4 in lift for 4x4's? - Page 2 - Nissan Titan Forum
post #16 of 26 (permalink) Old 11-09-2012, 05:02 PM
Mack207's Avatar
iTrader Score: 13 reviews
Re: 4 in lift for 4x4's?
I realize that you dont gain any clearance because of the drop bracket, but having the truck body and most of the frame up out of the way makes offroading easier. If you were to do a 4" with the rancho, the drop bracket would be close to the same height as stock. This is also why i havent installed a 6" lift.
The 2wd have spindles; 4" lift and increased ground clearance.
You could go with a mid travel kit; i think they can be set close to 4". But be prepared to spend some serious coin.
2012 JKU Sahara Triple Black - AEV 2.5"
In Its Prime: 2007 4x4 SE CC BT UpRev Tuned W/ TLPM
S&B CAI W/ 4" Ram Air & DEI Cooltape|Bosch Platinum IR Fusion Plugs|3"x26" Maggy to shut it up
PRG UCA's|PRG Heimed Outter Steering|Bilstein 5100's & 5125's|08 4x4 Coils|1.5" Spacer|C-10 Deavers|315/70/17 BFG's
PRG Traction Bars|eBay Grille|UWS LoPro|Headlight Mod|Tinted Tails|Colormatched Mirrors & Handles
15% Tint All Around|Wet Okole's|WeatherTech Digital Fit Mats|Custom Rear Storage
The Stigs Mechanic
Mack207 is offline
Advertisement
post #17 of 26 (permalink) Old 11-09-2012, 05:55 PM
reds_titan's Avatar
iTrader Score: 6 reviews
i just had the 5100's with 08 springs on middle perch, 2" PRG spacer and Rough Country Upper arms and even though it sat right the ride over big bumps was bad cause there wasn't much drop in the suspension. Now i have the same set up but the springs are on the bottom setting and it sits just about level and a lot softer ride with plenty of drop when going over big bumps. Also with the 2" spacer i put 2" bump stops. I don't wanna take it apart again for a while but i would go middle setting with 08 springs and a 1.5" spacer next time, should sit a little higher in the front with a firm but good ride.
2006 "Yota Killer" SE 4x4
180,000 Miles and Counting
Duel 2.5" to 3" si/so generic Magnaflow, S&B Ram Air Intake
CSF Rad, Tru-Cool 4590, 5100's w/08 springs, Modified Coil Bucket, CVT Rock Sliders, 2" PRG Spacer, RC UCAs
35x12.5R17 BFG KM2's on Machined XD Addicts, Drilled/Slotted Discs with Hawk HPS Pads, 2" Wheel Spacers,
Front Glassworks Fenders, Custom Speaker Box (built by me) with (2) 8" Fosgates, 800 Watt AMP,
Sony In Dash DVD Player, LEGIT ACCESSORIES Full Interior, Super Reverses, 20" Duel Row and Cubes
Want List
Headers, Cajun B-Pipes, UpRev, LEGIT ACCESSORIES 50" Curved LED Bar
reds_titan is offline
post #18 of 26 (permalink) Old 11-09-2012, 05:58 PM
Mack207's Avatar
Red get a measurement from center of wheel to center of fender. I need to check mine as well.
Sent while Autoguide freezes and crashes.
The Stigs Mechanic
Mack207 is offline
post #19 of 26 (permalink) Old 11-09-2012, 06:25 PM
stryker125's Avatar
iTrader Score: 10 reviews
I see what you are saying now, I understand how it all works just didn't understand what you meant.
Has anyone thought about what I just said about using older model coils to lower your bracket lift a tad? Zero reason why it wouldn't work and many people have been trying to find a way to get a ~4" bracket lift. Problem solved.
-Mazdaspeed 6-
Mazdaspeed CAI
SOLD
-2008 PRO4x-
RC 6" w/ T Bars
5100's, Deaver C30's
35x12.5 Federal MT w/ 2" wheel adapters
Borla ProXS
4" Airaid MXP CAI
5k/3k 35w HID lows/fogs
GO Rhino Dominator 2 steps
"Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety."- Benjamin Franklin
stryker125 is offline
post #20 of 26 (permalink) Old 11-09-2012, 06:42 PM
misfit482's Avatar
iTrader Score: 0 reviews
Not sure if it would work. The question for me is why would you pay for a bracket lift that provides 6" to turn around and spend more money to lower it to 4" of lift. Not to mention decreasing your suspension travel and making it ride like poop.
