Radflo kit with 3" rear blocks at 2degrees, Prg street traction bars, Air lift Ridecontrol, Prodigy brake controller, Magnaflow 22" oval dumped
zach93 is offline   Reply With Quote
Old 11-17-2012, 09:20 PM   #20 (permalink)
You guys got me paranoid now. I just purchased my PC1 kit with Radflo's and have not installed it yet. I know that every truck is different, but I do 90% hwy driving. If I install this and have a vibration, I will go nuts! I drive 3-6hr trips at least twice a month to Atlanta and at least an hour trip one way once a week. I would really like to see the outcome of this one.
Old 11-17-2012, 09:27 PM   #21 (permalink)
Redcrew08, what's your setup? What blocks, coilovers; etc.??
Old 11-18-2012, 05:01 AM   #22 (permalink)
Red Crew08's Avatar
The PC spacers with Bilstein HD's....3" block in rear with 5100's...Total Chaos Uppers. I had a 5.5" block in back when I bought it...vibration was bad...got rid of that and put the 3" in...got way better but still had vib...installed CBDB all good. I also dont have a driveshaft spacer...Greg from PRG said it was not needed on my truck
The Following User Says Thank You to Red Crew08 For This Useful Post:
KeepGodFirst (11-18-2012)
Old 11-18-2012, 11:59 AM   #23 (permalink)
Thanks. I think I will just use the 3" too. Hopefully no bad vibes.
Old 11-20-2012, 02:28 PM   #24 (permalink)
EricNY's Avatar
iTrader Score: 1 reviews
I just ordered some suspension stuff to lift my LWB and now scared. Im not going as high as u guys do u think i will get vibrations?? IM going to be running 5100 on middle setting with a 2" spacer and PRG UCA in the front and 1.5" block for the rear.
2008.5 LE CC 4x4 LWB
BILSTEIN 5100 All Around
PRG BUMPSTOPS,PRG UCA, PRG SBE, PRG 2" spacers, PRG 1.5" blocks, PRG cambolts
INJEN INTAKE, Nitto Trail Grappler M/T 295/60/20
EricNY is offline   Reply With Quote
Old 11-20-2012, 02:43 PM   #25 (permalink)
zach93's Avatar
1.5 in the rear, shouldn't have vibes at all
The Following User Says Thank You to zach93 For This Useful Post:
EricNY (11-20-2012)
Old 11-20-2012, 02:47 PM   #26 (permalink)
EricNY's Avatar
Good to hear!!! Goodluck with yours i hope u figure it out
Old 11-20-2012, 05:00 PM   #27 (permalink)
zach93's Avatar
No problem, I got the rest of the week off, so im gonna be trying some stuff this week. Tomorrow im gonna try 2 degrees in the back and see if it helps, if not im going to fab something to get my carrier bearing back to stock location.
stay tuned lol
Old 11-20-2012, 06:05 PM   #28 (permalink)
EricNY's Avatar
stay tuned lol
Ya i got this week off to, Im getting all my stuff installed tomorrow. I hope it all goes in good and i dont get any vibrations or tire rub. Ill be reading this thread to see how u make out. hopefully u get all good again.
Old 03-04-2013, 08:34 PM   #29 (permalink)
Steelyeyedone's Avatar
iTrader Score: 10 reviews
Are there any CBDB's that do not require cutting? I know PRG's does. And if I cut, and that doesn't fix the issue, I'd be PISSED!
2008 Nissan Titan LE CC 4x4 LWB
Mods
Steelyeyedone is online now   Reply With Quote
Old 03-04-2013, 08:42 PM   #30 (permalink)
zach93's Avatar
Im not sure, I made a bracket to put the carrier bearing back up to stock location and had a steel driveshaft custom made, with a 3" block with 2 degrees. Its the best combination I found, I have vibration only over 80mph now and I don't go that fast anyways so im good.
Advertisement
Stellership Problem Need Your Help (Sorry it's so long.) Scottysize Titan Problems & Dealer Service 14 12-20-2011 09:41 AM
lift... or... long travel a15-05titan Titan Suspension 8 06-22-2011 07:13 PM
crew cab long bed w/lift - pic request Bullwinkle Titan Pictures & Media Post 3 05-22-2010 02:41 PM
Pro-4X long bed, 6" lift GoFast33 Titan Pictures & Media Post 24 01-20-2009 01:19 PM
Solution to the Titan gas mileage problem…(long).. (very long) lowlypawn Titan General Discussion 35 01-18-2005 10:03 PM
SEO by vBSEO 3.3.2
