The solution..
Doing one side at a time. Emergency brake and block the rear. Detach the endlinks from the swaybar. Loosen lug nuts. Jack the truck at the jack point, and use a jackstand.
Use a 19mm wrench and socket for the bottom. 14mm at the top.
New vs. old.
L
My Galaxy '05 XE 4x1 modest mods:
Bilsteins HD, PRG adj. shackles, PRG swaybar endlinks, Stillen front and rear swaybar, RAS, Stillen Rad, BD PP, S&B CAI, DT LT's, Berk MP, SS Zoomers catback, Mag-Hytec rear diff cover, CF dash kit.
"The guy who invented the first wheel was an idiot, the guy who invented the other three, he was a genius."
The Following 3 Users Say Thank You to BBtruck For This Useful Post:
Spring compressor kit. Borrowed two kits from Autozone.
Attach the spring compressor hooks with no more than one spring in between the hooks. The large screw will bend if trying to compress more spring. Screw the Compressor until the top hat of the strut is loose. I use a adj. wrench and a 18mm wrench to take off the hat. from left (top) to right (bottom) hat assy..
L
The Following 4 Users Say Thank You to BBtruck For This Useful Post:
Pretty sure the washers cup away from the bushings. I don't see a problem doing it either way though.
Sent while Autoguide freezes and crashes.
2007 4x4 SE CC BT UpRev Tuned W/ TLPM
S&B CAI W/ 4" Ram Air & DEI Cooltape|Bosch Platinum IR Fusion Plugs|3"x26" Maggy to shut it up
PRG UCA's|PRG Heimed Outter Steering|Bilstein 5100's & 5125's|08 4x4 Coils|1.5" Spacer|C-10 Deavers|315/70/17 BFG's
PRG Traction Bars|eBay Grille|UWS LoPro|Headlight Mod|Tinted Tails|Colormatched Mirrors & Handles
15% Tint All Around|Wet Okole's|WeatherTech Digital Fit Mats|Custom Rear Storage The Stigs Mechanic
The Following User Says Thank You to Mack207 For This Useful Post:
I experimented with the washer cup in or out. I found it better to cup the bushing because it keeps it from deforming or squatting. But either way like you said is OK.
L
The Following User Says Thank You to BBtruck For This Useful Post:
nice write up, but the spring and seat should look like this IAW the Nissan maint manual
2008 SE CC 4X4 RED BRAWN w/popular package
Sirius Sportster 5
Spectre Performance Air Filter
Nitto Terra Grapplers
Bilstein 5100's
Activetune Grounding Kit Red wires
24" Magnaflow Cat-Back
Nissan Steprails Black
2* Timing
Nissan Bug Shield
OEM Weather Floor mats
Current miles 129K and still going strong
PINK JETTA WHORE
The Following 2 Users Say Thank You to ArmyAviation For This Useful Post:
I match the top hat to the to the mount, the three screws, and spring location on the hat was right on. Both spring seat looks asymmetrically in the same location on the truck as it sits. I'll have the mech look at it while checking the alignment tomorrow. Now I'm curious, but so far I don't feel nothing out of whack. Thanks for the pic..
L
If anything, I could just unbolt the strut assy. and rotate it to show the spring end looking straight at the wheel like the pic. Feel like doing it now..lol
I'll let you cats know..
L
Sirius Sportster 5
Bilstein 5100's
2* Timing
Nissan Bug Shield
what armyaviation said is something I used to follow too. In fact if it wasnt the right way like nissan states, the tie rod would hit it in turns. but that was on my 06 with 5100's and a pro comp lift.
__________________ 2011 White CC pro4x
Flowmaster Y
Banks Muffler
Airaid MXP 4" Intake
PRG UCA's
Extended travel Sway-Away 2.5 coilovers
PRG Camber Bolts
Homemade Traction Bars
Fuel Boost 18x9
Nitto Terra Grapplers 295/70 18
Front BORA 1.25 Wheel Adapters/ Pinch Weld Mod
6K HID's
10" Sub/Kenwood Amp
No, I don't, but I see clearly that I need to unbolt and move the assy. counterclockwise one notch where the paint mark of the spring is facing the tire.. At least I don't have to take the strut assy. apart. Good catch AA. Bet the alignment monkey would never noticed.
Originally Posted by honda250xtitan
Nice write up!
what armyaviation said is something I used to follow too. In fact if it wasn't the right way like nissan states, the tie rod would hit it in turns. but that was on my 06 with 5100's and a pro comp lift.
No interference here. But why leave it as is? I'll post the fix with pics.
L