Seems silly to me when you can spend half the cost to get your 3-3.5" and a very comfy yet capable suspension set up.
With what your proposing you'd likely spend just as much as PRG's extended travel kit to gain the same amount of lift but only the stock suspension travel. Might as well do the extended travel package.
'07 CC 4X4 Banks exhaust and intake w/tb screen delete, headlight mod w/ Morimoto switcbacks, legit hid's, XD diesel rims w/ nitto terra's, PRG minilift, PRG UCA's, Sway bar removed, 5100's all around, DK shackles, PWM, AVM, BW pocketflares, PD'd stuff, BL step rails, Streetscene grille, '08 brakes w/ Powerstop D/S rotors and pads, PRG SS braided lines, SM designs bezel kit, red LED's in footwells
misfit482 is offline
The Following 2 Users Say Thank You to misfit482 For This Useful Post:
honda250xtitan (11-09-2012), Mack207 (11-10-2012)
post #21 of 26 (permalink) Old 11-09-2012, 06:55 PM
honda250xtitan's Avatar
Garage
iTrader Score: 9 reviews
I'm with misfit on this
2011 White CC Pro4x
STOCK AF
Partout Thread\/\/\/
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAIDhttp://www.titantalk.com/forums/buy-...od-prices.html
Traded In: 06 KingCab 4x4
honda250xtitan is offline
post #22 of 26 (permalink) Old 11-09-2012, 07:04 PM Thread Starter
iTrader Score: 1 reviews
So I'm thinkin of doing the 1.5 spacer an 5100s set on the middle perch an I talked to Greg and he stated there gonna be making 2 in body lifts...
chrisc75 is offline
post #23 of 26 (permalink) Old 11-09-2012, 07:07 PM
stryker125's Avatar
I understand you could get an ext travel kit for that price, but at 4-4.5" IF at all possible, what are your CV angles gonna look like? Trash that's what. That's the only reason why I wouldnt go that route, Because that much lift without the drop bracket just won't work, with 4wd that is. This is the reason people with 4wd are looking for a 4ish inch bracket lift.
-Mazdaspeed 6-
Mazdaspeed CAI
SOLD
-2008 PRO4x-
RC 6" w/ T Bars
Borla ProXS
4" Airaid MXP CAI
The Following User Says Thank You to stryker125 For This Useful Post:
post #24 of 26 (permalink) Old 11-09-2012, 07:39 PM
reds_titan's Avatar
I've got glass on my truck now... from the pics mine looks lower than yours though
Want List
post #25 of 26 (permalink) Old 11-10-2012, 10:56 AM
Mack207's Avatar
My puny tires make my lift look bigger lol. How about to the bottom of the front crossmember?
The Stigs Mechanic
Mack207 is offline
post #26 of 26 (permalink) Old 11-10-2012, 02:37 PM
Mack207's Avatar
I'm sitting at 40.5" all around. I'll probably put the smallest leaf of the C-10 back sometime soon for towing, and i should be at 41" in the rear.
25" from the center of the wheel to the middle of the fender. I need to get rid of these tiny tires. To anyone that is going for 3"+ of lift, get 34's or larger.
15" of ground clearance at the front crossmember. I measured at the flat plates inside of the front LCA bolts.
The Stigs Mechanic
Mack207 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Lifted 4x4's??? fulms Titan Suspension 6 11-21-2011 03:03 PM
Do all 4x4's have... Rick Guess Titan General Discussion 4 05-17-2007 06:32 PM
Do All 4x4's Have Abls? PHOEBISIS Titan Problems & Dealer Service 5 10-15-2005 07:08 PM
Question for owners of 04 4x4's CJ3FLYR Titan General Discussion 19 08-26-2005 09:30 PM
why dodge 4x4's suck graytitan4x4 Titan General Discussion 9 03-24-2005 07:32 PM
You may post new threads
You may post replies
